Question about Singer Sewing Machines
How do I use a twin needle on a Singer 4411. I would like to know how to thread a twin needle on the Singer 4411.
  • Singer Master
  • 12,514 Answers
Most machines that take a twin needle will have more than one spool pin and two tension disks (one for each thread). Just be sure to thread each thread separately so they do not become twisted. (And, of course, ALWAYS RAISE the presser foot when threading!)
Posted on Dec 16, 2016
    Top Expert:
  • Singer Master
  • 8,376 Answers
Top thread does not catch bobbin thread singer 4411
Try a brand new needle.
If that doesn't work, your machine has probably been knocked out of time. Take it for service or if you are handy, you can search for "sewing machine timing" and try to fix it yourself.
Mar 31, 2018 | Singer Sewing Machines
Can I use a twin needle on a Singer Trafition? It seems to only sew one line of stitches.
Probably depends on the model. Was a twin needle included with your starter kit?
This one indicates it will take a twin needle:
2277 TRADITION
Your owner's manual or the product specifications are probably the best source for information.
Instruction Manuals
BTW, you are using 2 spools of thread, right? You need to thread both needles with separate spools (do not twist the threads when threading!).
Double Needle Tips Video Demos
How to Use Twin Needle on Your Sewing Machine
Be sure to verify the machine is set to straight stitch. Any zig-zag could break one or both needles!
You also will have to thread the needles manually as the needle threader will not work on twin needles.
ALWAYS RAISE the presser foot when threading the top thread!
Jun 22, 2017 | Singer Sewing Machines
How to thread on a singer 4411. Thank you
To thread the upper thread, make sure that the needle bar is fully up, using the hand wheel. Put the thread spool on the spool pin and secure it with the spool holder. Use the end of the spool holder that is closest to the spool size. Bring the thread through first guide to the left of the spool holder. Slide it past and behind the guide before pulling it into the guide. Then bring the thread to the pre-tension spring. Similarly, the thread goes behind the spring and then comes forward. Next bring the thread down through the channel and up through the adjacent one further to the left. It helps to hold the thread between the spool and the thread guide. Once you bring the thread up through the second channel bring it from right to left through the slotted eye of the take-up lever. Bring the thread down and through the horizontal thread guide, the thin guide clamp needle and to the needle. Thread the needle from front to back.
The manuals for most Singer sewing machines are available from the manufacturer's site: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the 4411 is http://www.singerco.com/uploads/download/1230_4411_heavy_duty_esf.pdf . See page page 16 (page 23 of the PDF) for pictures of the guides.
I hope this helps.
Jan 05, 2017 | Singer Sewing Machines
Singer 4411 will not pick up bobbin thread.
If what you say is the case, the needle/hook timing is off. You can search the internet for sites or videos showing how to do this yourself or take it for service.
May 21, 2016 | Singer Sewing Machines
Having trouble picking up the thread from the bobbin
Try a brand new needle. Verify that the machine is threaded properly--both upper and bobbin threads.
If it is still not picking up the bobbin thread, it is likely there is a needle/hook timing issue requiring service.
May 17, 2016 | Singer 4411 Heavy Duty Sewing Machine
How to oil a singer 4411 sewing machine
you oil it in the center of your bobbin case, also theres a small pad like thing just above your needle , there as well as inside your threading area where the spring is
Aug 13, 2014 | Singer 4411 Sewing Machine
I have a singer 4411 and the bottom thread looks zig zag and top is good I am using a heavier thread for outdoor sewing and a 18 needle. The local singer dealer said that i can get the lower bobbin...
Understanding Thread Tension Threads
Be sure to mark the tension screw setting on the bobbin BEFORE you make any adjustments so you can reverse the changes. If you sew a lot of heavy fabric, it may be worthwhile to buy an extra bobbin (they aren't that expensive). Then set one bobbin for heavy thread and keep one for regular thread. Makes it a lot easier to go from one to the other without fiddling with tension screw adjustments.
Feb 24, 2018 | Singer Sewing Machines
I have a singer 4411 heavy duty and bobbin thread gets snagged
Either blunt needle or you may have a burr on the needle plate
Oct 06, 2013 | Singer 5417 Mechanical Sewing Machine
How to thread a bobbin on singer 4411 sewing machine
If you've threaded the bobbin per instructions... then make sure your needle isn't damaged, bent, or dull. Also make sure the needle is seated fully and correctly oriented into the needle bar.
Aug 24, 2012 | Singer Sewing Machines
How to thread twin needle on singer
Look in your attachments for the secondary spool pin. Then you'll thread both upper threads as normal.
Jul 30, 2012 | Singer Sewing Machines
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
