How do you setup password for 2WIRE213 CONNECTION
How do i obtain a internet password
There are no internet passwords. For lot of internet related services you need passwords. Like when you want to setup a wireless connection, you have to setup your wifi router with a wireless connection the connection gets a name and if you are wise you secure the connection with a password. Same goes for every mail account or accounts on websites. You need an unique login name and to make sure no one els can access the account secure it with a password.
Apr 19, 2015 | Azpen Innovations Azpen X1 10.1-inch...
How do i get the passwords for 2wire2 network on a ipad 5.1.1
Try to find the person who did setup the connection named 2wire2. He / she did give in the password. I can understand when they won't give the password, because they bought the wireless router and pay for the connection to the net.
Feb 17, 2015 | Apple iPad Tablets & eReaders
I have a trio stealth i need a password for wifi
You must have a wireless router, connected to the internet. then you have to setup the router and the wireless connection. Don't forget to setup a password protected connection with WEP2, or else someone else can use your connection and consume your data plan.
Dec 16, 2014 | Tablets & eReaders
Try the following steps:
>control panel
>network connections
>create a new connection
>choose "connect to internet" > Next
>setup my connection manually > Next
>connect using a broadband connection that requires a user name and password > Next
>Then fill in the space and set the user name ad password properly and then follow the setup wizard.
If you need any kind of technical assistance you can contact support cell at
Nov 11, 2012 | Computers & Internet
How to program to my new enternet connection
HEllo bro...
I don't know what model that use, however here the best explanation for you..
1. Username and password for router.
2.Username and password for provider internet.
3.Ethernet cable (rj45 connection)
5. Pc /laptop to setup router ( on step i'm referred to pc)
4. Web browser( more preferred to using internet explorer current version)
1. Plug Ethernet cable to router
2. Plug another end Ethernet cable to pcthat you are using to setup
(Now you have cable was connected between pc and router)
3.Switch on the router.
4.Open web browser. Or click here
5.Some window will popup
6.Enter the username and password for router. If default( mean you don't change username or password,you can leave blank for username and fill password with "admin")
If still can't enter try search at google with your model and brand for username and password default.
7.After success enter, then using the wizard .
8. Fill the username and password for provider.
For step 7th, to 9th, you can directly go setup internet connection( depend to model, sometimes it just type setup) where you will find ppp username and ppp password.. change it..
Good luck and be careful. sometimes you make it right but router need time to create new connection..
For the best go here Lynksis setup
Jul 06, 2011 | Linksys Cable Modem
Connected to d-link network which is unsecured. how to secure?
You need to setup a password for the wireless connection,
1. Connect D-link Router to your computer
Your computer should be connected to the LAN port of using an Ethernet cable.Power on the router after connecting the router to your computer.
2. Log on to D-link Wireless Router
To logon to wireless router type the default IP address of the router on the address bar. The default IP address of the D-Link router is
Before log on to the router it will ask you the user name and password. For a default D-link router
User Name : admin
Password :admin(Flip the router over to know the default username and password)
3. Click on Setup Wizard
To configure the router in an easy way click on the button Setup Wizard.
4. Click on Launch Internet Connection Setup Wizard
To configure the internet connection in this D-link router, click on the button Launch Internet Connection Setup Wizard.
holygrass_21.jpg Now the wizard will show you what steps it is going to complete while running the wizard. Click Next to continue.
holygrass_22.jpg 5. Create new Password For your router
holygrass_23.jpg Setup wizard will prompt you to create a new password for your WBR-2310 Wireless Router. After entering the password click on next.
6. Select your Time Zone
Now the setup wizard will prompt you to select your time zone.
holygrass_24.jpgPost .
Post back if it is not working we will be happy to help you.
Hope this helps.
Jan 12, 2011 | D-Link Computers & Internet
How to do a PPPoE connection?
You have not mentioned OS you are using, i am assuming that you have windows xp or later. Go to properties of my network places and click on create a new connection > Connect to Internet > connect to broadband that requires user name and password .. follow next steps as appears it will install PPPoe protocol and will make a connection also
Jun 26, 2010 | D-Link DFE-530TX+ Fast Ethernet PCI...
Wireless router wont connect to the internet
this would be mine that no computer is connecting to the Internet right now?
here's what we need to do. We need to identify first what Internet connection type you have in there.
have checked connection on the network as well, first and foremost - modem-router-computer is the connection you have.
For cable connection, you need to do a mac cloning on the computer
For DSL connection you need to have a PPPoE connection type on the router
For cable connection:
> access the router setup screen -
> on your IE - address bar
> no username and password is admin
> on the setup tab there is a mac clone service
> enable it and hit the clone button
> save the settings after
For DSL connection:
> under setup tab - look for internet connection type
> set it to PPPoE connection
> try to connect and save the settings there.
Jul 12, 2009 | Linksys Wireless-G Broadband Router
Connection to my computer of hp photosmart c6300 via belkin adsl2router
2Wire 2700HG-B Setup
1. Connection of phone line, ethernet and power adapter
2. Indicator light: POWER: green; Ethernet: blink; DSL: green; Internet: blink or red
3. Open IE beoswer.
4. address:
5. Click "Run System Setup Wizard"
6. Login with preset password: admin. Or change password: click "I forgot the password." Under question "Here’s a hint for the password wedding date", click "I still can’t remember the password.". Then Reset System Password by enter System Key which locate on back of the Router (like: [1234567890]), and your new password, then click "Submit"
7."Set Up Your 2700HG-B Gateway" screen. Keep default "Key Code". Click "Next"
8. "Time Zone". Select your time zone,then click "NEXT"
9. "Set Up Connection Info". Enter "PPP Authentication" information provided by internet service provider. "Username", "Password", and "Confirm Password", then click "NEXT"
10. Screen "Connecting" running...
11. Auto turn to screen "2700HG-B Gateway Setup Complete", click "FINISH", or "EXIT" to complete setup or "Register" to register with 2WIRE on line.
Oct 30, 2008 | 2wire 2700HG-B Router (2700HGB)
How do I secure my dlink wireless connection?
Type (you can type the router address if you have changed) and enter on browser's addressbar. Router's interface will appear.
Click on SETUP and Click on the WIRELESS SETTINGS at left side. on the page you will see the option of WIRELESS SECURITY by drop down menu you can choose the Security mode that you wish. here is the link for the emulator
Please post your question if you need further assistance
Good Luck
Jan 19, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Computers & Internet Logo
David Payne
David Payne
