Question about Xerox Phaser 3635MFP/X Multifunction Copier/Email/Fax/LAN Fax//Scanner Laser Printer
Xerox phaser 3635 email Icon not enabled even though Admin settings have email enabled.
wrinaldo
  • 185 Answers
SOURCE: RESET INSTRUCTONS FOR XEROX 8560 MAINTENANCE KIT
There is no reset. Xerox never designed a supply reset for this machine.
If you installed a new one, either 1) you've got a bad one (get it replaced under warranty) 2)
the chip is not being read (due to drum maintenance camshaft cracked and out of position
Posted on Jul 31, 2009
SOURCE: My Xerox Phaser 6250 won't duplex all of a sudden
I don't have an answer, but I can add some detail since I have the same problem (6250 that suddenly won't duplex).
I have a wired network with multiple Vista machines connected and have been duplexing just fine for YEARS with the same PCs and same drivers. One day my wife complained she couldn't duplex and I messed around, updated drivers, rebooted everything, etc. etc. and finally gave up and sent the print job from my laptop where it duplexed just fine.
About a week or so later I noticed that my laptop would no longer duplex either! Once again I updated the drivers, rebooted, tried different settings, etc. etc. but no luck.
I'm pretty convinced that a Windows patch has caused this issue (which is why there is a timing difference between my machines). I've rolled back my system to remove several patches and things seem to work fine again, however I'm not exactly sure which patch causes the problem AND within a few days Microsoft reinstalls the patch automatically.
Unfortunately I'm not confident that Xerox will put much effort into fixing this driver problem since this is not only an "old" printer, but I don't think many people do much duplexing (so there won't be many people yelling for help).
I'll let you know if I find a better work-around or fix.
Posted on Jan 06, 2010
SOURCE: Default admin password for Xerox Phaser 8550DX
Default admin password is 1111
Posted on May 03, 2010
  • 57 Answers
SOURCE: Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Posted on Jan 22, 2011
SOURCE: How do I print to
This is a silly problem to have to fix but here is how you do it.
Go to Printers and Faxes, right click and select properties.
Then select Printing Preferences.
In the window that pops up, there is a paper option, click on the drop down arrow and select advanced paper selection.
In the next window where it says Output paper type, select 'AUTOMATICALLY SELECT' as opposed to Printer Default type.
This will solve your issue with this printer. It's kind of lame to have to do this but it works.
Posted on Apr 14, 2011
09-800 on phaser 3635 xerox how to fix
That error indicates an incompatible toner cartridge for that model. Verify you are using oem Xerox toner.
Dec 21, 2015 | Xerox Phaser 3635MFP/X Multifunction...
How do I print labels using the bypass tray on Xerox phaser 3635?
All I can add to your question is from my experience.
Make sure you have the recommended labels installed.
The fuser can cause jams when not using the correct recommended stock.
Very old labels tend to ooze a small amount of glue along the edges and can get stuck to the inside.
Print as you would do on paper, perhaps try printing on some white 80 GSM stock and hold them up to the light to check alignment.
Good luck.
Jul 02, 2014 | Xerox Phaser 3635MFP/X Multifunction...
How to reset Xerox Phaser 3100 to factory settings?
First you have to enable the admin mode:
press and release: (down arrow) * #
on SOS1 change the 8th bit to 1 (counting right to left)
ie: 00100001 to 10100001 {press OK to confirm}
Now the admin menus are enabled.
To <Erase all. Reset to default configuration>
press (and release): (down arrow) #7
Feb 19, 2013 | Xerox Phaser 3100MFP
How to change the time on a phaser 3635
To Set Date & Time on a Xerox 3635
Press: Machine Status (hard button)
Press: Tools (on touch screen)
Press: Device Settings (on touch screen)
Press: Set Date & Time (on touch screen)
The machine will have tabs at the top
Press: Set Date
Press: Month
Enter the Month: (Using the hard buttons)
Do the same for Day and Year
Press: Save
Press: Time
Same procedure as above setting the Date
Press Save
Turn the machine off and back on for settings to take effect.
Dec 20, 2012 | Xerox Phaser 3635MFP/X Multifunction...
How to reset admin password on phaser 3635
xerox machines come with default passwords.
once that password is changed only the changer knows it.
should he forget or lose the password he flat has a problem.
the reset requires a xerox laptop/tech to reset and they "will bill" you for doing it.
Jul 01, 2011 | Xerox Phaser 3635MFP/X Multifunction...
We have hosted Exchange email and I've been tasked with getting a xerox 3635mfp to scan to email. So far no luck even though I believe I've input all the correct information.
for scanning with Xerox MFP it is convenient to use MFP TWAIN Importer (http://www.scanworkssoftware.com/twainimportermfp.aspx ) It allows scanning from Xerox MFP directly to user's workstation with secure way and without any additional efforts.
Nov 05, 2010 | Xerox Phaser 3635MFP/X Multifunction...
How do I print to envelopes on Xerox Phaser 3635?
Nov 04, 2010 | Xerox Phaser 3635MFP/X Multifunction...
Can we share 3124 to another users in 1 network ?
Yes. One can by enabling others the access to your printers by first turning on sharing in windows, then installing the printer driver on one pc and ticking the box in the driver on that pc to allow sharing ie right click on printers icon, properties, sharing, and enable sharing tick.
Then going to other computers and installing the printer via installing netwok printer.
You cant do any of this without admin rights
Nov 04, 2009 | Xerox Phaser 3124 Printer
Xerox Phaser 3635MFP/X Multifunction Copier/Email/Fax/LAN Fax//Scanner Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
