Question about Kitchen Appliances - Others
Is their a problem in the Sandwich area with the signal post code cT13OAA
OP: Posted by Barbara Frye on May 11, 2016
Barbara. get car serviced? at an ASE shop or dealer?
you cant fix this lacking tools, ill not try to guess.
did you first erase those errors (push reset on tool)?
and see if they return, ???? this is first.
have you had work on the pump/tank area.
in a collision?
here is why.
first check fuses. any blown.?
then do the cluster self test, no tools needed.
posted here 100s of time, need that?, or the free link to the test in the FSM book? posted that too 100s of times here. (ask or search)
next is scan it, see all errors, not just the 2 you see now.
a real scan tool shows all errors and for sure those that might be related, and any CAN-BUS errors.
a real scan tool can see all JEEP extended DTC errors.
also post if the instrument cluster is acting odd. in any way.
does the fuel gauge work? can you tell?
needle steady and correct for reality,
QOD: questions of the day,
does engine run?
does car drive, correctly day and night with bright head lights?
does any other feature of the car fail. any at all.
no charge lamp failures in cluster, nor volt meter below 14v in the cluster meter of same name (volts)???
Theory of Operation
The Front Control Module isn't receiving a fuel volume signal over CAN B from the Cluster Module. The FCM has
to send the PCM a fuel volume signal over CAN C. The signal the FCM sends over CAN C is implausible.
my guess is 1403 is the real error. (primary)
the fuel sender might be glitching,
here is that sensor,
in the tank , part of pump, part of fuel rack. in tank.
May 11, 2016 | 2007 Jeep Grand Cherokee Overland
How do I clean it after grilling
Gloria, All the links can show how to clean after grilling.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Wash Toasters and Sandwich makers
What the best way to clean panini press with non removable sides
How to Clean Sandwich Toaster Helpful Tips to Cleaning Your Kitchen...
Easy tips for cleaning an electric grill
Apr 19, 2016 | Kitchen Appliances - Others
Have a 94 toyota camry , check engine light comes on when stop at light or car sits at idle. got codes 12 , 22, am very confused !!
Code 12. RPM signal.
Problem area: Loose connection, broken rpm signal wire from distributor to ecm to rpm meter, rpm meter, distributor assembly or ecm defective.
Code 22. Water temperature signal.
Problem area: Loose connection at water temperature sensor connector, broken wire between the sensor and the ecm, defective sensor or ecm.
Aug 25, 2013 | 1994 Toyota Camry
Android ice cream sandwich signal problems
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Nov 10, 2012 | Nokia 3310 Cellular Phone
Icecream sandwich will not load. ?????
I think it would help others get a better understanding if you posted what brand tablet you're using. Motorola Zoom, Apple iPad 2, Asus Transformer Prime, etc. It could be a known issue with the particular brand.
Sep 21, 2012 | Polaroid 7-in. Internet Tablet - Other
Postal code.
Their website is set up to accept online registrations from only the US and Canada. You should be able to phone in your registration through their telephone number: 800-231-9786
Jan 07, 2012 | George Foreman Kitchen Appliances - Others
I am looking for the electrial cord for the tefal waffe ane grille appliance
You will be able to locate the nearest authorized parts dealer on your area by visiting
Feb 07, 2011 | Tefal Avant Sandwich and Waffle Maker...
Picture freeze lockup and no sound
It Was Solved by removeing the unit from its present site and retuned unit to winter hill in a good signal area, when unit was returned to original site it was retuned again. and operated ok. as to what was the course i have not a clue, can only think that due to thie site being a fringe signal area may be the transmitter was on reduced power or something?
Apr 10, 2009 | Humax DRT800
Kitchen Appliances - Others Logo
70 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
