Question about Genius PenSketch 9x12 (PENSKETCH9X12)
My Pencil is Borked!
Graphite core is all broken inside - any fix?
    Master:
    Sergeant:
  • 226 Answers
You will just need to buy a new one
Posted on Jul 21, 2009
How to remove lead pencil from the sole
to start with , there is no lead in a pencil
It is graphite
so to remove graphite use a suitable cleaner
Dec 09, 2016 | Cars & Trucks
Tip
Using Pencils for Lubrication
The"lead" in a pencil is graphite. This is commonly used in industry for lubrication in situations where there are high temperatures or pressures or where dirt would stick to oil. Around the home it can be used to lubricate where grease or oil would be messy, e.g.lubricating zips, drawing instruments, sliding surfaces, locks etc.To lubricate a zip simply run the tip up and down the teeth of the open zip.To lubricate a tumbler lock, first break off a lump of lead from a pencil. Push this into the keyhole of the lock. The aim is to crush the lead up into powder in the lock. Push the key into the lock and turn it backwards and forwards. If you meet any resistance just keep sliding the key in and out and backwards and forwards until the lead is broken up. Alternatively run the tip of a pencil backwards and forwards along the teeth on the key.Graphite can also be used for lubrication where a surface can become very hot and where oil would be unsuitable e.g. hinges on stoves, sliding parts. Make some graphite powder by splitting up a pencil using a knife or otherwise and extract the lead. Crush this in the lid of a jar with a blunt object such as the handle of a screwdriver or something similar. The powder can then be shaken into the hinges. If it is mixed with oil, it can be formed into a paste. This can then be worked into the joint or onto the surface to be lubricated.
on Apr 23, 2011 | Watches
My television's makin a sharp buzzing noise and giving me headaches. how can i fix it?
Hello
There is some loose in the ferrite cores of the two transformers inside your TV. Both are working at highe frequencies, so a slight loose between its core will make a buzz sound which is very annoying. One of them is at the power supply section [SMPS transformer] and the other is LOT [Line Output Transformer]. You just open your TV, and switch it on, and listen which one makes noise. Just press its core with any noncudactable material, like a small dry wood piece or so, and see whether the noise stops. This way you can determine the trasformer which has the core loose. After confirming it, switch off the TV, and applay a little super glue or so, fast drying glue, to the cores' joints and press it for a while., and let it dry well before switch on your TV.
Caution:- Never use a pencil for this purpose, as the center core or pencil is made up of graphite, which is an electrically conductive material.
The fault is core loose, and you only look for that. If you need furthermore asistance, feel free to contact me through Fixya. OK.
Dec 10, 2010 | LG Televison & Video
My calculator is running slowly and i reset the ram and it doesn't work. I have to click any button like 10 times to make the calculator show the command. Is there anything i can do to make it work like...
It is possible that there is some foreign substance inside the IO port. Blow some air on it to remove the foreign object. Do not use the tip of a pencil as the lead may break and remain inside the port. This may make things worse as the lead is really graphite (a conductor of electricity).
Apr 27, 2010 | Texas Instruments TI-83 Plus Calculator
Sctratches on 46" lcd tv. Two of which is noticeable in dark scenes.(White lines) How do I fix this?
used thse methods myself
Vaseline Method
  1. Clean the surface of the screen.
  2. Take some Vaseline and fill the scratch with it.
  3. Gently wipe off the excess Vaseline, being careful not to press too deeply so as to leave some inside the scratch.
  4. Voila. This works because the optical density more closely matches the LCD face than air.
Pencil Eraser Method
  1. Find a pencil with a clean, soft eraser. It must have no pencil graphite on it as you won't want to smudge that on your monitor.
  2. Lightly rub the eraser over the scratch or nick on the screen.
  3. Keep rubbing until the scratch completely disappears
Oct 01, 2008 | Televison & Video
Scratched lcd screen - 52inch sony bravia
Vaseline Method
  1. Clean the screen
Neither is a perfect fix but does help alot
LB
Sep 21, 2008 | Televison & Video
Scratches in my LCD Television Screen (sony bravia) How will I fix this?
Easiest solution is the stuff you buy to fix your glasses with (Lens cpr), so long as it's a small scratch. Larger scratches don't try to fix you can damage the screen further.
Other solutions (though I recommend only at your own risk)
Vaseline Method
Keep rubbing until the scratch completely disappears [1].
Sep 02, 2008 | Televison & Video
Remote control
You need to resurface the contacts. Here's how you do it:
First, disassemble the remote. Clean the black foil pads on the circuit board with rubbing alcohol. Now take a #2 pencil and a razor and shave the graphite from the "lead" onto a piece of paper (hold the blade perpendicular to the lead, this results in a finer powder). Now that you have a nice pile of powdered graphite, blot a Q-Tip into it to saturate the cotton with graphite. Rub the graphite onto the little black pads on the rubber button membrane, and be sure to apply more graphite to the Q-Tip every 2 to 3 buttons. Blow off any excess graphite. reassemble remote and test.
Nov 01, 2007 | JVC RV-B90 Boombox
Genius PenSketch 9x12 (PENSKETCH9X12) Logo
105 people viewed this question
Top Genius Computers & Internet Experts
micky dee
Mirca Sekosan
Mirca Sekosan
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
