Question about Food Processors
I have a cusinart food processor, model DLC8. It stopped working. I disassembled and pulled the capacitor(motor start CE 130VAC 150uF). Could you help me to find the replacement part for this?
  • 17,326 Answers
Ebay or mouser dot com
Posted on Dec 16, 2016
Motor humming but drive shaft not moving
I would suspect either the starting capacitor on the motor or worst case the motor itself. The capacitors are a fairly common item to fail while the motors are uncommon. Expect a new motor to be extremely expensive.
Jan 24, 2016 | Magimix 3200 Food Processor
Tip
The cusinart pro classic food processor is not working ?
Try this procedure:-- It usually goes something like this, with minor variations depending on model number:1.Remove the work bowl completely from the base
2.Plug the food processor in and turn it on
3.Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4.Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the work bowl
5.Place the lid on the work bowl with the tab slightly left of the center of the work bowl handle – slide the lid counterclockwise until it won’t slide any more
6.Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7.Slide the lock to the right into the locked position
The food processor should now work.
This will help.Good luck.
on Mar 08, 2010 | Food Processors
Blade of cusinart dlc 7 superpro food processor will not spin when food is in the bowl- works when no food is in it. Is it is the stem? How do I replace it?
It'll probably cost more to fix than replace. If you have a collection of blades, maybe find one in working order on a shopping site and meld the two together. Happy hunting! Happy New Year!!!!
Jan 01, 2015 | Food Processors
How to us cusinart 11 cup food proceessor for chopping. cutting.
You can download the user manual for the DFP-11 from
http://www.cuisinart.com/parts/food_processors/dfp-11.html
Click on the "download user manual" hypertext link on the right under the processor picture. You need to have Adobe Reader loaded to be able to read the manual.
Please rate this solution. Thanks.
Oct 22, 2009 | Cuisinart DFP-11 Deluxe Food Processor
I have used my Kenmore food processor MAYBE 10 times. Yesterday I turned it on, lights came on but the motor just hums. Is my only choice to buy a new one? Because it sure won't be from Sears, if so.
I have the same problem with mine. It is almost certainly the motor start capacitor. I have been looking for a replacement capacitor from an outside source, but so far have had no luck. The capacitor used is an obscure size and model. I have found the manufacturer of the capacitor, but no electronic suppliers carry this brand. It is almost certainly going to be a Sears replacement part item.
Sep 26, 2009 | Kenmore 219103 Food Processor
It will not start no matter how well everything is in place and locked.
I had the same problem until I called Cuisinart. The handle of the bowl needs to face you. Have you tried that as well?
Jul 25, 2009 | Cuisinart DLC-5 Food Processor
I have a cusinart pro classic, went to use it yesterday, filled it and turned in on, got nothing. i tried a different plug and still nothing. it is not even making a sound.
1. Remove the work bowl completely from the base
2. Plug the food processor in and turn it on
3. Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4. Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl
5. Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more
6. Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7. Slide the lock to the right into the locked position
-Tha Mp3 Doctor
Oct 19, 2008 | Cuisinart DLC-10S Pro Classic Food...
I have a very old cuisinart food processor
Unfortunately the CHM models no longer have replacement parts. If the workbowl parts says something like DLC-7 or DLC-10, then you can call Cuisinart and get replacement parts. CHM models would require finding somthing on eBay.
Aug 24, 2008 | Cuisinart DLC-10S Pro Classic Food...
Wont run
If you try the instructions below, and the motor test fails, you can send it in to Cuisinart for a trade-in, but the trade-in will be just as expensive as getting a new food processor (unless your product has an extra-long motor warranty):
You can test the motor by plugging the food processor in, pressing the on switch and using a pen to press the dark grey or black button on top of the base of the food processor. As long as it spins, the motor is definitely good. Next, unplug the food processor. For the food processor to work, you need to have the work bowl, lid, and pusher sleeve all inserted - if one part of the work bowl is not attached, then the food processor will not spin the blade. Once all three pieces have been inserted, plug it in and turn it on. If the blade is still not spinning, then there is a problem with the element that runs from the back of the pusher sleeve down through the work bowl that triggers the motor button. In that event, you can go to Cuisinart's website and order a new bowl, lid, and/or pusher sleeve - if you see any obvious damage to one part, you can order just that one part. If it is not apparent which part is damaged, order the whole work bowl. Make sure you enter your exact model# at Cuisinart's website, because a DLC-7 is not the same as a DLC-7E or 7P, for instance. The work bowl parts are expensive, so I would just write down the part numbers from Cuisinart's website and find them cheaper elsewhere. There is also a video on the website that shows you how to use the food processors - the first part of the video describes work bowl assembly. Once you get this food processor working, it is going to last forever. Have fun!
-Tha Mp3 Doctor
Sep 16, 2006 | Cuisinart DLC-8S Pro Custom Food Processor
Food Processors Logo
65 people viewed this question
Top Food Processors Experts
Ross Keen
Are you a Food Processor Expert? Answer questions, earn points and help others
