Question about Singer Sewing Machines
Singer model 99 has started bunching the thread under the fabric. help
  • Singer Master
  • 11,482 Answers
Usually, this is thread nesting or bird nesting and results from the machine being mis-threaded, the upper tension too loose, OR most likely, the thread is not seated in the tension disk.
Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning--verify the thread path is correct. Set the tension at the midway point between high & low numbers and re-test your machine. Tweak the tension so the upper & bobbin threads meet in the middle of the fabric.
Remember, if the thread issue appears "under" the fabric, it is usually an upper thread problem. If the thread issues appear "on top" of the fabric, it is a bobbin problem.
Posted on Dec 16, 2016
    Top Expert:
  • Singer Master
  • 8,204 Answers
I have a 9020 singer sewing machine I bought without a manual. I can't seem to sew without looping the thread under it. Almost in knots.
Are you saying the upper thread is knotting under the fabric as it stitches? This is bird nesting or thread nesting and is generally caused by mis-threading, the thread not being seated in the tension disk, or the upper tension too loose.
When threading the upper thread, ALWAYS RAISE the presser foot. Verify that the machine is threaded correctly. If one guide is missed, the stitching will go haywire. Start out with the upper tension set around the midway point and then tweak it through test stitching.
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Dec 22, 2016 | Singer Sewing Machines
Singer Q7469 confidence sewing machine
Hey Shari,
When you say, "thread bunches up" does that happen under the needle plate? Or on top of the fabric at the needle? This can be several things like, installing the correct needle for that machine and proper threading.
I might be able to help more if I had more information like make and model machine you are using, and a response to the question above.
Embroidery Services
San Diego, CA
Jul 28, 2016 | Singer Sewing Machines
I need elp with tension on singer cg550
You didn't explain the symptoms. Is the thread bunching, looping, knotting under the fabric? Is the bobbin thread rising to the top of the fabric?
If it is bunching under the fabric, it is probably what is called thread nesting or bird nesting. There are several fixes, sometimes more than one fix is required to resolve the issue.
Be sure to clean under the needle plate, around the bobbin, and the feed dogs. If the machine has instructions for oiling, follow the directions using a fresh, good quality sewing machine oil and apply only 1-2 drops each spot.
Install a brand new needle. Make sure you are using a needle compatible with the thread and fabric being used. All About Needles
Best practice is to use the same thread in both the upper and bobbin. Also, avoid old or bargain bin thread. Spend an extra couple of dollars to reduce frustration and increase success with your machine. If you wish, you may use two different colors of thread to test so you can easily determine what is happening with the tension.
Remove the thread from the machine. RAISE the presser foot and rethread from the beginning--the thread needs to be seated firmly in the tension disk. Verify that the correct thread path is followed (consult the owner's manual).
Set the upper tension to the midway point between high & low numbers (this is the factory standard and is a good place to start, but every machine is different and may need adjustment).
Confirm that the bobbin is installed in the bobbin case (turning the correct direction) and that the bobbin case is threaded properly.
Before beginning to stitch, hand rotate the handwheel one rotation and pull the bobbin thread to the top of the fabric. Then, gently hold the thread tails in the left hand and slowly begin to stitch.
If thread is bunching, looping under the fabric, the upper tension is too loose. Tighten it and retest. On most machines, the lower the tension number, the looser the tension.
If the bobbin thread is rising to the top of the fabric, the upper tension is too tight. Loosen the upper tension and retest.
Keep adjusting and testing until it is where you want it. Generally, tension is correct when both threads (upper & bobbin) meet in the middle of the fabric. FWIW, tension is static and should be tested and readjusted every time a new project is begun. The needle, thread, and fabric will affect the tension, so it is important to get comfortable adjusting the tension.
Also found the following reviews. Appears that some users have had tension issues with their CG550.
Amazon com Customer Reviews Singer CG 550 10 Stitch Commercial Grade...
Mar 17, 2016 | Singer CG550 Mechanical Sewing Machine
Singer 8734 :my thread is bunching up under the fabric. How do I adjust the bobbin?
If the thread is bunching up, it sounds to me like the stitch isn't being formed properly. Nothing to do with the bobbin, more a case of timing.
The spike, or whatever it is on your machine, which is under the needle, must pass through the loop in the thread from the needle at exactly the right time.
When the needle reaches it's lowest point, as it starts to go upwards again,a loop is formed in the thread,next to the needle eye. This loop is what the spike must pass through in order to make the stitch.
May 19, 2014 | Singer Sewing Machines
Bobbin thread is bunching under the fabric what is causing this?
check the needle to see if it's bent
check to make sure the needle & thread are right for the project
some sewing machine bunch under fabric when the top thread come off the thread take up lever
Sep 27, 2010 | Singer Sewing Machines
Top thread bunching under fabric when sewing
tension could be too loose. start with bobbin tension- should allow thread to pass with SLIGHT resistance. then adjust top tension at about 2-3 to start.
Jun 01, 2010 | Singer 8280 Mechanical Sewing Machine
Thread bunches up on Singer HD-110
my wife's hd110 singer machine is not keeping tension. what can I do/ look at to try and help this
Jul 07, 2009 | Singer HD-110 Mechanical Sewing Machine
Thread bunches up under the fabric
For normal everyday fabric, tension should be 3-5.
If it is looping on the bottom, the problem is the threading of the machine. If it loops on the top then the problem is with the bobbin.
Mar 22, 2009 | Singer 3116 Simple
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
