Logic L55 dab 15 radio how do I tune it as do have the manual
LOGIK L55DAB10 INSTRUCTION MANUAL Pdf Download. > Brands > Logik Manuals > Radio > L55DAB10
View and Download Logik L55DAB10 instruction manual online. ... DAB RadioInstruction Manual L55DAB10 L55DAB10_IB_110810_Zell.indd 1 10/08/2011 ...
Dec 16, 2015 | Audio Players & Recorders
Hi.i've lost manual for bush dab alarm clock,cr231 dab can anyone help?
Hi go to the company website and look for downloads click on this and look for your model you should be able to download a copy of the manual from there
Feb 02, 2015 | Audio Players & Recorders
How do I set the fm volume to be the same as dab?
This depends on the Music System. Check the manual, check in settings and see if there is volume normalizer or try keeping the eualizer in defult, or reset the system.
Oct 04, 2014 | Car Audio & Video
Dab signal
I suggest you scout around the neighbours for a DAB you can borrow to test the signal in your usual place. Your own radio could be faulty.
One of my DAB radios worked fine on FM even though one day it just stopped working on DAB for no apparent reason. The board to repair it is priced not to sell...
Sep 17, 2017 | Audio Players & Recorders
Purchased a Gemini 49 DAB (no manual) can you supply one?
Hi there Kenneth,
Here is the direct link to the manual for Gemini 49 DAB.
Please let me know if you are able to open the link above and if it solved your problem. Thank you for using FixYa.
Oct 05, 2010 | Audio Players & Recorders
Need manual for Alba Clock Radio CRDAB301
Sorry m_gerard, I can't help you with the manual.
However here is a partial list of operations for the Abla CRDAB301:
Switch on
  • Press STANDBY
Switch off
  • Press STANDBY
Factory Reset:
  • Switch the radio on;
  • Press and hold MENU for 2 seconds
  • Press SELECT.
Switch between FM and DAB:
  • (radio must be on)
  • Press DAB/FM
Tune & store all DAB stations:
  • Press MENU
  • Press ">" three times (or until display says "Autoscan full")
  • Press SELECT
To listen to another DAB station:
  • Press "<" or ">" until the station name is displayed
  • Press SELECT
Hope that helps!
Apr 20, 2009 | Audio Players & Recorders
Open Questions:
93 people viewed this question
