Question about Diamond Refrigerators
Does ice diamond fridge deforst its self - Diamond Refrigerators
Fridge/freez ,motor fan stopped power going in,lound buzzlike a transformer
manually trun the defort timer clockwise until the unit goes into deforst mode. IT MAY BE THAT THE EVAPORATOR COIL IS FULL WITH ICE.
Jan 31, 2012 | Refrigerators
I own a lg ice beam door cooling fridge for the past five years since recently the fridge is not cooling properly when i open the firdge i see the fan inside the frdige is at standstill pls advice also the...
sounds like u have a deforst problem. if it dont automatical defrost then u have to manually do it then u will have to replace the defrost timer and hope your defrost heaters are still good. ok
Feb 12, 2011 | Refrigerators
Why is the freezer part working and the main fridge part is warm?
hi deforst element or timer may not be working look frost in freezer. i would check timer frist. hope that help
Oct 10, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore side by side, model 105 Freezer is fine, but reefer side doesn't get cool. Any ideas on what may be going on?
Your fridge 100% depends on the freezer. No cold air is going in. It could be a damper, that is located in the left top corner of fridge in the back, that is iced up. Or it could be a deforst system failure and it's has a bunch of ice in the back of the freezer.
Kenmore refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Refrigerators
Kenmore fridge. freezer top works, but bottom doesn't.
Either your fan has stopped working, or it is not defrosting. Take the back panel of the freezer off and see if the evaporator coil is iced over, if it is replace the deforst heater, and the deforst thermostat. If the compressor is running the fan if the freezer should be running. Also make sure both your fridge and freezer controls are centered. Putting the freezer on the coldest setting acutally shuts off airflow to the fridge.
Dec 05, 2009 | Kenmore 71192 / 71194
Freezer works, the refrigerator does not
check out for the refrigerator setting, plz keep the setting in high,, else check your compressor,, thank you plz rate me,,,
Jul 07, 2009 | Frigidaire FRT17G4B Top Freezer...
Not cold enough. ice on back of freezer but not making cubes
sounds like you might have a deforst problem or your drain is blocked not allowing the water to drain when the fridge goes into defrost.
Apr 24, 2009 | Freezers
Red light on Hotpoint Iced Diamond freezer
got a hot point iced diamond fridge/freezer, just got back off hols and red light on, all food defrosted with water running out of bottom. whats wrong?
Aug 27, 2008 | Refrigerators
Refrigerators Logo
26 people viewed this question
Top Diamond Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Diamond Refrigerator Expert? Answer questions, earn points and help others
