Question about Diamond Refrigerators
Does the ice diamond fridge defrost its self - Diamond Refrigerators
  • 833 Answers
SOURCE: Hotpoint Ice diamond fridge freezer both green & red lights on.? takes about two days to fully defrost these units unless you take the freezer section cover off and use a heat source. If you sure to protect yourself against water and electricity mixing....not healthy. See below for another note.
clean the condenser coils below the unit.
check for the amount of gas in the unit. It must be off for half an hour. Remove the back fiber panel. The big thing is the compressor. Clean off the largest pipe coming out of it. Plug the unit out for the fan! The pipe should frost up and then clear off or stay wet after about 5 minutes. It should not be frosty. If it is, you need refrigerant.
Note: If you do remove the inside freezer panel and defrost, you can see how much refrigerant you have in your unit. Start the unit. Wait 5 minutes and observe the coils. They should be evenly frosted end to end. If approximately so, you're good. If not, you're low on gas.
Posted on Dec 18, 2007
  • 111 Answers
SOURCE: my Hot point ice diamond
I don't know this particular frig, but evidently the defroster doesn't work. Frost buildup has blocked the flow of cold air.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
If that doesn't make it defrost, then the problem is probably the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad and is the cause of your defrost problem.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
Hope you can fix it.
Posted on Aug 01, 2008
SOURCE: Hotpoint iced diamond fridge freezer red light
Buy a new fridge
Posted on Sep 22, 2008
  • 1136 Answers
SOURCE: No self defrosting. Ice builds up clogging the
Hi. Are you having frost build up or is the drain icing up?
If it is frost, remove the rear panel inside the freezer and check the defrost heater and the bi-metal switch for continuity. If either switch shows no continuity, replace that switch. The bi-metal switch which is located on the top of the evaporator coil, needs to be tested while it is still cold.
If eithe part shows good, the you will need to replace the defrost timer.
I hope this helps you. Please let me know if I can assist you further.
Posted on Jun 24, 2009
  • 6 Answers
SOURCE: Fridge Freezer ices up
easy....drain hole iced up....when it defrosts it will flood base of freezer....24 hour switched of to defrst it will cure it
Posted on Jul 15, 2009
Just did a defrost due to large build up of ice. I took off the back panel of freezer and found fan was encased in ice.
No this time the fan was the cause of the ice build up and the fridge will be damaged if the fan problem is not resolved. What is the model number of your fridge?
Dec 07, 2015 | Refrigerators
Not cooling in fridge,fridge temperature in freezer
Self defrost mechanism has a problem. Check the defrost timer and defrost heater element for proper operation. Ice buildup is the culprit.
If you unplug and defrost overnight, replug, it will work fine till the ice builds up again.
Nov 26, 2013 | Refrigerators
Refrigerator leaks
If it a frost free fridge it should self defrost every 6 to 8 hours all by its self. If you see ice or frost buildup in side the freezer usually back wall harder to notice if the cooling fins are just under the freezer floor but above the fridge ceiling or better picture it as the fridges taint. Sounds like the fridge is having defrost problems and if it every once in awhile does go into defrost or you do it, all that water flows down a hose and out the back around the compressor. Heat from the compressor or other gadgets evaporate the water. If it only defrost a few times a year it is going to overflow the catch basin. Easy to check some times catch basin or drain hose move check back bottom or remove front cover look if bottom catch basin. Main fault is defrost timer stuck in run, location all over in or out, defrost element around cooling fins,defrost thermostat on cooling fins,wiring to / from / joining the last two.
Mar 17, 2017 | KitchenAid KBRP20ERSS Stainless Steel
I'm really pissed. Ive had my fridge fixed twice and its still doing the same thing. The freezer is not self defrosting and the fridge part is not getting cold. it was fixed profressionly two months...
Either the defrost control is bad or the heater is bad, Only two things that could be happening, ice building up on the evap. coil needs to be removed by defrosts cycles, not happening. Find a better Tech.
Jun 27, 2011 | Refrigerators
Fridge Icing Up
Sounds like you have a defrost Prob. Take back cover off. Turn defrost timer in to defrost mode you will feel a click. timer may be located in fridge. ceiling or back wall if not there check bottom of fridge. behind kick plate or in back bottom of fridge. by compressor. See if heating element gets hot if not check for 120 volts at heater and defrost thermostat ( Terminator ) if not check defrost timer if you do have 120 volts check for 120 volts at heater terminals if no voltage or weak voltage replace terminator if you do have good voltage replace heating element. When ice builds up the fridge. starts to get warm turn off for 24hrs turn back on fridge. will run OK till ice builds back up.
May 22, 2010 | Refrigerators
Jul 15, 2009 | Refrigerators
Freezer switching off on Hotpoint Iced Diamond Fridge Freezer
home refrigerators are not dsigned to work in areas where the temps will drop below about 45 f to my knowledge there is no way to help wiht this problem. Thx peyton
Jan 29, 2009 | Refrigerators
Red light on Hotpoint Iced Diamond freezer
got a hot point iced diamond fridge/freezer, just got back off hols and red light on, all food defrosted with water running out of bottom. whats wrong?
Aug 27, 2008 | Refrigerators
Refrigerators Logo
Top Diamond Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Diamond Refrigerator Expert? Answer questions, earn points and help others
