White Roger thermostat Model# 1F80-261. I set temp for heating at 70 and it reset to 62. Will not stay at set temp?
  • 15,639 Answers
I set my 1F85-0477 thermostat to 80 but the room temp. is staying at 62 , why?
Apparently the heating unit is not working for whatever reason. A thermostat is only a switch, it doesn't provide heat.
Dec 03, 2013 | Emerson 1F85-0477 Thermostat
Fasdfas
Does the furnace stays off?.
Furnace are ment to cycle on and off because of limits .If you set to 70 furnace would cycle several times before reaching that temperature.
Just make sure your filters are clean and you got proper return air flow because lack of air flow will cause furnace to shut off sooner than normal
Jun 08, 2017 | Heating & Cooling
My white-rogers 1F81-261 model thermostat keeps rgoing back to a 62 degree setting after the furnace kicks on at a setting of 72 degrees. I have reset the program, but that doesen't seem to help. What can...
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set to
HEAT or COOL, momentarily press HOLD button. HOLD
will be displayed. Use UP or DOWN to adjust the temperature.
The thermostat will hold the room temperature at the
selected setting until you press RUN button to return to
program operation.
This is on page 6 of the manual
Link: Installation Instruction
Feb 06, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Temp doesn't shut down when preset temp reached. Have to do it myself. Set it for 62 for example, won't come on till I set it to maybe 70. Try to set the temp to maybe 65, doesn't shut down till we...
This is normal. It will only turn on when the temperature set is below the ambient temperature in the area around the thermostat.
Your problem may be the location of the thermostat is not ideal form the areas you are heating. this usually cause the temperature in areas vary from the thermostat to the point wher relocation of the thermostat is sometimes the best resolution.
this is often the case wher ther are multiple heating zines in a building, and one or more zones interfere with the thermostat of others,
but it also happen in single zone heating systems too.
Jan 30, 2010 | DeLonghi DCH4120 SafeHeat Ceramic Compact...
My Honeywell TH4210D1005 Thermostat will not respond
well with 62 outside temp and then maybe a little solar gain and body heat you very well could be 5 degrees warmer then outside
Apr 06, 2009 | Honeywell TH4210D1005 Heater
THERMOSTAT MODEL 1FB82-261 WHEN I TURN THE THERMOSTAT UP TO 70 IT STAYS THERE FOR FEW SECONDS AND THEN REVERTS TO 62 OR 63. I HAVE CHANGED BATTERIES I HAVE ALSO TURNED THE POWER TO THE FURNACE OFF...
Try doing both at the same time - leave it off at least 60 seconds. Also while you have the cover off look fo any buttons (reset). If this does not work you will have to replace the thermostat. (Be sure the power is off to th furnace B4 changing the tstat)
Mar 11, 2009 | White Rodgers Water Heaters
Have gas furnace and this winter,began having
The Thermostat Wizard is an interactive tool that will guide you through wiring and troubleshooting your thermostat, as well as programming it to the most comfortable settings for you and your family. Simply answer the questions from the Thermostat Wizard to correctly connect, troubleshoot and/or program your Honeywell Thermostat. You can even print the instructions and bring them right to the thermostat to help make things easier.
Go to: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Thermostat+Wizard/
However - the problem is probably not with your thermostat but with your furnace. It is most likely a dirty flame sensor - a maintenance issue. If you have not had your furnace serviced recently (more than 1 year) that is where you should start. Modern furnaces require regular maintenance.
Please rate my answer!
Feb 28, 2009 | Honeywell Electronic Programmable...
Thermostat temperatures not reaching preset Energy Star settings
Well with a boiler system like you have it will cost you more money to heat your house that way than if you leave it like it is. With a boiler system it takes a lot longer to heat an area than with a furnace. The best thing you can do is find a happy medium and leave it there at all times. If you read the paper work on your new thermostats they have a set procedure which tells the thermostat if you have forced air or boiler system. Do you have baseboard or in-floor heat how many zones do you have.
Jan 07, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
