Question about Dewalt DW421 5'' orbital sander
I have replaced the brushes, switch and tested the cord yet the sander will not operate, Any suggestions.
  • 97 Answers
Check the comutator (where the brushes contact on the shaft) and make sure it is clean and not shorted
Posted on Jul 26, 2009
How do I troubleshoot why the sander is not turning on? Have replaced switch and opened the sander to check all connections and there is nothing not intact.
Try and test the motor coil if you can to see the motor is intact. If you notice a small circuit board inside, you might as well test its electronic components, e.g. capacitors. You may also test the power cord and the pins to prove they are OK. If these options are exhausted, you can refer to an experienced service tech.
Nov 09, 2015 | Sander Tools & Hardware - Others
My porter cable belt sander 352vs just went dead. I was using it for about 15 minutes and then it died with no warning signs. I subsequently plugged it into a variety of outlets thinking that was the...
Unplug the the sander open the plate to the power cord check for broken wires. Use a Digital Multimeter on the cord to find hidden broken wires in the insulation, if the power cord checks out fine it is in the motor or the switch check the switch and wires with the Digital Multimeter if the switch is fine it is in the motor replace whatever you find that is bad.
Sometimes Harbor freight tools will give away 7 Function Digital Millimeters just for visiting their store check the ad in the link below.
Harbor Freight Tools Quality Tools at Discount Prices Since 1977
Cheers
Billy from Hayward.
Dec 22, 2014 | Sander Tools & Hardware - Others
No powerto sander. Cord is good,switch is good and brushes are long
It sounds to me that you have used the sander a lot and the vibration has broken a wire or it's about to break on the field windings. The brushes you need to look at to see if worn. But I kind of think wire problem. I had this happen on mine and opened it up to find this is what happened. The sander would be turned on and would not operate until I turn upside down and it would work. This is great if you are sanding upside down but this is just a sign that you are on borrowed time as this will eventually not turn on at all. I was able to fix mine with new wire crimp connection and solder with heat shrink material. If not you can order new field winding if this is what is wrong. Cleaning up the sander won't hurt either. You might want to see what a new sander will cost vs. part. Good Luck!
Aug 23, 2012 | Dewalt Sander,random Orbital - DEWALT
My Bosch 1276 DVS belt sander abruptly stopped working. Could it be the switch?
that is possible, but was the tool operating properly first?? unplug tool and check the cord for any breaks, then what I would do is clean the tool as good as possible with compressed air and if you can remove the brush caps do so and check the condition of the spring and clean the area. DO NOT sand the brushes but look across the face to see if both look worn evenly. If you have a volt ohms meter check from the plug to the brush holder with the switch on brushes removed to see if you have continuity and if not then I would have to think the switch
Feb 11, 2011 | Bosch 1276DVS 4" x 24" Dustless Variable...
I have and OLD bench 1
The local hardware store has brushes in all different sizes in a box, next to the switches, fuses, plugs, cords, tool type stuff. They are standard sizes, should be able to find them no problem. Hope this helps.
May 25, 2010 | Campbell Hausfeld Tools & Hardware -...
No power nothing happens
Milwaukee tools have a 5yr warranty, best thing to do is to take it to a service center. It could be anything from the cord to switch, brushes, field coil etc. If it is newer than 5 yrs, thats the best route.
Feb 06, 2010 | Milwaukee 6140 6 4 1/2in. Sander/Grinder
Intermintly will not come on
Take the brushes out, inspect them, and blow out the whole tool with compressed air.
Mar 17, 2009 | Dewalt D26453 3 Amp 5 Inch Variable Speed...
A makita 9227C does not work
Hi, Unfortunately there is no external test, It has to be opened and troubleshot with a multimeter. Especially something with a variable speed controller, power cord, brushes, switches, ect. It could be several things. If you are technical enough to take it apart let us know we will try to help. Good Luck to you!
Feb 20, 2009 | Makita 7" Electronic Sander - Polisher...
CLEANING SANDER BUSHINGS
It's usually not the brushes but the commutator that needs cleaned. The commutator is the surface the brushes ride on. Go to Walgreens and buy a multi-surface nail file, one of the soft ones that are about 3/4" square with different colors for different grits. Don't start at the coarse grit!! Start at the medium grit and lightly drag it over each section in a smooth arcing motion, when the commutator surface is shiny it's clean, then replace the brushes with new ones.
Feb 16, 2009 | Bosch Power Tools Sanders Orbital Sanders
Dewalt DW421 5'' orbital sander Logo
202 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
