Question about Amana Heating & Cooling
I have one Amana PTAC unit PTH153B35AE, its compressor is not turning on?
  • 1,657 Answers
Likely have a bad capacitor. Amps×2650÷volts on the capacitor will give you the microfarads
Posted on Dec 17, 2016
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
Do you have an amana ptac wiring diagrams?
Sounds like you need a new control board.
Sep 03, 2014 | Amana PTC124E50AXXX
Amana ptac- blows same temperature air whether its set at 80 or 65...any ideas?
Check to see if your compressor is running. Thre are 5/16 screws on either side of the unit holding it to the case. Take those out and you can get to the cpmpressor. These are not complicated units but you may have to have a service tech look at it for you. I do sell a lot of these PTAC units so if your compressor is running you have leak or bad compressor. Russ
Jul 23, 2009 | Amana PTH123B25AM Air Conditioner
AMANA PTH153B35AE PTAC Temp drop??
PTAC temp drop should be 20 to 25 degrees across the coil. They never put a service tap on these units. I sell Amana PTACs. You may be alittle low on gas. Check your air TD and that will tell you. The compressor may be overheating due to lack of cool gas to cool the comp. May need a service tech but get a free estimate first. Rus
Jul 04, 2009 | GE Zoneline AZ55H07D Air Conditioner
The unit has quit cooling. The compressor does not seem to be coming on.
check thermostat contacts, possibly not sending signal to pick up
Jun 02, 2009 | Amana PTH153B35AE Air Conditioner
Do you think you have a heat pump outside ?If so then I would call the installer back and show me how to operate the control.They should have did that when it was install.
Apr 06, 2009 | Amana PTC153B50AJ Electric Heat Air...
Amana PTAC
I know this is late but I had to add a solution to this problem since I had the exact same problem and was able to solve it. The probelm is not your control board. On these units, the heat pump compressor will not kick in unless the temperature you set on the control panel is within 2-1/4 degrees (or 4 degrees depending on your unit model. Otherwise, the unit locks out the compressor until the electric heat coil bring the indoor temperature up to that level - and then will switch the compressor back on for heat pump operation. So the problem is not the control panel or the compressor, it the electric heat coil. The coil has two manual limit switches on it that may be tripped and should be checked. The coil can be easily accessed by shutting down the power, removing 4 screws around the air outlet, pushing the screen up and sliding the panel out the top. The power wires can remain in place while the limit switches are reset. Hope it works.
Nov 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
May 02, 2007 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
