Question about Winchester Optics
My dial knob is stuck on my winchester TS-9 - Winchester Optics
    Top Expert:
  • Winchester Master
  • 8,204 Answers
When I push the setting dial down and push the iginator control button the flame starts, and when I release the dial knob the flame goes out and that is on Model # CBN 301 DESA Blue Flame Custom Glow
It sounds like your thermocouple either needs to be cleaned or replaced.
I would start by cleaning the thermocouple first.
Here is a link to the instructions.
Oct 17, 2011 | Desa International Blower Glow Warm Wall...
Is the dial to adjust temp coldest set at low numbers or high number?
The dial inside the fresh food compartment, the bottom compartment
set to middle or above (higher numbers mean colder). Usually 5 to 9 if it has numbers.
Freezer knob in the middle if it has one. (If you set a freezer knob to "colder" it cuts
off the cold air to the lower compartment). Hope this helps
Jun 29, 2011 | Kenmore Top Freezer Refrigerator
Admiral Model AT17M6W - Temp Control Knob Stuck - Now I Broke It?
you will have to take the inside panel off the door to get to the back of the switch..Inspect it closely for sharp edges as all should be smooth on the swtiching mechignism.. if its broken remove the out part of the switch and see if you can turn the temp switch inter control shaft either way...if it keeps spinning then you'll have to replace the entire swtich(ording parts) if it doesnt spinn freely then plut the inner pannel back on but with the swtich house off so the dial rod sticks out...Kind of **** but it would work!!! hope this was helpfull:)
May 19, 2009 | Maytag MZD2766GES Side by Side...
Kenmore Series 90 Washer dial isn't calibrated correctly
push the knob to off and turn knob only to you is in..always unplug unit first
Nov 03, 2008 | Kenmore 15864/15862 Top Load Washer
GE top load Super Capacity 16 cycle washer (one year old)
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing it turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Dec 18, 2007 | GE WBSR3140DW Top Load Washer
Optics Logo
42 people viewed this question
Top Winchester Optics Experts
james laughton
james laughton
Andrew Taylor
Andrew Taylor
Are you a Winchester Optic Expert? Answer questions, earn points and help others
