Question about Exercise & Fitness
Stamina 1399 rowing machine belt want wind back into machine looks like that spring inside snapped into two pieces. Order new spring . Please tell me how to replace old spring and replace with new one
  • 107 Answers
SOURCE: Belt keeps snapping
Check your brush. It is likely that the brush is broken and will not spin. Hold the brush by the end caps and spin the brush and if it will not spin freely that is your issue.
Posted on Dec 18, 2008
  • 2920 Answers
SOURCE: washing machine spring who do i attach it to the drum
if you have a screwdriver you can put in on the drum first the use the screwdriver to pull it up yo hook to the tub like a kind of prybar effect.
Posted on Jan 12, 2009
  • 137 Answers
SOURCE: replace belt kenmore sewing machine
Try this URL:
Posted on Mar 02, 2009
SOURCE: The "spinner, 3rd level wash" kept falling off. Ordered new part, no instructions with it.
I had the same problem, the 3rd level spinner falling off. Without getting into my saga story, save yourself some $$$.
-You will need a screw & washer to replace the plastic thumbtack. The screw will have to be able to screw into the female part of the spinner; the washer will keep the screw from falling out of the hole in the flat hose on the ceiling of the dishwasher.
-If you look closely at the spinner(the part that keeps falling off), you will notice it comes apart. With a flat head screwdriver, separate the 2 parts. (there are 3 parts all together; Keep the round center piece sticking out of the top peice)
--Remove the top drawer of the dishwasher to give you some room to work
-Remove the screw on the "ceiling" of the dishwasher(it is located further back from where the spinner goes) to allow the flat pastic tube to come down low enough for you to get in behind it.(set that screw aside in a safe place; you will put it back later)
-Remove the pastic thumbtack from the hole in the flat plastic tube if it is there & replace with a washer and screw.
-Take the top 2 peices of the spinner, together as assembled & screw the screw into the female portion of the spinner.
-snap on the 3rd piece of the spinner
-replace the screw you took out earlier, securing the flat plastic tube.
-place top drawer
Voila, you are done!! You just saved yourself $20+
Posted on Mar 16, 2009
  • 77 Answers
SOURCE: washing machine spring snapped but how do i attach it to the drum
That's quite tricky one, try make sure that you bought the right one, otherwise find some one to help you holding one side wile you stretch, it is dificult even with lotss experience. good luck
Posted on May 08, 2009
Broken cord
Where can i get a replacement cord belt for the air rower, its frayed and snapped?
Mar 31, 2014 | Fitness Quest Integrity 3000 Air Rower
Need replacement bands for Flex gym LT2000
Sure, you can find them on amazon, take a look here: Amazon com Stamina Bio Flex parts I hope this was helpful. Cheers
Oct 21, 2013 | Stamina Products 2010 Stamina Bio Flex...
Pulley on a rowing machine
return spring broken replace..
very common problem
Jan 15, 2013 | Body Sculpture Rowing Machine - Orange
Sharp r520kst door won't stay shut
If the door will not stay closed it is the spring inside door, or the small plastic piece that holds the spring which is attached to the $80.00 piece called outer door.
To fix it, it is EASY and you do not have to even take the inside cover all the way off. Just remove the three sides of cover by gently slipping a plastic putty knife around rim to release the clips. Then attach the spring to the small hole below where the plastic piece used to be, which is located in the metal on the glass frame piece, use tweezers, hold the other end of spring as you place spring onto plastic door latch and set into place!
Snap the inside cover back on and YAY! FINI!
Aug 20, 2012 | Sharp Microwave Ovens
When turning the crank, the spring slips, and the crank flies back to original position. Spring will not wind up.
One day while cranking the freeplay PLUS Radio on a job site with no power, something inside snapped, and made a horrid grinding noise. All of my co - workers laughed. From then on I only used the radio with the AC plug in adapter.
After 8 years of keeping the freeplay plugged in to listen to it I finally decided to open it up and take a look.
Low, and behold I found some broken pieces that looked like a belt. HMMM?
After a little more investigating I found the 2 drive wheels that power the generator... with no belt on them. I looked in my junk drawer, and found a small blue rubber band amongst the others that I save from packaging items. It looked suitable to do the task. After stretching it around the generator drive wheels, I cranked it up, and IT WORKED!
I'm still waiting to see how long this fix works, but in a pinch... keep some rubber bands and a phillips head screwdriver around. This may be the same problem your having. I'm now getting the long lost last laugh.
Hope this helps! KMT
Feb 19, 2011 | Freeplay Energy BayGen AM/FM/SW Radio
Kettler Model Kinetic S3 Rowing Machine rope snap want spare rope
KETTLER® USA 1355 London Bridge Rd Virginia Beach, VA 23453 USA
Phone # 757.427.2400 Fax# 757.427.0183
Feb 15, 2010 | Kettler Rowing Machine Kadett Rowing...
Stamina 1205 Rowing Machine
mine did this as well--turn the shock 180 degrees so the sticker is down and the caution sticker--this fixed mine. The shock is probably slightly off from the factory and is in a bind the other way. Hope this fixes the problem for others.
Feb 03, 2009 | Life Fitness Stamina 1205 Precision Rower
Exercise & Fitness Logo
97 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
