I picked up a CV LW15, it's missing the amp & connection plate. Can I direct wire the subwoofer to the receivers sub out?-or do I need to buy a LW15 amp? Also is that woofer 8Ohm.ThankU4Ur time!?????
    Top Expert:
  • Audio Player... Master
  • 45,079 Answers
The sub out of the receiver is intended to feed the input of a powered sub. Direct wiring will not work.
Posted on Dec 16, 2016
SOURCE: AVR 810 Denon Receiver Sub Woofer Hookup?
Denon AVR-810 was a quite out-dated model. I had owned since 1992. It shown 'Protection' on the screen for 2 months ago and not yet been fixed. Better to replace a modern one or repair it at a reasonable costs.
Posted on Jan 04, 2008
  • 4234 Answers
SOURCE: Amatuer needs sub-woofer advice for Pioneer VSX-454...
Based upon your description, the subwoofer is just a speaker and is taken from the normal speaker outputs. Run your A channel to the sub and then from the sub to the left and right front speakers. That should do it.
Dan
Posted on Apr 08, 2008
  • 236 Answers
SOURCE: Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Posted on May 03, 2008
tech48
  • 624 Answers
SOURCE: Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Posted on Feb 06, 2009
SOURCE: I have a teac AG
I have the same-just talked to TEAC last week, if fuses(two 5 amp glass ones inside housing-just remove screws on back after un-plugging 120v power) on the LSR-1008 subwoofer are blown, it may be failed relays. I replaced my fuses, both blew w/in 5 seconds. Called TEAC today, relays are NOT available alone and are solder connected; however, complete new circuit board is plug in, part #APE000515-0001 at $47.69 plus shipping. Verify #s and price with TEAC, but now I must decide if it's important to keep this sub, or if another at around 60$ on Ebay is a better bet. Good luck!
Posted on Apr 16, 2009
Connecting a passive subwoofer to a denon 2113
you need another reciever/amp to power that sub, because that denon reciever is designed for a powered sub,. if you have another old reciever/amp laying around, you can connect the sub out from the denon into an auxillary input of any old reciever/amp, (switched to that input) with speaker wires from old reciever/amp to the passive sub
Mar 05, 2013 | Denon Avr-2113ci 7.1-channel Home Theater...
I have a 15 inch front firing CV 15 inch home theater sub with connections for multiple more speakers. When I connect speakers to them nothing happens.
Be sure that the connection on the back are indeed outputs. Many manuf. set up what looks like speaker connections but in reality these are high level inputs to the sub. THE GREAT OZ.
Aug 15, 2011 | Cerwin Vega LW15 Subwoofer
I have a Niles SW300 subwoofer that continues to blow fuses. I have replaced the fuse, but when it the power is plugged back in the fuse immediately blows.
ok, temporary cheap fix... (i mean in a ******* engineering kinda way ;-) . . . )
since your primary receiver has a sub-out RCA plug, you can hop into the local pawn shop, buy a cheap receiver and an RCA line splitter, and connect the primary sub-out to the CD or any input EXCEPT phono (resistance is different on the phono rca's). remove the plate from the sub and run the speaker wire from the "pawn stereo" directly to the speaker. replace plate on sub to keep box sealed, and adjust receivers to desired level of bass & volume.
You have spent $50 and now have a decent sounding system again.
Mar 27, 2011 | Audio Players & Recorders
When I hook up the speakers in the back to the left and right side for the in and out, do I connect the front or rear speakers. do the speakers connect to the subwoofer first then to my receiver or the...
I was trying to find an owner's manual or picture of the rear panel of the sub, but had no luck. The subwoofer is a powered type - or "active" speaker. This means it has a built in amplifier. These active subs usually provide for one or both "low level" and "high level" inputs. Low level signals are usually carried by shielded coaxial cables and have RCA type plugs on the end. The low level is also called "line level". This is an un-amplified signal that might be heard on cheap earphones - but that's about it. It is similar to the output of a tape deck, DVD or phonograph. These signals require an amplifier to be heard. If you have a sub woofer output on your receiver or amplifier, you could run a patch cable between the low level input on the subwoofer and the subwoofer output of the amp or receiver. You receiver or amp may call this output "low frequency effects" or similar. The front and rear speakers would then connect directly to the receiver or amp's corresponding connections.
If you lack low level outputs on the amp or subwoofer, you'll need to run speaker wires from the amplifier or receiver's front left and right speaker output terminals to the subwoofer's high level input terminals. High level signals are speaker connections or amplified signals. These are typically connections that accept bare wire connections. The front speakers would then connect to the subwoofer's front left and right speaker output terminals. The rear speakers connect to the amplifier.
I hope this helps - and good luck!
Nov 24, 2010 | Cerwin Vega AVS-632 System
Hi, I have the Kenwood Subwoofer KS-201-HT, my question is how do I connect it to my receiver?
usually subs have outputs 4 ur monitors however if ur sub is active @ ur monitors are passive then you need 2 connect sub 2 ur tape loop with rca connections,usually you use the send signal from ur reciever which would norm connect to ur tape input , if the sub is passive then u connect direct to speaker output on amp then monitors to the sat connections on sub
Oct 12, 2010 | Kenwood SW36HT Subwoofer
Subwoofer with speaker wire?
Back in the old days, subwoofers were powered by the voltage from your receiver, through speaker wire.
Nowadays, subwoofers have their own power, hence not having speaker wire connections anymore.
It's unlikely that you'll be able to connect your old subwoofer to your new receiver.
You'd need to get a new one, which if you don't mind buying closeout, can be found on eBay pretty cheap.
Mar 16, 2009 | Sony DAV-DX255 System
How to connect Jensen subwoofer CS10 to Yamaha Receiver HTR5660
Does the yamaha have a subwoofer line out RCA type jack? Most receivers with 5.1 output will. Just insert a male rca to male rca patch cable from the receiver to the line in on the subwoofer,( not the speaker wire inputs) Plate on the sub may say low level input, and setup the receiver menu option for SUB? yes/ no to yes, this will direct the low frequencies to the subwoofer.
Jan 25, 2009 | Jensen CS10 Speaker
Jan 02, 2009 | Audio Players & Recorders
Subwoofer to receiver hookup
In general, there are two ways to hook up your sub-woofer. First using the high level outputs from your receiver ( speaker output from the front R & L speaker terminals ) run a set of wires from the outputs to the speaker inputs on the sub-woofer, you do this in concert with the speaker wires going to the front R & L speakers which you then attach to the R & L speaker outputs on the sub woofer amp. Note that the sub woofer doesn't power your front speakers, the connections from the sub amp are just a pass through connection where the signal needed by the sub is parasitically taken from the inputs.
Second is via a low level output from your receiver / amp to the low level input on your sub amp. This is normally done via a RCA type of patch cable and connected to the sub woofer RCA jack on the rear of the source receiver or amp, Next run the patch cord to the sub amp an into the RCA jack input. IF you have a right and left input, use the Right input.
john
Aug 18, 2008 | Audio Players & Recorders
Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Oct 30, 2007 | Audio Players & Recorders
 Grubhead
Grubhead
