Question about GE Kitchen Ranges
The lower heating element of my GE Range (JBP78W) is not heating. Basic continuity-check shows a complete circuit. The broiler is OK Can I swap the two elements to see if it's a control circuit issue?
5 Suggested Answers
  • 343 Answers
SOURCE: I'm having trouble with the lower heating element
Most of the time it the heating element.
(recheck your model number)
Here is a good source for replacement part
Or directly to GE
Posted on Dec 24, 2009
  • 310 Answers
SOURCE: Broiler will not work. Broiler Switch indicator
Three possibilities:
1. Bad Broil element.
2. Wiring problem to broil element.
3. Electronic controller failure (this can be repaired).
Posted on Feb 21, 2010
  • 8220 Answers
SOURCE: RF302BXP Whirlpool range. Lower/baking
This vid shows how to check an electric oven with electronic range control:
Posted on Sep 13, 2011
Mike 11_99
  • 94 Answers
SOURCE: Kitchen range Kenmore 790.46994 Everything including Broiler element works great but lower oven heat element does not get hot?
Does the continuity test show ANY resistance at all?????? If not, the element is bad.
Posted on Mar 03, 2015
Broiler will not work on a whirlpool range rf367lxsyo
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
Apr 17, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Does the element pass the short test? Check between the element leads and anywhere on the element except the other lead. If you get a circuit, its shorted. When you say power to element OK, are you getting 220Vac? If yes its OK, if not, its not OK.
Mar 02, 2015 | Kenmore Dryers
Why doesn't GE JBP24 preheat?
Not familiar with this exact range, but it could be a couple of things.
If the broiler (upper) element heats properly and the baking (lower) element works properly, then the issue is probably in the controller/preheat switch.
If the broiler doesn't heat up, then the upper heating element.may need to be replaced.
Jun 15, 2014 | GE JBP24 QuickClean Electric Kitchen Range
GE standing electric oven range. Oven lower element will not heat up.. only gets Luke warm, can still touch it, although the upper oven element gets very hot. What could the issue be?
Sounds like the bake element - do a visual check and look for blistering or cracking. If it looks normal, unplug the oven (or flip breaker for wall oven) and then you can remove the screw holding the element and pull it forward enough to unplug it and do a continuity test with a multimeter. If it test bad, replace the element.
Apr 09, 2014 | GE Kitchen Ranges
Kenmore 790 oven won't heat after self clean
Did you fully disconnect the wires when you checked continuity? If not you are checking continuity in the whole circuit. For what its worth, the self clean feature superheats the oven and often burns out elements. We see it all the time. It is one feature to never use!
The broiler element is not part of the oven temperature, it is a broiler. The oven works on the bottom element alone. If it only gets to 300'F, wither the bottom element is faulty or the thermostat is failing. As I mentioned self clean is a great way to cause problems.
Nov 16, 2017 | Kitchen Ranges
GE XL44 Oven and stovetop work - broiler does not work
The broiler is the top element in the oven. Look at it. Bad ones sometimes have burnt into or have a melted spot. If it looks ok take it out by removing the screws at the back and pull the wires out a little and unplug the element. With an ohm meter it should show continuity. Replace it if any of these things apply.
Feb 04, 2010 | GE Kitchen Ranges
I'm having trouble with the lower heating element not heating on my GE Electric Range. Its probably 10 + years old. The broiler element heats. Will I be able to replace the element or circuit board? ...
Or directly to GE
Dec 24, 2009 | General Electric Stove/Oven/Range Chrome...
Kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
Oct 25, 2009 | Kenmore 30169 Electric Single Oven
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
