Laars Neotherm 80,000 BTU gas boiler-loud humming noise after prepurge on startup.Hum goes away after 15-20 seconds.Humming only happens when the temp outside is very cold.
  • Heating & Co... Master
  • 3,150 Answers
Is it the gas meter outside making a noise on a cold day .
Posted on Dec 17, 2016
Testimonial: "Gas meter is quiet and the hum noise is emanating from the gas valve / venturi unit. Thanx for your rely"
  • 2 more comments
  • Paul Carew Dec 18, 2016
    Do you mean the burner is humming ? If so you could clean them out with air line or shop vac ,
  • Anonymous Dec 18, 2016
    Gas valve/venturi is humming Possible adjustment
    Not sure on what you are calling gas valve venturi
    follow this link thanx again.
My 2001 chevy malibu had been working fine up until this afternoon it turns but wont start,itmakes ahumming noise even when i turnoff key.
That humming noise may be your fuel pump burning out. Try turning the key to the on position while someone else listens near the gas tank. The humming should only hum for a few seconds so you won't have time to listen yourself unless you can hear it from inside. If the hum continues and doesnt shut off, it is likely a bad fuel pump. It is normal to hear a small hum for a couple of seconds , but when it starts getting weak, it will hum louder, longer, or not at all
May 11, 2015 | 2001 Chevrolet Malibu
Our gas oven has not worked in over a year. The electric panel was malfunctioning. The burners work fine. We just had some work done and had to turn off the radiators and manually fill the boiler an
The hum may be a b ad regulator in the stove. Pull stove out and see if regulator is humming. It's where the gas line connects to stove.
Maybe the power was interupted to the stove which may have reset power to control board.
Oct 22, 2014 | Kitchen Ranges
My GDM-12 is not cooling. when I turn the temp up it make a loud humming sound.
If the humming last 3-5 seconds then makes a faint click sound and stops humming for a minute or two. Then resumes the hum again it may be your compressor locked down. Stuck. Most likely it is just a bad start capacitor not kick starting the compressor. A $6 part.
Mar 07, 2014 | True GDM-12 Refrigerator Commercial
Could do with a service.
Check the turntable motor and drive plus check the cartridge and signal wiring.
Sep 14, 2017 | Wurlitzer Jukebox CD Player
I have a pair of JM lab Electra 905 speakers, running through a DNM amp and power amps. When powered up, the left speaker makes a very loud humming noise. This has happened recently. I haven't changed...
Switch on your amp, keep its volue down to extreme low, and listen if there is still hum through the left channel or not. If still there is hum, the left side power amplifier section inside the amp;ifier is faulty. If htere is no hum at this state, hum enters thorugh the audio input terminal, and the input wires must be checked for open sheild connection. OK.
Apr 10, 2011 | Jmlab Electra 905 Speaker
My new Laars JVS 225 boiler make a whining noise when heating up. It does it on all zones. This was a replacement for a Teledyne Larrs that had a leak but ran quiet. IPressure is 15 lbs and temp is 155...
My new Laars NeoTherm boiler (NTH150) was making a whining noise soon after install. The noise was audible through most of the home. Replacing the air/gas blower solved the problem. Correct sizing of pumps is also important to reduce (water-flow related) noise. Having done all that my Laars boiler still isn't particularly quiet in its start-up and (modulating) operation. It should NOT be located below or next to a bedroom.
Nov 19, 2010 | Heating & Cooling
Our neighbor's pool heater/pump produces a constant humming/droning noise. There is a fence between us. Is there a sound barrier I could install?
I am experiencing the same thing. My neighbor has a 400,000BTU Hayward heater that's on a timer and everyday I hear it kick-on and in the evenings as well. The humming is inescapable in my unit.
Unfortunately, I'm going to have to move. I cannot stand it. Fortunately, I'm renting and this hastened my search for a home purchase. I talked to the neighbor's pool tech "The Pool Doctor" and he confirmed that the noise is something that you have to live with as he said that he was not allowed to reduce the pressure of the heater, which might reduce the humming and noise.
Nov 09, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a TYPE JV Gas Fired Mini-Thermal Hydronic Boiler supporting 2 zones in my home. It has run perfect for the first 13 yrs. For the past 3 yrs there is a loud HUMMING which occurs only when the upper...
Lower pump connector going bad? Air in the system? Do you have valves that may be partly open and stuck? When the noise is occuring, go through the system as much as you can get to. See if you can find the source by hearing it get louder or by you touching here or there. It sounds as though it is mechanical but may be as simple as a valve in need of attention. Food luck and please let me know if you find it...Lee
Loud humming noise when dishwasher is filling with water
sounds like it could be furring in your water piping. may need a plumber to check it out.
Mar 16, 2009 | Dishwashers
Loud humming noise when in use
We had this problem with a new GE microwave in our last home. GE service replaced fan assy,.AND added rubber foam around the motor, Loud hum was reduced,but never did completely go away. We learned to live with it/
May 31, 2007 | GE JE1640 Microwave Oven
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
