Question about Dryers
It is completely dead, I have checked breaker and plug point, no problem. what can be the problem.
    Top Expert:
  • 8,376 Answers
You might have already tried this but have you check the fuse in the plug it might have blown.
i am in the uk so i might off got it wrong.
Posted on Dec 16, 2016
If there is no power for either the washer or dryer, is there an internal fuse or reset button
I assume you checked the circuit breaker for this outlet? Both appliances are plugged into the same outlet? I would try unplugging both appliances then attempt to reset the breaker again....throw it completely to the OFF position, wait 10 seconds and throw it to the ON position. At this point we are assuming the breaker is working. It could actually be defective. It could be tested with a meter or test light. If you don't have that try plugging a lamp or another device into the outlet the appliances where plugged into. If it works you know your breaker, wiring, and outlet work. If not you need to troubleshoot that...perhaps a ground fault breaker somewhere in between? If the outlet works with the test lamp, next plug in one appliance at a time to try to determine which pops your breaker.
Feb 06, 2015 | Dryers
No power on Cyclone 4100
Do you have power at the outlet where the unit is plugged in? If not restore power to that point. Next, check the main breaker to determine if it has tripped. It may look like it is on but to verify, turn it off and then back on. It should click into place. If that does not work and your trailer has a genset with a transfer switch. Check the transfer switch to make sure that it has not failed. It may be locked into the genset side and not switching back to shore power. If you are running the genset and do not have power make sure the breakers on the front of the genset are on.
Mar 02, 2014 | Heartland 2012 Cyclone 4100 KING
It is power on but doesn't start
1. wont start fillin and spinnin or just dead no indicator at all?
1a - no indicator
- check if the plug point have power - any tripped breakers
1b - no fill
- check if your water inlet valve is opened
no spin
call service
Oct 16, 2013 | Fisher Paykel EcoSmart GWL15
Dead Dirt Devil Featherlite
1. Power cord not firmly plugged into
outlet.
1. Plug unit in firmly.
2. Blown fuse or tripped breaker. 2. Check fuse or breaker in home. Replace fuse/
reset breaker.
3. Needs service. 3. Take to service center or call 1-800-321-1134.
4. Thermal Protector activated.
4. Unplug cleaner. Allow to cool for 30 minutes
Nov 03, 2012 | Dirt Devil Featherlite Bagless Vacuum...
Microwave stopped working
The main fuse in the microwave is probably open, causes are! door switch, magnetron, inverter board, "if 7 years old or less" and possibly the keypad control board. I recommend having it checked out.
May 08, 2012 | Samsung Microwave Ovens
I have a 8 hp Briggs with electric start.Battery is dead it also has pull start. Hasn't been started in a while cannot get fire from plug.Not sure what to try next.
1 - a bit obvious, but make sure you have the switch turned to on
2- replace the plug
3- If there is still no spark the magento coil may be expended and require replacemt - check to see that the
wire from the plug to the magento coil is not earthed / grounded
Dec 16, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
We had a power outage and now our Maytage Gemeni stove won't go back on. Can't test the outlet, of course, since it's that weird huge plug, but all the other electricity is fine. The oven is completely...
Hi!!
Check breaker box for a tripped Double Breaker, probably 30A, If breakers are OK, unplug unit from wall outlet and wait 15 min. to reset the control board, plug unit it back up and check Range. You can check for power at the outlet using a voltmeter set on the AC mode.
Keep me posted!!
Dec 04, 2010 | Maytag MER5550 Electric Kitchen Range
Settings for points for 454 engine86 chev c30 scotsdale one ton truck
You have a 1986 454 engine with an old style breaker point ignition distributor, GM has not used a breaker point ignition for their V-8 engines since 1974, is that an older distributor or something after-market?
The ignition points dwell angle for that engine should be set at 29-31 degrees dwell (a dwell meter would be the most accurate way to set the ignition points), or a .019 in. point gap.
The spark plug gap for that engine would be .035 in. and the timing should be set at 10 degrees before top dead center.
Jun 29, 2010 | 1986 Chevrolet Chevy
We have a JVM1870SF02 Microwave Oven. Everything
Is it on a gfci plug? If it is reset that. If not I would recheck the circuit breaker again
Sep 23, 2017 | GE Microwave Ovens
Unit/control panel completely dead
Check your circuit breaker, "off" and "on" the breaker it my be tripped off. If it wont work may be some fuse blown in the control, or the control itself may be defective.
Jan 28, 2008 | Carrier 38CKC042 Air Conditioner
Dryers Logo
Top Dryers Experts
