Question about Sceptre Televison & Video
My Sceptre TV randomly changes input sources - Sceptre Televison & Video
SOURCE: Protron 32 inch HDTV
I have the same problem as above - any response?
Posted on Sep 19, 2007
  • 186 Answers
SOURCE: input source change on remote for tv
Are there not enough ports? You can buy port splitters to add more connections to your tv. Also, some surround sound receivers have port switchers too.
Posted on Apr 26, 2008
  • 56 Answers
SOURCE: mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Posted on Nov 20, 2008
  • 74999 Answers
SOURCE: Sceptre LCD--Input not functioning. Audio but no video when using inputs. TV antenna has video and audio.
Check the connecting cables for break. Check proper input selection.
Posted on Jun 05, 2012
  • 229 Answers
SOURCE: sharp tv keeps changing the source channel on its own
you may fave a faulty switch in the key controller, may best advice is replace it
Part numbers:
Posted on Jun 18, 2012
Have a Sceptre 32" TV that changes sources all by itself, how do I fix it?
Model Number?
It may have a setting to automatically switch to a new source. Check and see if that is off. Also, power down your other connected devices completely, as some will occasionally "ping" the TV to make it's still connected while in sleep/idle mode. The Nintendo Switch is especially bad at that.
Jun 18, 2017 | Sceptre Televison & Video
How do i get my nintendo wii console to appear on the tv screen ive tried every channel and hdmi and such and nothing i know its on and working cause i feel the wii remote vibrate just nothing shows o
Kate what did you plug the cables into I suspect it was a grey cable with a red , white and yellow plugs. If I am correct this cable should be plugged into the AV1 or AV2 input port of your television. Try changing the input source to AV1 or AV2 Check it is plugged to AV1 on the Television and not into Conponent input !
Jan 02, 2015 | Sceptre X32BV-Naga 32 in. LCD TV
I have a Sharp LCD that keeps changing inputs and will randomly turn itself on.
Sounds like you have another infared source that the LCD is seeing. Put opaque tape over the infared receiver and see if the issue continues. Look for another IR device in the area.
Nov 09, 2014 | Sharp Televison & Video
i have a sceptre Lcd tv model x40 the red light is on but when you push the power button it will not come on
Dec 31, 2013 | Sceptre X405BV-FHD3 40 in. LCD HDTV
Random channel changing on 40"sceptre flat screen
button might be depressed. check that's not the case
Aug 18, 2013 | Televison & Video
Scepter flat screen input problem
It sounds that the input signal selection IC is faulty. This IC is at the main board, and will be very difficult to replace to an inexperienced person. Contact any service technician.
Jun 24, 2013 | Sceptre Televison & Video
Sceptre TV unexpectedly changes input source away from HDMI
My sceptre tv just started randomly changing through input modes, sometimes once or twice before stopping and sometimes it continues
Jun 30, 2012 | Sceptre X405BV-FHD3 40 in. LCD HDTV
I have a flat tv sceptre brand. how do you connet the nintedo wii to the tv and what channel to put? i don't have sound and video. thank you
Use the Yellow/Red/White cable of the Wii and connect to the Video in on the back or left side of the TV, matching the colors. Turn on the Wii. On the remote or the right side of the screen press the "Source" button until you get to that input. Use the same source button to get back to TV.
Apr 19, 2011 | Sceptre X46BV TV
May 29, 2007 | Protron PLTV-37 37 in. LCD Television
Televison & Video Logo
Top Sceptre Televison & Video Experts
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
