I have a paper jam and can not get the paper out.any sugestions
    Top Expert:
  • Office Equip... Master
  • 8,213 Answers
Printer give a paper jam error when there is no paper in the machine
Hi, thank you all for your replies & sugestions. I think I've tried everything now apart from talking to Kodac and cleaning the paper sensor. Where do I look for the sensor ?. I've had the top cover off & can't see anything.
Many thanks.
Steve
Mar 27, 2016 | Kodak ESP 5250 All-in-One Printer
When I go to print Avery labels 5160 i get the error code load ssf 024-0969. I can print all other documents
Hi, Brad;
the label with the adhesive on the back when it go through the heating unit it goint melt will coming off and stick on paper path it cause paper jam, sugest print label use inkjet printer.
Oct 31, 2013 | Dell 2155cn and 2155cdn Color Laser...
Im getting plain paper jam at the fuser... I work for a large Hospital , and at this locations we have about about 100 pirnters they all are lexmark T642 and 50% of them have 3 to 4 tray and labels and...
You can replace those rollers. They wear smooth very quickly. In a pinch you can also peel them off the hub and put them on inside out. It will give it traction. It sounds like you already know about the little sensor in the trays themselves. I've seen them pop out of position and cause those probs. I don't think they could have made those sensors any cheaper if they had tried!
Apr 08, 2009 | Lexmark T642 Laser Printer
Royal orca wont forward will reverse shredd.
May have paper bits jammed above fixed curved metal surface that spiral cutter slices against.  Need to spend time removing built up material with stiff wire or flat tool.
May 04, 2008 | Office Equipment & Supplies
Paper Jam HP LaserJet 1020
Papper never realy "jams" the problene is usualy that the paper is late reaching the next paper sensor. What i would sugest is that you clean the paper pickup roller it is usualy in the shape of a D. Clean it with dishwassing soap dont use water just clean soap rub it on with a clean cloth until the roller is dry so use a small amount. This should solve your prbleme.
Apr 23, 2008 | HP LaserJet 1020 Printer
Paper jam!!!
hi,
please follow the link below to find and open rear access door and to clear the paper jam...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00652863&lc=en&cc=us&lang=en&rule=417&dlc=en&product=1146331
once after opening the rear access door proceed as i b4...
thanks and regards
agnel
Mar 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
Ricoh Aficio AP2000 Laser paper jam
Found solution myself.. The paper sensor arm with flag and sensor was missing from the exit side located on the fuser assembly.. Customer apparently broke off prior to calling for us to repair. Solution-replaced fuser assembly clean and tested works great
Jan 30, 2008 | Ricoh Aficio AP2000 Laser Printer
Carriage Jam error always - how do I fix it?
Try resetting the printer (pressing the cancel button and connecting the power supply, check in the HP website if this is correct for your printer model) , after the reset the printer will clear any errors and will recalibrate the mechanism including the paper feed mechanism and the carriage.
Also check if the carriage is moving freely by disconnecting the power and moving it by hand.
Jan 21, 2008 | HP Photosmart 2710 All-In-One InkJet...
Paper Jam
The problem is that after the cover sensor clip is replaced, the logic that tells the printer to feed the paper just to the beginning of the input roller is corrupted. The feeder roller (grey one at the paper feed) rolls to feed the paper and once the paper get to the input roller, another switch detect the paper, that tells the logic to change the direction of the input roller to feed the paper to the cartrige.
There's should be a way to reset the logic part of the printer to get it working right. Maybe pushing a combination of the front panel buttons.
Try playing with the power/green or power/"X" while unplug and plug the power cord.
Good Luck!!! email me with more sugestions/ideas... jmjc_65 at hotmail...
Jan 15, 2008 | Lexmark X3470 All-In-One InkJet Printer
24 people viewed this question
k24674
jasbo
jasbo
