Question about Cell Phones
Code 71 n 084m repair - Cell Phones
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
I bought $89 office 365 from Dick Smith. How can I install with that? Ellie
Common causes for error code
  1. Antivirus software or firewall might be blocking the Office installation and causing error code
  2. Internet connection or proxy settings are preventing from installing Office results in error code
  3. Pre-existing version of an Office suite is blocking the installation resulting in error code
  4. Incomplete\partial\failed repair\installation\change\removal of a previous Office suite can prevent from installing a newer version can cause the error code
Follow the below steps to troubleshoot the error code
1 - Repair your Office app to fix the error code
error code will be fixed when Office repair tool replaces all the corrupted system files. Follow the steps below to run repair tool to fix the error code
  1. Open Control Panel using Start.
  1. Click on Programs and select Programs and Features.
  2. Click on the Office product that you want to repair.
  3. Click Change.
  4. Select Quick Repair and click on Repair. If Quick Repair didn't fix the error code, select Online Repair and click on Repair.
Note: If Office Repair did not fix the error code, remove and reinstall the Office Suite to fix the error code.
https://answers.microsoft.com/en-us/msoffice
http://microsoftsupport.cc/
Feb 02, 2016 | Microsoft Office 365 Personal 1yr...
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Fh error code wirpool duet washer
    Display shows F20 or FH - Front-load washer ' Whirlpool ...
    https://www.whirlpool.com/...fh-front-load-...
    Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
    whirlpool duet error code FH - Appliance Repair Forum
    forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
    Jan 5, 2009 - 10 posts - ‎1 author
    ... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
    1 post
    Dec 5, 2014
    Whirlpool Duet Washer HF Error Code
    Jun 10, 2013
    FH Error Code on Whirlpool Duet Washer
    Mar 11, 2013
    FH error code
    Sep 13, 2008
    More results from forum.appliancepartspros.com
    Stumped on error code FH for Whirlpool Duet front load washer .
    Jan 08, 2016 | Washing Machines
    The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
    LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
    Select
    Use our model number finder
    Choose your product type
    Common model number plates
    Close
    LG Refrigerator Error Codes
    These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
    Er FS Error Code
    Er rS Error Code
    F dS Error Code
    r dS Error Code
    Er HS Error Code
    Er IS Error Code
    Er SS Error Code
    Er rt Error Code
    Er It Error Code
    Er gF Error Code Error Code
    r dH Error Code
    Er IF Error Code
    Er FF Error Code
    Er CF Condition
    Condenser fan motor is defective Check/Repair
    Condenser fan motor, wiring or the control board Shop Parts
    Condenser fan motor, Power control board, Wiring harness Error Code
    Er CO Condition
    Communication error Check/Repair
    Communication error between main board and display board Shop Parts
    Display control board, Power control board, Wiring harness
    Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
    How do ya fix codes p0320&p0340
    Ford Crown Victoria, Mercury Grand Marquis, Marauder, Lincoln Town Car 1999-2005
    4.6L V8 - Auto 2
    Print
    Trouble Code: P0201
    Cylinder 1 Injector Circuit Malfunction
    Possible Causes:
    Injector 1 connector is damaged, open or shortedInjector 1 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
    Trouble Code: P0202
    Cylinder 2 Injector Circuit Malfunction
    Possible Causes:
    Injector 2 connector is damaged, open or shortedInjector 2 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
    Trouble Code: P0203
    Cylinder 3 Injector Circuit Malfunction
    Possible Causes:
    Injector 3 connector is damaged, open or shortedInjector 3 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
    Trouble Code: P0204
    Cylinder 4 Injector Circuit Malfunction
    Possible Causes:
    Injector 4 connector is damaged, open or shortedInjector 4 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
    Trouble Code: P0205
    Cylinder 5 Injector Circuit Malfunction
    Possible Causes:
    Injector 5 connector is damaged, open or shortedInjector 5 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
    Trouble Code: P0206
    Cylinder 6 Injector Circuit Malfunction
    Possible Causes:
    Injector 6 connector is damaged, open or shortedInjector 6 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
    Trouble Code: P0207
    Cylinder 7 Injector Circuit Malfunction
    Possible Causes:
    Injector 7 connector is damaged, open or shortedInjector 7 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
    Trouble Code: P0208
    Cylinder 8 Injector Circuit Malfunction
    Possible Causes:
    Injector 8 connector is damaged, open or shortedInjector 8 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
    Trouble Code: P0219
    Engine Over-Speed Condition
    Possible Causes:
    Engine operated in the wrong transmission gear positionExcessive engine speed with gear selector in Neutral positionWheel slippage due to wet, muddy or snowing conditions
    Trouble Code: P0230
    Fuel Pump Primary Circuit Malfunction
    Possible Causes:
    FP or FSV circuit is open or shortedFuel pump relay VPWR circuit openFuel pump relay is damaged or has failedPCM has failed
    Trouble Code: P0231
    Fuel Pump Primary Circuit Low Input
    Possible Causes:
    FP or FSV circuit is open or shorted to groundFuel pump relay VPWR circuit open or fuel pump relay failedPCM has failed
    Trouble Code: P0232
    Fuel Pump Secondary Circuit High Input
    Possible Causes:
    Fuel pump relay contacts always closedFuel pump ground circuit has high resistanceFuel pump secondary circuit is shorted to powerLow speed fuel pump relay damaged or related circuit problem
    Trouble Code: P0297
    Vehicle Over-Speed Condition
    Possible Causes:
    The code indicates the vehicle was driven at very high engine speed (rpm) for too long. The PCM temporarily prohibits high engine speed by disabling the fuel injectors with this code set.
    Trouble Code: P0300
    Random Misfire Detected
    Possible Causes:
    Base engine mechanical fault that affects two or more cylindersFuel metering fault that affects two or more cylindersFuel pressure too low or too high, fuel supply contaminatedEVAP system problem or the EVAP canister is fuel saturatedEGR valve is stuck open or the PCV system has a vacuum leakIgnition system fault (coil, plug) affecting two or more cylindersMAF sensor contamination (it can cause a very lean condition)Vehicle driven while very low on fuel (less than 1/8 of a tank)TSB 03-14-4 contains repair help for this code for COP ignition
    Trouble Code: P0301
    Cylinder Number 1 Misfire Detected
    Possible Causes:
    Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 1Fuel delivery component problem that affects only Cylinder 1 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 1TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
    Trouble Code: P0302
    Cylinder Number 2 Misfire Detected
    Possible Causes:
    Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 2Fuel delivery component problem that affects only Cylinder 2 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 2TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
    Trouble Code: P0303
    Cylinder Number 3 Misfire Detected
    Possible Causes:
    Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 3Fuel delivery component problem that affects only Cylinder 3 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 3TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
    Trouble Code: P0304
    Cylinder Number 4 Misfire Detected
    Possible Causes:
    Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 4Fuel delivery component problem that affects only Cylinder 4 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 4TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
    Trouble Code: P0305
    Cylinder Number 5 Misfire Detected
    Possible Causes:
    Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 5Fuel delivery component problem that affects only Cylinder 5 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 5TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
    Trouble Code: P0306
    Cylinder Number 6 Misfire Detected
    Possible Causes:
    Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 6Fuel delivery component problem that affects only Cylinder 6 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 6TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
    Trouble Code: P0307
    Cylinder Number 7 Misfire Detected
    Possible Causes:
    Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 7Fuel delivery component problem that affects only Cylinder 7 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 7TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
    Trouble Code: P0308
    Cylinder Number 8 Misfire Detected
    Possible Causes:
    Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 8Fuel delivery component problem that affects only Cylinder 8 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 8TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
    Trouble Code: P0315
    Unable to Learn Crankshaft Variation
    Possible Causes:
    Inspect the CKP sensor for damageInspect the CKP sensor for debris on the rotorInspect the crankshaft pulse wheel for damaged teethInspect the crankshaft pulse wheel for wobble (loose condition)
    Trouble Code: P0316
    Misfire in the First 1000 Revolutions
    Possible Causes:
    Check for CMC DTC P0136, P0156, P0171, P0172, P0175, P1130 and P1150. Repair these adaptive fuel and HO2S codesCheck for any other CMC in memory. Repair these codes first!Ignore P1000 codes that set during KOEO and KOER Self-Test
    Trouble Code: P0320
    Ignition Engine Speed Input Circuit Malfunction
    Possible Causes:
    Inspect for problems with an Aftermarket 2-way radioInspect for signs of "arcing" at one or more of the ignition coilsInspect the Profile Ignition Pickup (PIP) unit inside distributor (check for damage or corrosion at the PIP sensor connector)PIP sensor is damaged or it has failed (distributor models)Ignition control module (ICM) has failed (Distributorless models)Trouble Code: P0340
    Camshaft Position Sensor Circuit Malfunction
    Possible Causes:
    CMP sensor circuit is open or shorted to groundCMP sensor circuit is shorted to powerCMP sensor ground (return) circuit is openCMP sensor installation incorrect (Hall-effect type)CMP sensor is damaged or CMP sensor shielding damagedPCM has failedTSB 02-22-1 contains repair information for this trouble code
    Nov 16, 2012 | Ford Cars & Trucks
    Nokia 1650 security code forgot
    Hello 12345 is the default code,even if it does not solve please visit nearest mobile repairing shop.Because, phone's security code could not reset it by yourself moreover, it could not be repaired without using repairing tools.With the help of repairing tools we can reset or generate the current code without missing any user data.Good luck.Thanks for visiting fixya
    Jul 15, 2012 | Nokia 1650 Red Grey Unlocked Dualband GSM...
    Have a code Po441 where is the sensor? does a menchanic have to fix it? trying to get car to pass emmission
    this obd2 trouble code table can help you understand the meaning of code.
    for this code, you can try,
    Repair damaged EVAP lines or canister.
    Repair open or short in voltage feed circuit to Purge Solenoid.
    Repair open in PCM purge command circuit.
    Replace purge Solenoid.
    Replace vacuum switch.
    Repair restriction in Evap line or canister or soleniod.
    Repair resistance in purge connector.
    Replace PCM.
    Sep 14, 2011 | Mitsubishi Endeavor Cars & Trucks
    Camera Code
    mimi-griffin
    pentax error codes are in the repair manual.the camera must be repaired . take the camera to a camera repair shop to get an estimate for repair.
    Jul 04, 2008 | Pentax IQZoom 928 35mm Point and Shoot...
    Cell Phones Logo
    24 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
