Question about Sony Televison & Video
Sony HXD870 DVR confused over PAL/NTSC??!
I have a Sony HXD870 DVR which is set to PAL-I (I live in the UK) and displays PAL TV signals beautifully. However, when I have tried to plug an Xbox 360 or a Nintendo Wii into its input port (either the SCART on the back or the 3 x composites on the front), even though both consoles are set to display PAL signal, it comes up with the following message:
"TV system of this signal is different from the recorder's setting"
If I go into the PVR's settings and change its 'Input Line System' from 'PAL/SECAM' to 'NTSC', the consoles display perfectly, despite the fact that they're both outputting PAL signal onto a PAL TV - how bizarre!
Any ideas?
SOURCE: AV 500 "No input signal" on multiple attempts
make sure your power source is connected to the dvr docking pod
Posted on Dec 05, 2007
  • 4 Answers
SOURCE: Curtis DVD8723UK Wrong Region Problem
This may be of no help to anyone but I have the same problem and I have spoken to Curtis Support today, they say there is no fix, its a fault in the machine and must be returned to the vendor as they have no service network in the UK. I bought mine with a 90 day guarantee off Ebay and it went faulty after 100 days but probably only used for 3 days so I'm stuffed!!!
Posted on Jun 09, 2008
SOURCE: Scart Video Control
Do you still need instructions on how to use it?
Posted on Oct 17, 2008
SOURCE: XBOX 360 NTSC only Black and White
yes xbox 360 NTSC only in black and whit colours
Posted on Feb 08, 2009
SOURCE: How do I set the correct input channel for S-video from laptop
press the video/tv button on your remote control until it gets to video or input 3
Posted on Feb 18, 2009
I bought sony and samsung tv in the uk can i used that in the philippines? Ive heard uk is PAL and philippines is NTSC. What is all about is there any converter to use it?
Yes, converters are available for possible different formats (PAL-NTSC) etc and also for different line voltages if it is needed--
Google is you best way to begin--search PAL-NTSC or what ever is needed for the signal ...........
Oct 24, 2012 | Televison & Video
How to turn a sony bdp-s790 dvd multi region
Buy two players. One from each region.
If you ave an NTSC TV only, you will also need a PAL to NTSC converter, if you want to play UK PAL DVD`s on US or Asian TV`s. But I think all Euro/UK TV`s are all both color signals (PAL & NTSC).
Jun 27, 2012 | Televison & Video
How do I get a US Sony Bravia KDL-42V4100 to work in the UK?
I have encountered this before---there are set top boxes that will convert the NTSC to PAL and the only other concern is the line voltage being the same or not.
May 29, 2012 | Sony Bravia KDL-42V4100 42 in. LCD TV
How to convert sanyo dvr DSR300N(NTSC) to DSR300P(PAL)?
You have to buy one NTSC to PAL signal converter for this, and connect it in beween your tV and DVR.
Apr 21, 2012 | Sanyo DVR-120
Hi - My question is basic - If I have a NTSC DVR can I use an external PAL tuner to enable me to receive and record NTSC and PAL signals?
There should be an output option that you change to NTSC (on your external tuner), Dvr's are pretty "proprietary", and are very sticky about accepting non-proprietary signals. For instance, a sattelite dish dvr, will not accept these inputs, nor will their hard drives re-format or zero out.
Oct 01, 2010 | Adapters.com AlchemyTV DVR NTSC/PAL/SECAM...
PAL PS3 NTSC HDTV, HDMI Cables don't work, WHY?
I have the same problem. I get the "Mode Not Supported" message on my Samsung pn50b860 when I try to run the PS3 through the HDMI. Any solutions/suggestions yet?
Jan 06, 2010 | Sony Playstation 3 (PS3) Console
Rf signal pal to ntsc
there should be an option in your picture settings menu
Jul 23, 2009 | Polaroid FLM-1514B LCD TV
Convert ntsc to pal for sony bravia tv
While a modern PAL TV can display NTSC sources (namely DVD players and PAL VHS players that support pseudo-NTSC), an NTSC TV can not display a PAL source, unless it's an expensive multi-standard TV. Sorry pal, bad choice.
Mar 30, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Can't display Pal on My Sony 57" KP-57WS520
There are probably a few problems here. What are you using to play the disc? Some NTSC players will "play" a PAL disc but interpret it as NTSC with the symptom you are describing. You need a DVD player that will play PAL. Many of those will output NTSC directly when set up to do so. The other alternative is to have a PAL compatible player that will output PAL into the converter. To narrow this down specifically, please post the model numbers and the connection scheme for your equipment. Once I understand your current setup, I should be able to describe a method to get this to work for you.
Dan
Dec 16, 2008 | Sony KP-57WS520 57" Rear Projection...
Not working
first you should know that the uk system is pal and the usa system is ntsc. ok connect your cable box using the rca cable to your converter then out of your converter to you tv. the converter box should have buttons for out and in now remember that pal signal is going in to your converter (it should automatically selected it) but you would probly have to select the signal that is going out of the convert and the signal going out is ntsc so make sure u select out signal to be NTSC. hope i could help
Apr 02, 2008 | Samsung SV5000W VHS VCR
Televison & Video Logo
433 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
