My H5B series will not play net flix due to the wrong ip address of 192.168.0.9 I have to pay $45.00 for the right one. why ?
2 Suggested Answers
drdarklord
  • 98 Answers
SOURCE: IP address problem with my router
call up your ISP. and ask for ipconfig check..
Posted on Jul 04, 2010
How do i uninstall nrt flix from my android 4.11 model #PLT7045K
Go to apps . then all apps . select net flix and then gap on uninstall
Feb 05, 2016 | Proscan PLT7223G-K 7in Android 4GB Tablet...
Still cannot play LAN games, used to can't now. I've checked everything I know (didn't take long) I've had a response suggesting a system restore, but that isn't going to help as I cannot point to the...
Did you get a new router or connection to the internet? The LAN games must see your ip address to communicate with you. If yours router or firewall is hiding the ip address, or if they're seeing an address starting with 192.168 or 10.10., that's the wrong ip address.
Some a/v software which includes a firewall can prevent connection too, and just disabling its firewall might not be good enough to get through. If you use the Windows firewall, it can be disabled as a test.
Nov 20, 2013 | Computers & Internet
Cannot wireless connect Samsung DVD Blue Ray to Net Flix
set the ip address to be detected automatically in the tv network settings.
What you need to know is the encryption key used on the Wi Fi
If you do not know it it might be on the case of the Wi Fi access point device.
Otherwise you will need to log into the router by typing the router's ip address into an internet browser on the working computer.
Nov 01, 2017 | Samsung Televison & Video
Can't load net flix on my ps3? shows wrong e-mail address?
PSN might be down again, try again in a few days
wrong email? delete it and type in the correct one
May 21, 2011 | Sony Playstation 3 (PS3) Console
Jul 04, 2010 | Zonet ZSR4134WE Wireless Router
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Wireless connection
1, You need know the TCP/IP address range that your router is allocating to your network. You can check this by typing ipconfig in the DOS window (click Start - Run - then type cmd to get a DOS window)
2. Take a note of the TCP/IP address and sub net mask etc.
Most likely IP address is 192.168.0.xxx (xxx might be 2 or 3 etc.)
Then go to the HP printer and to the configuration menu and scroll through to the Network configuration and setup the IP address and sub net mask. Set an IP address nearly the same as on your laptop but the last group of digits to be greater than the laptop (eg 10 or 15).
3. If you have installed the printer driver then click on Printers and Faxes then right click on the printer then Properties.
If not install the printer driver and install it on thr LPT1 printer port. Then click on Printers and Faxes then right click on the printer then Properties.
Then click on Ports tab - then click on Add Port - then select Standard TCP/IP Port - and configure this port with the IP address you assigned for the printer. Make sure you tick this Port box and tick Enable bidirectional printing - click Apply and then Close.
Then click General tab and Print Test Page.
If you get a test page then its OK, if not then go through the steps again - most likely the IP address is wrong.
Mar 29, 2009 | Gateway MX6421 Notebook
Need to determine the ip address for SATO M8485SE
2 ways you can determine the IP setup.
1: You can use Sato's ip net software, available from the Sato web page. This software will discover the printer on the network through a connected PC.
2: With the NIC carad inserted, the IP address can be set through the front panel by depressing the line key while powering up the printer. You can scroll through to the settings and change to the needed IP address
Dec 03, 2008 | SATO GT408E Thermal Label Printer
Computers & Internet Logo
David Payne
David Payne
