Question about Singer Sewing Machines
I have a singer ultra lock and its chaining off but not attaching to the fabric?
I gave changed needles, cleaned it out, re threaded it?
    Top Expert:
  • Singer Master
  • 8,204 Answers
According to this manual, it takes Singer needles which are probably 130/705 type:
Singer enthusiasts generally recommend using Singer needles, however, other sewists will use other brands as long as they are the same type. As for the needle size and the point, that depends on the fabric you are stitching.
All About Needles SCHMETZ Needles
Dec 14, 2017 | Singer Sewing Machines
I have a singer serger 14SH654, I have threaded it ok, (checked and double checked), and it's sewing ok, but whenever I go to remove the item I'm sewing the "yellow" looper always thread always breaks,...
I try not to pull the threads when removing my fabric from the serger. Instead when the fabric has cleared the needles, continue to sew a chain of about 5-6 inches, then simply cut it with scissors leaving part of the chain attached to the fabric and the rest of the chain attached to the machine.
Mar 27, 2015 | Singer Sewing Machines
Why would my Singer ProFinish not chain and the needles will not stay threaded?
Try rethreading it. Make sure you are getting the bottom thread right or your tension will not lock the threads thus no chain.
Jul 25, 2014 | Singer Sewing Machines
Skipping Stitches My Singer Confidence machine is skipping stitches. I've cleaned the feed dogs and the stitch hook, changed needles three times, changed thread, adjusted the tension, etc.
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
5. If the above suggestions don't help then the machine needs to be checked
For a timing problem.
Oct 07, 2013 | Sewing Machines
Singer sewing machine pulls fabric and snarls
try changing the needle--make sure the needle is the right one for the
fabric being sewed.
rethread the machine using every thread guide
try turning the bobbin the opposite direction
clean under the needle plate and in the bobbin area for lint
you may also have to use a washable stabilizer with the fabric
Apr 15, 2013 | Singer Sewing Machines
Singer model 620 sewing machine needle pokes holes in fabric but doesn't sew with the thread?
try changing the needle--make sure it's the right needle for the
fabric being sewed
rethread the machine top and bobbin
make sure the bobbin is inserted into the bobbin case
it's also possible that the machine could have a timing problem
and needs to be checked
Feb 12, 2013 | Sewing Machines
Singer 9030 runs but don't sew
try changing the needle--make sure the needle is the correct one
for the fabric being sewed.
also make sure the needle is turned the correct way in the needle
holder and pushed all the way up into the needle holder.
Nov 08, 2012 | Singer Sewing Machines
I have recently bought Singer Quantum 9940 and I am not happy with the stitch. For zigzag stitch, I can see too much of the upper thread on the bottom side. This happens unequally: more on the right hand...
1. Make sure your needle is correct for the fabric. Go buy some good needles in several sizes. You'll need a 90 for jeans, rounded points for fine fabrics... get a few sizes. Your manual should provided you with clues to the right needle for the fabrics. (BTW... there really is no such thing as a Universal Needle... toss it.)
2. Re-read your manual and carefully follow the instructions on threading the bobbin and the upper thread...
3. Check your tension on the upper thread... it is too loose for the application. The tension on the bottom thread is handled by a spring on your bobbin case or race. If you do not have that threaded properly you'll have problems. Same with the direction the bobbin turns... have in it backwards... problems.
Barring all these things... It might be time for a qualified Singer repair person to look at it. Sadly Singer has seriously lowered it's standards in the last 20 years.
Feb 05, 2011 | Singer Quantum 9940 Computerized Sewing...
Every few stitches thread gathers and jams on bobbin side of fabric. Why? [the machine is a Singer model 6180]
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin
Check tension 3 or 4 is usually good
Nov 23, 2010 | Sewing Machines
How do i thread my needle with the singer handy stitch?
  1. Loosen needle screw & insert needle with shank's flat side facing front of machine. Push needle in all the way, then tighten screw to hold needle in place.
  2. Install a fully wound bobbin by loosening bobbin nut & placing bobbin on top. Re-attach bobbin nut & tighten. If standard thread spool will be used, then attach spool pin to bobbin shaft & place thread spool onto shaft. Attach white spool cap on end of thread spool, then tighten. Bobbin/spool should unwind facing forward toward needle.
  3. Bring end of thread through thread guides & over tension control. Pass end of thread through needle eye, from back to front, & pull it out about two inches.
  4. A spring pushes pressor foot onto fabric that is being sewn, so lift pressor foot & place fabric underneath.
  5. Turn large handwheel on side of machine (handwheel can be turned in either direction) to raise needle arm to its highest position.
  6. Holding the Handy Stitch in place with your right hand, press on power switch & begin sewing. Guide fabric (being sewn) with your left hand.
  7. To end this sewing session, turn off power. Turn handwheel to raise needle to its highest position. Carefully pull out about three inches of thread through needle & snip, then lift pressor foot to remove fabric. Turn fabric over & loop needle threader through last stitch. Place end of thread from underside through eye of needle threader, & pull to loop through. Pull to tighten and snip end of thread.
Nov 11, 2010 | As Seen On TV Handy Stitch Mechanical...
Sewing Machines Logo
27 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
