Question about Pentair Mastertemp 250 Natural Gas Pool Heater
Mastertemp 250 power issue and service system only 8 months old initially turning on then from there a service system light and power distribution issue . Switched out ignition box and bad connector
    Diehard:
    Visited the website for 60 consecutive days.
  • 121 Answers
What is the current problem?
Posted on May 14, 2017
5 Suggested Answers
  • 366 Answers
SOURCE: I have a Pentair MasterTemp Heater 250K BTU (i
try cycling the power to the heater itself. Check for damage (pack rats, etc..). It sounds like you may have had a direct short. It could be a board problem or a transformer problem. If you're still getting the service heater light, check to see if any diagnostic LED is illuminated behind the board.
Posted on Jan 19, 2010
  • 1340 Answers
SOURCE: mastertemp 250 service system light
This has something to do with a water temperature sensor which normally is a thermocouple.It seems that yours is reading the water temperature,sends a feedback signal to some sort of computer type controller,and when the heater output water starts getting a bit hotter than the temperature which it knows the water currently is,it's shutting down.Within thermocouples,there is a small section known as a reference temperature.That section sounds like it's gone bad because when comparing the temperatures and going above the reference,the best way to describe it is it's like popping a circuit breaker in your house,which causes shutdown,but in your house it's to prevent fire and/or save the housing wiring.In the pool heater,it's saving the water from boiling because it doesn't know when to stop.If you need more help or this is not correct,just comment back here and I will get an autolink to your post and reply ASAP.Good luck! Greg
Posted on Oct 16, 2010
adamh294
  • 310 Answers
SOURCE: Pentair MasterTemp 400 Heater Will run fine for
This reminds me of some of the High temp sensors ive replaced. I would start with checking the pumps flow to the heater. Make sure there are no abstructions and at least 35 GPM (gallons per minute) running to the heater. If your flow is too low, you will trip the high limit sensor after a short while.
This could also mean you need to clean out the heat exchanger. When an exchanger gets dirty, it blocks the flow of water, slowing it down and "super heating" itdue to the water being in contact with the exchanger for too long. This will also trip the high limit and call for service.
If both the above items check out, contact me @ adamh@newconceptchem.com and I will guide you further.
Posted on Nov 23, 2010
  • 57 Answers
SOURCE: MasterTemp 250 blowing breaker...
As a pool professional, i have yet to have this problem, and youve had this problem twice now. Have you looked inside the liquid tight flex or galvanized conduit at the wires feeding the heater? Water could be inside that line causing your power to short to ground. Id check there first.
Posted on May 21, 2014
Could have a soft breaker.
Have a technician check the amperage draw at breaker pane.
May 21, 2014 | Pentair Mastertemp Heater
Mastertemp 250 will not turn off
make sure not on heat maintain if on turn off if ok bad display board
Nov 24, 2013 | Pentair Mastertemp Heater
Pentair MasterTemp 250 Natural Gas with "Service System"
possible bad pressure switch or loose wire or plugged line to switch
Sep 05, 2017 | Pentair Pool & Spa
Pentair MasterTemp 250 Natural Gas Heater with "Service System" issue
this heater will display 2 red light related problem 1-service the system mean you need to clean you filter, and service the heater mean it may be a problem with the heater this 2 you will be able to see it in key pad control the heater ,now reset the board and see what happens (CUT THE POWER ON/OFF UNCE )
Jun 09, 2013 | Pentair Pool & Spa
Pentair Mastertemp 250 Natural Gas Pool Heater Logo
94 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
