Question about Garden
Fisher plow will move up and down but not right or left. when i push button to move left plow goes up
SOURCE: fisher minute mount goes up and left and locks up
check your connections, especially the main power plug in, i have used a small "c" clamp over the connection to aid in the same problem
Posted on Nov 13, 2010
  • 34066 Answers
SOURCE: I have a 8ft Fisher storm guard plow on my dodge
Duplicate
Posted on Nov 29, 2012
dwb13
SOURCE: I have a fisher minuteman plow it will go up, left and right but will not go down what is wrong with my plow
If you have a Minit Mount two it's probably the valve sticking. It's electronically controlled so if it clicks, then the solenoid is working and the shuttle in the valve is stuck. Can be disassembled and cleaned. New ones are best but pricey.
Posted on Feb 07, 2015
dqdiamond18
  • 16 Answers
SOURCE: I have a fisher minute mount 2 plow for some reason it only goes to the right now , not up or left , no matter what button I press on the control it goes right .
Start by plugging everything in and pop the cover off the control part on the plow and check for magnetism on all 3 solenoids when you hit the various buttons on your plow controller. The pull should be very strong and noticable...a weak magnetic pull is likely just residual magnetism on your screwdriver. In my case, the S3 solenoid wasn't firing and that causes exactly what you're describing.
If your S3 isn't firing you can test the wiring by moving the S3 hot wire to the S2 solenoid. If your wiring is good the plow will misbehave in an entirely different way. Also get out your ohm meter and test the S3, if its good you should get 7 ohms on it.
You need to use the guide from Fisher and be methodical about it. Start at the plow and work your way backwrds towards the truck.
Posted on Jan 27, 2016
  • 14585 Answers
SOURCE: HOW TO GET WESTERN SNOW PLOW TO GO LEFT AND RIGHT
Hydraulic fluid doesn't really freeze. When it does, we wouldn't be around to see it. You need to go threw electrical. Go to there web site and see if you can get a diagram for it. Old systems are fairly easy to go threw. Newer ones have PC boards. Older ones, the stick/switches go bad first. But it always wise to loosen, then tighten the nuts that hold wires first. Corrosion sets in because it isn't used for so long.
Posted on Dec 18, 2016
Dec 18, 2016 | Cars & Trucks
Jan 27, 2016 | Cars & Trucks
When I press the controller button (any one) the blade goes to the right towards the passenger side and will not return or go up and down when I press any button.
PDF]2015 Nissan Rogue Quick Reference Guide
https://owners.nissanusa.com/.../2015-Rogue-quick-reference-guid...
NissanMar 19, 2015 - 22 Front Passenger Air Bag Status Light* ... A cellular telephone should not be used for any purpose while driving so ..... The MOD system will not operate if the liftgate is open. ... Press the ECO button 1 on the instrument panel to activate. ... When the vehicle approaches either the left or the right side of the.
[PDF]Getting to know your Q5 SQ5 - Audi USA
https://www.audiusa.com/.../dam/.../2014-Q5-quick-start-guide.pdf
Audicontrol knob with joystick, control buttons and function buttons. Pressing one of the ... While operating the menus and functions, you can return ... Tipping the knob right or left allows you to move through ... You can set any mix of up to 50 Presets from FM, AM or Sirius options. ..... Press and hold the driver's side temperature.
Meyer Plows Q & A December 2013 - Smith Brothers ...
smithbrothersservices.com/dec-2013-meyer-plows-q&a.html
To angle right the C Valve must divert all of the fluid to the driver s side PA Ram to make ... IF it was a bad coupler, it would be that the plow gets stuck and will not move, .... Message: the plow angles left to right with no problem when I go to raise .... goingbackwards through a return port and putting pressure on the coupler.
Jan 08, 2016 | Cars & Trucks
I have a minute mount plow, when I try to use it only goes to left and right side but doesn't go up, when I try to lift the plow goes to the right. What can I do
2002 Fisher Minute Mount Inst-Act Wont Angle [Archive] - PlowSite ...
www.plowsite.com > ... > Truck & Equipment Repair
Nov 17, 2011 - 90 posts - ‎9 authors
My plow went up it was jerking and did it in steps , but , it got there . Now , it onlyjerks when i try to angle it right or left or up . I filled the fluid ... Drop it and if it doesn'traise you can just use a jack and shorten the transport chain to hold it. .... I do havecontinuity on the plow side for all 3 wires going to the plug . Hooking Up A Fisher Minute Mount 2 In Under 1 ...
Feb 1, 2011
Plow Wont Angle
Oct 19, 2010
What's wrong with my plow?
Jan 9, 2003
Looking For Minute Mount Tips
Feb 13, 2002
More results from www.plowsite.com
Ultramount Intermittent Angle Problem - Snow Plow Forum - L
Dec 27, 2015 | Cars & Trucks
My fisher minuteman 2 plow will go up and left and right but will not go down
Most of those systems don't have a driven retraction on the piston. It is gravity feed back. There is a valve that is sticking or out of adjustment. http://library.fisherplows.com/?cat=38
Jan 24, 2015 | Cars & Trucks
I have a fisher minute mount an older model with fixed controls. plow goes up and down but does not go left or right, sometimes with the control set for left or right it starts to go up ? where to sta
check the wiring connections on the plow solenoids to be sure they are correct, the second step is check the controller box, using a continuity check via multimeter set for DC voltage. I have an old western plow that had similar symptoms, and was the controller box.
Oct 19, 2014 | Cars & Trucks
Fisher minute mount plow
does the pressure release close to raise the plow?
Jan 05, 2014 | Dodge Cars & Trucks
Fisher minute mount goes up and left and locks up
Oct 29, 2009 | 1998 Chevrolet C1500
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
