Plzzzz help m274949 ob 2fcf18c838ja - Washing Machines
I need an unlock code for my t919 behold samsung plzzzz help me or email me here jhennazelle@yahoo.com plzzzz
i need YOUR IMIE NUMBER PRESS THIS FIRST *#06# ON YOUR PHONE TO GET YOUR IMIE NUMBER
Jun 27, 2010 | Samsung Behold Cell Phone
I forgot my nokia n70 security code.........plzzzz
this is master security code for your imei no.
4214235773
Apr 09, 2010 | Nokia N70 Cellular Phone
The washer stops mid cycle and says Ob. I
The OB indicates and out of balance condition has been detected by the motor control.
One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 05, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
E73 error code. X-box is not connected to internet. Ethernet?
This is caused by overheating, a cold solder joint under the southbridge or ethernet chip.
Go here to find out more and how to fix it.
Dec 05, 2009 | Microsoft Xbox 360 Console
I have an error message that reads ob. I have an
OB MEANS OFF BALANCE if the motor controller detects an unrecoverable off-blance condition, the machine controller will shut down and display ob. the lid switch must be opened at least once before restarting the cycle if this condition occurs. opening the lid will allow you to view and redistribute the load. press stop/cancel to clear the display. hope this helps.
Oct 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso stops at 26 minutes and throws ob code
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
May 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Machine stops during spin cycle and reads 'ob' on the display
Read this thread about your error. I am sure it relates to your (drain) problem.
Good luck and if you have any more questions, just come back here and leave a comment - I'm happy to help.
May 21, 2009 | Kenmore Washing Machines
"OB" Code error
Nov 15, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Calypso ''ob'' problem
ob Off Balance If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an ob for Off Balance The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load.
if this does not fix the issue it is most likely the strut and shock system that is falty on the machine. you could replace them yourself but they are fairly expensive
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Nokia 2865 forgot security code
standard code is 12345 if you jave changed it then infortunately you will have to take it to a service centre to have them reset it
Jan 18, 2008 | Cell Phones
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
