Question about Dishwashers
My gallery dishwasher 117902380-a has a box in the control panel with this message in it:.CO what does this mean, there is also some kind of little beeping about every 90 seconds
4 Suggested Answers
SOURCE: oven failed to work; F5 error message
please tell about the make & serial no. of oven.
Posted on Sep 30, 2007
  • 1531 Answers
SOURCE: my fridgidare gallery,pro series oven was out of
the main control board has to be replaced. this is the onl solution
Posted on Sep 16, 2009
SOURCE: GE Profile Dishwasher beeping
Mine was doing the same thing. It was eligible for a recall.
Free repair or rebate toward new purchase. 1-877-275-6840 or go to website geappliances.com
Posted on Jan 30, 2011
Why is there recurrent error code I30?
Hello Roberta, I appreciate your submission!
Based off the information you have provided me your Frigidaire dishwasher is displaying an error code of "I30". Error code "I30" means you could be experiencing an issue within the aqua control, which means it could be your water valve, water line, or control panel. You may need to reach out to your manufacturer for additional assistance. I hope this information is helpful. -Matt
Apr 19, 2016 | Frigidaire Gallery Series FGCD2456QF Full...
Error code CO HOW DO I CLEAR IT ON THE DISHWASHER
Hey Robert, thank you for your post!
Based off the information you have provided your Electrolux dishwasher is displaying an error code of "CO" and you would like to clear it out. The error code "CO" means that there is a miscommunication within your dishwasher. The best way to clear the code out is to perform a reset and you can do that by disconnecting the power cord for at least ten minutes. If the code continues to display this could mean that your keypad, a wiring harness, or control panel may need to be replaced and I would recommend having a professional technician out. They would have the appropriate tools needed to disassemble your dishwasher and test each component. This will help protect you from any unnecessary part purchases. -Matt
Jan 15, 2016 | Electrolux Dishwashers
I need to know what the error code pf means for a frigidaire gallery model #fgh202465nf1a
Hey Carol, I understand that you are receiving an "PF" error message on your Frigidaire Dishwasher. Typically this error code indicates a power failure. Before considering contacting a service provider, I would recommend resetting the dishwasher by turning off the power to the appliance for about five minutes. After the five minutes return power to the appliance, this should allow the appliance to return to working condition. At this time if you find the problem still persists, you may want to consider contacting a professional technician. The concern could be the control board. Hope this helps! -JK
Oct 11, 2015 | Frigidaire Dishwashers
New dishwasher has stopped functioning...
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
Jan 25, 2013 | Dishwashers
Control panel not working
It is possible that themachine does not start off the cycle because there are errors or feedback fromthe inputs. For the program to start up the main program controller mustinitiate the INLET/PUMP MOTOR/DRAIN to workwhen it is commanded .If this does not happen then the voltage at thesepoints must be checked or the faultrelates to no voltage/drive from the controller. This means the controller is asuspect.Checkhow to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
Jul 06, 2012 | Maytag MDB9601AWS Stainless Steel 24 in...
Clean light is blinking red
Also please check the link below:
Mar 12, 2012 | Kenmore Dishwashers
Diplomat dishwasher operate button not doing anything
Mar 11, 2012 | Dishwashers
Hi I have an LG dishwasher LD 1415M and it is constantly stopping with error message OE, do you have any ideas.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water. If not the drain pump must be checked for dirt cloggging , cleaned or replaced.
Please check the link below:
Thank You for using Fixya
Sep 16, 2011 | LG Dishwashers
Frigidaire Gallery dishwasher smoke coming out of door. smells like wires burning.
You need to replace the blower assembly, common prob after a few years of use.
Part number: 154226802 "Blower-Crossflow", suggested list at this time is around 30.00 us dollars.
To replace: TURN OFF BRAKER TO DISHWASHER
Open door, remove inside screws form panel and carefully remove panel up from door, blower is next to timer on control panel.
Nov 12, 2009 | Frigidaire 24 in. FDB636GF Built-in...
Electrolux Gallery Dishwasher Error Message AL3
It sounds like it could be a heater problem, I would check this first
Nov 26, 2007 | Dishwashers
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
Owen Barnes
