Question about Korg Music
Hey it's someone who helps me on my korg PA800? Problemen is when I play with rhythm playing very bad but the standard sound and the style plays good.Kan be to changing ram?
  • 5 Answers
SOURCE: no sound
1. plug in some headphones into the jack.
2. connect to an amplifier or external source.
3. connect midi to a midi-compatible device and determine if device receives signal by pressing keys
If #1 or #2 passes, your speakers are bad.
If #1 & #2 fail, but #3 passes, your setting are set so that there is no sound, but the keybourd still recognizes input.
If all three fail, the keys do not send a signal at all, you should replace the keyboard.
Posted on Feb 26, 2009
  • 1138 Answers
SOURCE: pcm ram problem for korg pa800
http://www.musitronics.org/ Try here but apparently they are on holidays until August 16. There is also an ongoing discussion athttp://www.korgforums.com/forum/phpBB2/viewtopic.php?t=44624 Hope this helps.
Posted on Aug 06, 2009
SOURCE: Hello,I have a small question re the KORG PA800
there is now homemade solution for pa800 with 128mb ram, i have 128mb in my pa800. but u cant just put new ram, its kinda complicated.
Posted on Sep 28, 2009
  • 5603 Answers
SOURCE: WHAT KIND OF PCM RAM MEMORY IS USED IN KORG PA800
Here is a site IF you are having problem with the PCM RAM. It sounds like you might even get a free replacemnet part.
http://www.korgpa.com/pa_root/en/products/pa800_faq.html
Posted on Nov 20, 2009
mrniceneasy
SOURCE: Korg PA800. Ram Upgrade
The pa800 has a fixed amount of Ram at 64mbs and it is not physically possible to upgrade the Ram. The pa2x has a removable128mbs Module and that can be upgraded via a 256mb Module from Korg.
Keith [mrniceneasy - KorgForums]
Posted on Apr 09, 2010
My synth wont load when I power it on. can anyone help?
I suggest a hard reboot / initialize. Istructions are in your manual or on the Korg website
Jun 09, 2015 | Korg Pa800 Synthesizer
Korg pa800 256mb styles set
I wouldn't recommend doing that, because your OS system could freeze occasionally
Jan 29, 2014 | Korg PA800 61 key Arranger Keyboard Kit
Hi i have problems with my speakers on my pa 800 ,when i just play tones its clear but when i play the rhytms doesn't play right is not clear
Read your user manual about keyboard split. OFTEN the rhythms use the keys below F sharp for the chording of rhythm. When in this mode, you should restrict your melody to notes above F sharp that is to the left of middle C. If you play melody below this it will confuse the rhythm chording. You can likely change the split point of the keyboard, however, the F sharp split is the standard and I would suggest staying with it.
Dec 14, 2011 | Korg Pa800 Synthesizer
Hello, My Pa800 is few years old now has always worked perfectly. I recently combined few sets of rhythms together and loaded it there seemed to be no problem, few days later i was getting glitches in all...
The splicing of rhythms to play seamlessly would be tricky. Also you need to consider if you might be exceeding the number of generators available. If you are splicing external samples, that take great care and a lot of editing. Part of the problem is syncronizing the clocks of individual samples. It is hard to avoid glitches and changing mode of clock and quantizing will expose these glitches.
Sep 07, 2011 | Korg Pa800 Synthesizer
How to save styles in user pa800..
When you are in style play screen , press record , then select record/edit , it leads you to record screen. on record screen touch upper right hand of the screen (page menu) and select "write style" and this way you can save it whereever you choose. once you are done , on same page menu choose "exit from menu" to get out
Jan 19, 2010 | Korg Pa800 Synthesizer
I have noise on ram samples
Korg Pa800 Synthesizer i have noise on ram samples Answer i turned on my pa800 and when i play ram samples there was some noise like cracking and distortion,... (More) i turned on my pa800 and when i play ram samples there was some noise like cracking and distortion, that happened 2 or 3 times, now its normal, but i think it may hapen again??? where is the problem, somebody says it is on motherboard? or its just ram overheating? since i install 2.01 os i noticed that its kinda warm in right display corner, can u help me???
Sep 23, 2009 | Korg Pa800 Synthesizer
PA800 Instruments making noise
you have memory problem it cost $150 to fix it
Aug 06, 2009 | Korg Pa800 Synthesizer
Os system not loaded! hard drive was totally formated. PA800
Hi, have you solved this problem yet? If you have, share the solution with us please! :)
Mar 23, 2009 | Korg Pa800 Synthesizer
Music Logo
16 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Korg Music Expert? Answer questions, earn points and help others
