Question about Dryers
Dryer Pause/Start/Cancel button is not retracting correctly and hence dryer wont start. Any idea how to release it?
catriver
  • 878 Answers
SOURCE: My Dryer will only work if I hold start button, when I release start button the dryer stops.
Anra, this is a classic symptom of a failed even heat board. I've seen a lot of these failures out there. Easy to change out. Check out this link. Catriver..post back http://www.repairclinic.com/0080.asp
Posted on Mar 26, 2007
catriver
  • 878 Answers
SOURCE: My Dryer will only work if I hold start button, when start button is released the dryer stops working.
Anra, the problem is in the even heat board under the consol. This is a very easy job. Check out this link. Catriver, post back http://www.repairclinic.com/0080.asp
watugot
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
SOURCE: Kenmore Dryer
I had this same problem a couple of years ago. I replaced the circuit board located in the top part of the dryer and it has been fine since. The part cost $95 over the internet.
Posted on Jan 12, 2009
  • 3 Answers
SOURCE: Asko Dryer stops running when you release the start button.
It could be that the overheat protection kicked in. When this happens the dryer will start when you push the button but shuts off when you release it. There is also no heat.
There is a reset button on the back of the dryer covered by a rubber membrane. Push that in. If you hear a click, the dryer has reset and should run normally. If the dryer continues to shut off and need reset, there's probably a lint blockage somewhere.
Posted on Jun 21, 2009
Dryer is control locked, will not start. How do I release it?
try the Pause/Cancel button
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 26, 2013 | Dryers
My frigidaire dyer comes on then the pause message appears. These are new appliances.
Hello barbarada180 - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Jan 02, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How do you ge codes on a electrolux front laod dryer?
* Wake the washer by pressing any button. * Wait 5 seconds. * Press and hold the Start and Pause/Cancel buttons simultaneously. * All LED's will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LED's. The control will repeatedly signal the code, as long as the Start and Pause/Cancel buttons are pressed. A two second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Aug 19, 2012 | Frigidaire AEQ7000EG Affinity Series...
The dryer just stopped and now wont turn on
WAKE THE WASHER BY PRESSING ANY BUTTON.
WAIT 5 SECONDS.
PRESS AND HOLD THE START AND PAUSE/CANCEL BUTTONS SIMULTANEOUSLY.
ALL LED'S WILL GO BLANK AND AFTER A FEW SECONDS THE CONTROL WILL SIGNAL THE STORED CODE USING AUDIBLE BEEPS AND BLINKING LED'S. THE CONTROL WILL REPEATEDLY SIGNAL THE CODE, AS LONG AS THE START AND PAUSE/CANCEL BUTTONS ARE PRESSED. A TWO-SECOND PAUSE BETWEEN REPEATS AFFORDS YOU THE ABILITY TO MAKE ACCURATE COUNTS TO IDENTIFY THE CORRECT ERROR CODES.
PLEASE NOTE THE FOLLOWING: ON A SMALL NUMBER OF WASHERS WITH SERIAL
NUMBER PREFIX XC4, IF THE PREVIOUS PROCEDURE DOES NOT PREFORM AS
SPECIFIED, FOLLOW THE OPTION BELOW:
* FOLLOW ALL PREVIOUS STEPS BUT INSTEAD OF PRESSING START AND PAUSE/CANCEL BUTTONS, PRESS AND HOLD OPTIONS AND PAUSE/CANCEL BUTTONS."
*THE CONTROL WILL PAUSE FOR 2 SECONDS, THEN REPEAT THE CODE AS LONG AS THE TWO BUTTONS ARE PRESSED AND HELD."
NOTE: A LETTER APPEARING IN THE CODE STANDS FOR A NUMBER HIGHER THAN NINE: A=10 B=11 C=12 D=13 E=14 F=15 "
"EXAMPLE CODE F1: THE FIRST DIGIT WOULD BE 15 AND THE SECOND WOULD BE 1. IF THIS CODE WOULD APPEAR ON A WASHER IN THE GOOD MODEL LINE, THE FIVE INDICATOR LIGHTS WOULD BLINK FIFTEEN TIMES AND THE START INDICATOR LIGHT WOULD
Jul 28, 2012 | Frigidaire GLET1031FS Top Load Stacked...
My dryer wont start and the lock button is on
1) Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off.
2) When the dryer is running and Control lLcked light is on, the dryer can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
Mar 13, 2011 | Kenmore Dryers
Start button will not initiate on cycle. Get 3 beeps.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 20, 2010 | Whirlpool GEW9250 Electric Dryer
My whirlpool dryer just beeps when you try to start it. The panel is lit up the door is shut, push start and it just beeps...any idea what the problem is
To unlock the Control Locked feature:
NOTE: When the dryer is running and Control Locked light is on, the dryer can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If holding doesn't unlock the feature, it is likely a faulty interface. I am having the same problem with my Whirlpool dryer and it is the interface, but it seems that a lot of people are able to correct the issue just by pressing the End of Cycle button for 3 minutes.
Here is a link to parts, numbers, and prices from Sears:
http://www.searspartsdirec t.com/partsdirect/getSubComp.pd?modelNumber=GGW9250PW1&productCategoryId=0151200&brandId=1198&modelName=RESIDENTIAL-DRYER&diagramPageId=00001&componentDescription=TOP%20AND%20CONSOLE%20PARTS&documentId=W0508037&blt=06
Jan 09, 2010 | Whirlpool GEW9250 Electric Dryer
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Apr 23, 2008 | Dryers
Dryers Logo
Top Dryers Experts
