Question about Cooktops
How to clean the ceramic parts on the hob - Cooktops
4 Suggested Answers
  • 338 Answers
SOURCE: hob not working
replace the hob. the f1 error is not sensing a temp change and if the burner is broke it wont sense it.
Posted on Dec 07, 2008
SOURCE: Stoves 700CTH hob
I have a Stoves 900 CTH with the same problem. Its been like it for about 6 months and we're still able to get it going eventually.
If you turn the power on at the mains and leave it beeping for about 2 hrs then press the power on touch button. You should see all the "0."s flashing. When the flashing and beeping goes slow try pressing one of the hob buttons alot until the little dot illuminates next to the 0 then quickly lit the + button.
It sometimes works after 5 mins but other times it takes 20-30mins and is a real pain in the ****.
I did ring Stoves a while back and they quoted me £190 for the pcb but I hardly use it so just lived with it as it is but I finally had enough tonight and done a web search which turned up this thread.
I've just pulled it to bits to see if I could locate this "C17" but not 100% sure what I'm looking for.
29792d1.jpg Is it the big silver thing in the center with 5B RVJ on it?
Posted on Oct 13, 2009
  • 254 Answers
SOURCE: I can't unset the child safety lock on my diplomat ceramic hob
get the model number if a cooktop will be underneatth on sticker.... go to kitchaid.com and locate thier manuals and literature section where u can download a copy or print one out.... hope this helps
Posted on Feb 06, 2010
My clients ceramic hob has small scratches appear on one of the pan areas it's only a week old how can this happen the pans seemed clean underside .
ceramic tops are not made for sliding pans or skillets on . as on GAS ranges. give them a bottle of cook top cleaning creme
Dec 22, 2015 | Bosch 233331 - GLASS CERAMIC HOB TOP
Lamona ceramic hob
Ceramic cooktops need the correct type of pots or they leave marks,check your instruction manual.
Mar 11, 2014 | GE Cooktops
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
Feb 05, 2010 | Cooktops
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Neff T1722 so 02 ceramic hob
its normal for the ceramic hob to ON & OFF coz of the sensor inside the unit to protect for overheating.same here in phillipines.its normal.tnx gerbee
Jul 28, 2008 | Neff 23 in. T1443 Electric Cooktop
Cooktops Logo
78 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
