Question about GE Microwave Ovens
How do I replace the wave guide cover on ge model # jes737wm02
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Microwave is arcing inside
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is the plastic ceiling.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced.
If you need more specific help, please reply back with your brand and full model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Feb 03, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: not just once, twice!
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
Your manual should address the issue of removing and cleaning the waveguide cover.
If for some reason you don't have your owner's manual, you can download GE owner's manuals and installation instructions here.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jun 24, 2009
SOURCE: GE Profie JE1860SH 04 microwave sparks
Our JE1860SH was also sparking after a few seconds. The GE tech pulled the upper round disk and found the problem. The plastic was burned and the round metal which is behind the plastic dome was arching with the frame. Lasted seven years expected more especially from a GE product. So my suggestion is to remove the dome and check it out.
Posted on Jan 21, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: KitchenAid Model: KHHS179L Serial No:
In your owner's manual (available free online here) this is called the "microwave inlet cover".
See the tag in your oven cooking cavity or near the door frame for your full model number.
The cover is located in the ceiling of the oven.
You should be able to remove and clean or replace the cover without removing the oven from the wall.
The oven installation instructions and parts list are also on that page.
You can also find handy exploded views and order any needed parts and accessories by model or part number here.
Posted on Jan 16, 2011
MicrowaveSvc
  • 9098 Answers
SOURCE: I need a new wave
The part number is PCOVPB085MRP0 (note ohs and zeros are different) and you can get it from Encompass here.
Posted on Feb 17, 2011
I have a GE WES1384SM2SS microwave oven that shoots fire out of the right hand side.
Sounds like it is arcing there. Is there a plastic or Mica cover there?? If so that is the wave guide cover and it will need to be replaced and any and all carbon burn marks totally cleaned out to be able to save the machine. You can remove the burnt cover and run the unit with a container of water in it to see if it still arcs. If it does more cleaning will be needed if not, replace the covers with new ones and you should be good.
Aug 12, 2017 | GE Microwave Ovens
My GE microwave is starting to arc, You can see the arcs on the plate (I believe it is the wave guide cover) on the right side interior. Burn marks are evident on teh plate. Is it the waveguide cover or...
Some units use a plastic or fiberglass cover over the wave guide where the microwaves are dumped into the oven cavity. If this cover gets coated with food/grease, or soaks up grease, it can arc, or catch fire. If unit is still operating properly otherwise, I would suggest replacing the cover. You need to inspect the wave guide, also, to make sure it is still intact, and there are no cracks in it that would allow microwave radiation to escape.
Apr 17, 2014 | Maytag MMC5000 Microwave Oven
Ge mircowave message is P F
"PF" means that the power has been interrupted, so you need to set the clock, then the oven should work.
If you actually do have a problem with this oven, it will have to be replaced, since GE does not make repair parts available for it.
Jan 16, 2013 | GE Microwave Ovens
I have a GE microwave model# jes737wm02 manufactured inFeb. 2009 it runs but won't cook
we purchased a ge microwave about 2 yrs ago & the paint is peeling on the inside. Is this dangerous & should we continue to use it?
Oct 28, 2010 | GE JES738 Microwave Oven
I have a GE Microwave Oven/Dual Element Browner Model # JES1288SHO3. The inside cabinet is arching through the wave guide panel. DAVE IN LA.
Hi Dave in LA,
The wave gude cover is replaceable, the part number is1085082. The reason for arcing through is typically a splatter of food stuck to the cover and then the heating waves overcooked or burned it. Carefully replace the cover (panel), look for any burned spots behind the cover, if the wave guide is burned through, the Microwave is unrepairable. If the waveguide has small arc spots you can carefully clean (sandpaper) and use touchup paint to recoat. I hope this helps and if it does, please let us know!
Apr 18, 2010 | Microwave Ovens
I have a GE spacemaker. It releases electric volts when is turned on . Needs to be changed or can be repaired?
Do you mean "sparks" inside the oven cavity when it is operating ?
If so, check for grease spots on the wave guide cover or scratches on the oven liner. Scratches can be touched up with touch up paint and wave guide cover`s can be replaced.
Hope that help`s, good luck.
macmarkus :)
Feb 10, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Sparks and strange noise when microwave is turned on even when empty inside. i have a ge jvm1850smss over the oven microwave.
YOU SHOULD NOT RUN MICRO WITHOUT ANY THING IN IT / THIS WILL OVER LOAD THE MAG TUBE . AND SOME TIMES FRY IT .. The sparking and arcing is probably a bad wave guide . this is sometimes caused by food splater / it gets in the cracks and corners and then cooks till it truns to carbon which conduts the micro's and thus arching .. clean it good and touch up any burns in the metal and repl wave guide cover. mm hope this will help .. mm
Dec 20, 2009 | GE Spacemaker Over-the-Range Microwave
Clicking When Unit Starts
Q - When there is small amounts of food in the oven, arcing occurs right behind the plate where the wave guide comes into the oven. Sometimes it works well and sometimes you can't even put in a bag of popcorn. Any ideas? Could food have 'dripped' in here and be causing a microwave short?
A - Yes! Food splatter or drips can continue to cook and will carbon over creating sparks/arcs from the wave guide cover. Usually can clean up the food on and under the wave guide cover, if the oven liner has been damaged we usually lightly sand and touch up those marks with touch paint. Do not let it go for too long as damage to the magnetron end is possible as well :(   If the wave guide cover has been damaged, replace it!
Apr 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
prototech@usa.net
Nov 13, 2008 | GE JES1384SF Microwave Oven
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
