Question about Ovens
What means the fault L by a Tarrington IC Cooker
I BUY FROM ARGOS A BUSH COOKER THEY DELIVERY TO MY 3 FAULT BUSH COOKER.I'M STILL WITH A FAULT COOKER
call them and tell them what the problem is . we have no idea where you got or what you got
Jan 26, 2016 | Ovens
Tip
Built in Oven not heating
If you have a problem with your cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
on Apr 02, 2015 | Ovens
Oven will not heat up after using autoclean.
If you have a problem with your whirlpool cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
How to Repair
Buy Paul Beer
Mar 16, 2015 | Whirlpool RBS245PRS 24" Single Electric...
Electrolux EOD5310 Electric Double Oven power to oven but no heat
If you have a problem with your Electrolux EOD5310 cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
How to Repair
Buy Paul Beer
Jul 06, 2014 | Electrolux EOD5310 Electric Double Oven
Beko fan oven making noise
If you have a problem with your cooker or oven then this diagnostic video will help you find the fault on your beko oven and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
How to Repair
Buy Paul Beer
Jan 08, 2014 | Belling XOU492 Electric Double Oven
Beko oven
If you have a problem with your beko cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
How to Repair
Buy Paul Beer
Jul 06, 2013 | Ovens
Hi Our smeg oven model SNZ91MFX1 has stopped working, and the clock just says Fu 14. Any thoughts on what the fault message means?
did you find out what this meant? I have a smeg cooker which is saying the same and can't find any info about it. Many thanks.
Apr 27, 2011 | Smeg Ovens
My Belling E641 keeps tripping out. Now the trip
You evidently have an earth fault on the cooker i.e one of the heating elements has failed and the trip switch is operating to prevent you getting a shock.
Most likely it is one of the radiant rings that is at fault but it could also be an oven element.
There is no easy way to tell without checking with a multi-meter for earth continuity between each element and the cooker frame, you can do this with the power off and the meter set to resistance or continuity test.
There should be no reading between healthy elements and earth but a faulty element will normally show a reading when the probe touches the cooker frame.
Dec 30, 2009 | Belling Ovens
Cooker power has gone.
has it come back on? if not it may be a connection going into the back of the cooker or if it has come back on it may be an overheat stat kicking in -check the blower (cooling) fan is ok.
Mar 16, 2008 | Ovens
EG73 Hotpoint Oven heating when switched off
sounds just like hotpoint customer service "fob off"
your fault sounds more like the selector swich shorting out going by prev repairs i would isolate the cooker straight away and investigate.
ps. would not leave cooker powered up if not in use until fault repaired
Feb 28, 2008 | Ovens
Ovens Logo
23 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
