Question about Kitchen Appliances - Others
I want to have a manual of the Tarrington House IC2011B induction Cooker
What should we do when the induction cooker appear E0?
Are you searching forInduction Cook-toperror codes? Here youcan find the error codesof all popular inductioncooktops and how totroubleshoot it. Theseare for your referenceonly, do not try to open your cooktop withoutproper safety measures, we advise you to call theservice person if any servicing is needed.
Error codes like E2, E0, E9, as we see in famous induction cookers like Pigeon, Prestige, Butterfly etc. are annoying at times, when we are in a hurry to go to office. Errors appear as numbers and finding it from the user manual will take days and leave us impatient. Here is a handy guide of induction cooker error codes usually seen in branded and un-branded induction cookers. You may save this page as pdf or as it is in your phone or PC for quick reference.
E0 -Cooking vessel is not placed correctly. Vessel is either removed or not made of a material usable with induction cooker.
Feb 03, 2017 | The Kitchen Appliances - Others
If induction cooker does not heat the pot
Induction-compatible cookware contains contains iron or has a layer with magnetic properties. Cast iron, enamel cast iron and most types of stainless steel cookware are all induction compatible (But not all types; for instance, All-Clad's MC2 line, which is made of aluminum and stainless steel, is not induction compatible)
Nov 25, 2014 | Winco Professional Induction Cooker -...
Pressure cooker is not heated on induction cooker
Likely the pressure cooker base is not induction-compatible. This is the case with all aluminum pressure cookers and some older stainless steel models. Your cookware store will have a small metal plate that you can put on your induction burner to heat non-induction compatible cookware.
Nov 10, 2013 | Home
Lost my manual for induction cooker
What make and model induction cooker?
Oct 26, 2013 | Ovens
When have weight on induction cooker cooker can not cook
Remember that induction cookers are fussy that you have a special stainless steel pot or pan made just for induction cooking. It must be an 18/10 alloy (18% chromium and 10% nickel)
Oct 02, 2013 | Winco Professional Induction Cooker -...
Repair induction cooker
>> call a service agent with induction cooker experience
Sep 27, 2013 | GE Electric Induction Cooker
The induction cooker when put on it shows E6 after about a minute or so and no heating takes place.
There is a error message there, it indicate a problem with your induction cooker. It cause a defective winding wire or circuit controllers your know induction cooker works similar to the principle of electro magnet induction, it give heat to metal cooking pot. I hope I give you a idea regarding what happen to your unit.
Mar 23, 2011 | Microwave Ovens
I have a prestige Induction cooker... a new one. When I tried to turn it on for first time, it just shows "-- -- -- --". Post this, even after placing a induction cooker compatible vessel, it...
We have a Prestige Induction cook-top Model PIC 3.0. It gives the error "-- -- -- --" and a beep when the power is turned on. Can anybody help. My email is asbhambra@gmail.com
Mar 11, 2011 | Microwave Ovens
E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
Dec 12, 2010 | Stoves Heating & Cooling
I have a new induction cook top. When using for the first time I found an F or P appeared next to the element I was using. I have bought stainless steel cookware specifically to use. The user manual...
Stainless steel (or Aluminium) cookware will not normally work with an Induction cooker: Induction cooker need cookware that have a certain amount of metal especially at the bottom of the pot or pan.
An easy way to check if the cookware is suitable is to use a small (fridge) magnet: if it stick to the pot/pan then it is very likely that the pot/pan is suitable for induction 'magnetic' cooking!
Hope my small hint is of assistance and if so, vote accordigly!
Oct 03, 2010 | Westinghouse Microwave Ovens
Kitchen Appliances - Others Logo
283 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
