Question about Vehicle Parts & Accessories
Change pin on remote. - Vehicle Parts & Accessories
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Posted on Dec 16, 2016
How to change the battery in a jaguar XF smart key
1) Carefully remove the plastic silver sleeves on each side of the remote.
2) Carefully open the remote to expose the battery -- try to keep the circuit board and valet release pin from falling out.
3) Replace battery -- plus (+) side down
4) Before closing body of remote, take note of valet key release pin & spring. Be sure the spring and pin are in the correct position (see pic).
5) Carefully close body of remote.
6) Before attaching sleeves to remote body, be sure the notched end of the sleeve is aligned with the valet key.
7) Carefully slide silver sleeves onto each side
8) Test
Apr 24, 2014 | 2009 Jaguar XF
Remot start/alarm system not working properly
Sounds like something out of sync reboot. Disconnect batteries and reboot.
Jan 15, 2014 | 533 2way Security Remote Start System
Tried a Kodak Extension remote cable and slide transport now inoperative
Take a closer look at the pins on the remote cable and the socket on the projector. Their are 5 pins on the plug. The top 2 pins are closer together than the bottom 2 pins. It is easy to rotate the plug 180 degrees and with little extra pressure, push it in. If the pin / plug interface is rotated 180 degrees, the remote control will appear non-functional. Check that first. Then try plugging the remote into the projector without the extension to eliminate a broken wire in the extension cord. Verify that the on-board cycle buttons will cycle the projector. If they do, and the projector won't work with the remote control, then there may be a open circuit inside the projector. You may need a factory-trained technician to help you with this one!! Good Luck !! Jim
Nov 06, 2012 | Office Equipment & Supplies
How do I get my messages from the answering machine ? What do I need to key in ?
If you are using the handset, press Menu and scroll down to the line Answer Machine with the up/down arrows. Then press the left soft key twice (Select answering machine and then play new messages). The left soft key is above the Talk button. Press End to stop the play back of messages. When there are no new messages, the above will play all messages.
If you want to access the messages from another phone, you first need to change the Master PIN from the one it shipped with and set up remote access. You do this from the handset.
To change the Master PIN, press Menu, scroll to Advanced Set and press the left soft key. Then scroll to change PIN and press the left soft key. Enter the original PIN (or the current PIN) and press the left soft key. Then enter the new PIN followed by pressing the left soft key twice. You will hear a tone and see New PIN Stored on the screen. If you do not enter the correct PIN above, the screen will return to the previous menu. The PIN from the manufacturer is 0000.
For remote access, press Menu, go to Answer Machine and press the left soft key. Then scroll to Ans. Settings and press the left soft key. Scroll to Remote access and press the left soft key. Use the up and down arrows to select Activated then press the left soft key again.
Once these are set, call your phone number and when the machine picks up press #. Within 8 seconds, enter the PIN. An error tone will play if you do not enter the correct code; try again. The unit will hang up if the PIN isn't entered in 8 seconds. All new messages will play. Press 1 to replay a message (or go to the previous message), 2 to play all messages, 3 to advance to the next message, 4 to delete a message.
The manual is available here: .
I hope this helps.
Jan 19, 2011 | Philips ID9371B DECT telephone
Need to reassign remote frequency for a SMC OJ44V Ceiling Fan
As long as you have the pins in the same position on both the remote and receiver, everything should work fine.
Jan 06, 2010 | Casa Vieja Prelude White Ceiling Fan
Grundig GU22DVD - Manual Instruction & cancel PIN Code
Please i have this Grundig lcd tv,model number GU22DVD,how to enter service mode to change sound standard PAL I toPAL BG,help me.
May 14, 2009 | Grundig GU19WDT 19 in. LCD TV
Navigation system
I have a 1997 Acura 3.5 RL and my remote unlock doors button dont work cause of the battary so I change the battary and it still dont work then I found out that I need a code to reset the remote also when I put the battary in the red light just stay on do anyone know about this
Oct 20, 2008 | 1996 Acura RL
Sony Trinitron 30" no remote seems to work
If you want to test the voltage you can do so at connector CN002 on the main board. You should have 5 volts DC at pin 4 and at pin 5 marked SIRCS (sony infared remote control system)should be 5 volts as well but, will drop to about 2.5 volts when any button is pressed on the remote. If it doesn't change then you should change the HR board wich houses the IR rec. and associated components.
Jan 25, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Vehicle Parts & Accessories Logo
23 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
