Lid is stuck arrows going the wrong way - Washing Machines
I have the Ninja Kitchen System 1100 and the only way I've found to lower the handle on the lid is to simultaneously depress the two white "tabs" at the base of the handle. This is awkward at bes
Make sure you have the arrow on the handle in alignment with the arrow on the lid. Press down securely before closing the handle.
Jan 16, 2013 | Vacuums
The power button is flashing red in my ninja nj600
Arrow on lid, Arrow on handle. Line them up. I just did it. I knew it was something simple but I didn't think it would be that simple.
May 29, 2012 | Euro-Pro Ninja NJ600 Pro Blender - NJ600
Staples are stuck inside the stapler and will not come out
Typically you do not open these up.
Makes it difficult to remove stuck or wrong staples.
I have had good luck removing the staple ram rod and rapping firmly on the **** of the stapler against a wooden table. The idea is jolting the stuck staples into reverse out the way they went in. Tedious process but usually works. Removing the jammed staples in the nose at the striker plate requires using needle nose pliers and a sharp awl or small screw driver used on very small screws.
My T50 Arrow stapler is over 20 years old.
Still works great. Sometimes I slide in the wrong size staples by mistake. The process above usually works.
May 26, 2010 | Arrow T50P ARROW STAPLE GUN
Harley transmission stuck in 3rd gear
The only way to tell whats wrong is to remove the trans top or ratchet lid and look whats going on. Chanses are it's something in the shift mechanism.
Apr 11, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
Lid is stuck in "down" position on the right only.
k the only thing you can do is try starting then stopping each drawer to see if the lid will go back up if not it will even be a hard one for the serviceman. you can't swap the wires like you've done it will cause large problems like a jammed lid sorry.
Mar 21, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Wrong Region
This will make the player multi-region:
Switch on player
Open DVD lid
Press setup on the remote
Select preferences
Press 2,5,2,3,1,5
Press LEFT arrow
Press DOWN arrow
Press 0 for multi region
Press setup to exit
Mar 30, 2008 | Philips PET710 Portable DVD Player
Carriage hits the right inside of printer - will not print
if the lights are flashing along together there is a cariage stall. The ink cartridge craddle is hitting something. Find out what and remove it if doesn't belong there. First of all remove and reinsert both cartridges. One of them may be inserted wrong.
Mar 19, 2008 | Office Equipment & Supplies
Ink Cartridge
Make sure the power is on when you open the lid. The cartridges should move into the center so you can get to them. If they don't, close the lid, remove the power supply and reinsert it. Turn the printer back on and try again.
Sep 23, 2007 | Lexmark P4350 All-In-One InkJet Printer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
