Need old fashioned typewriter and local location to pick up
3 Suggested Answers
  • 3594 Answers
SOURCE: Missing power cord
There are basically 2 cords one loks like a figure 8 with 2 wires the other is 5 sided and is very common on computers and printers and should be easy to find. The "8" cord is available from us for 9.95 + shipping
DickyO
216-241-0027
Posted on Apr 29, 2009
cautionflag1
  • 116 Answers
SOURCE: Required manual typewriter
I see quite a few at flea markets and thrift stores. They are usually pretty cheap there. You can also find refurbished ones on Amazon.com and probably a few other sites.
Posted on Apr 26, 2010
Keyboard
check to make sure your numlock is off. otherwise check your keyboard language and make sure its set to US. on windows this is usually a little symbol located in the bottom right hand of your desktop.
Jul 29, 2013 | HP Computers & Internet
Tape wont register on this after we changed the tape
U.S. Office Machine Co., 5722 N. Figueroa St., Los Angeles, CA 90042. 323-256-2111. "We specialize in the repair and restoration of all your old typewriters, and we have a very large selection of parts and supplies. We have been in business since 1962 and have had many satisfied customers." One customer writes: "The guy who owns the place is a WW2 veteran named Jesse Flores. He's been there 46 years. His son Danny handles most of the repairs now. They also repair the old fashioned adding machines and mechanical calculators. Around Christmas, he gives out toys to needy children and has helped organize the local Christmas parade in the past and such. The building he is in used to be a theatre back in the 1910s, and the fellow has photos of him with every coucilman and mayor, as well as Senators and national politicos from the early 60s to the present, on his walls."
Mar 25, 2008 | Sharp EL-2196BL Calculator
Need pick up of old air conditioners at my home in Meriden,Ct.
If you're just trying to get rid of it and it still works. Contact your local Goodwill Store or the Salvation Army location. They' pick it up and you get to write it off as a tax donation.
May 16, 2011 | Heating & Cooling
The correction tap will not pick up all ink?
When the correction dosen't work the ribbon and or the correction tape are old. Put a fresh ribbon and correction tape on. Not one that has been sitting on the shelf for years.
DickyO
Nov 11, 2010 | Brother ML-100 Typewriter
Apr 01, 2010 | Olivetti Lettera 35 L Typewriter
Missing power cord
DickyO
216-241-0027
Apr 28, 2009 | Olympia Mastertype 3 Typewriter
Olivetti lettera 22 replacement black/red ribbon ?
Try Office Depot or one of those big box office supply houses.The Lettera 22 is a pretty old typewriter, but the ribbons ought to be available
Mar 19, 2009 | Olivetti Lettera 25 Typewriter
LASER UNIT FOR SHARP AL-1010
GO ON LINE SHARP AL-1010 LASER COPIER SCHEMATICS.
OR THE LOCAL LIBRARY TO INDUSTRAIL COMMITION STANDARD COMMITION, THE BRANCH OF THE COVERMENT THAT REGULATES THAT PRODUCT SHOULD HAVE THE SCHEMATICS OF THE COPIER OF A DEALER OF THE EQUIPMENT SHOULD ALSO HAVE THEM ON MICROFISH, OR KNOW WHERE TO LOCATE SUCH THINGS, OLD TYPEWRITER REPAIR SHOPS MAY HAVE IDEAS WHERE TO LOCATE THAT DOCUMENTS AT
ROD
Feb 09, 2009 | Office Equipment & Supplies
I want to find a location to service my machines. I live near kipling and eglington in west toronto
This LINK is a local Toronto Directory, there are several Sewing & Service Shops listed...........or just try the Telephone Directory , old fashioned, but may still work !?!?!
Jun 24, 2008 | Singer 7462 Mechanical Sewing Machine
Old remington typewriter
G'day mate, most likely cause is that the drawband is broken/disconnected. Look under the right-hand side of the carriage,you would have to tilt the typewriter on it's back. There you will see a small hook where the drawband should be attached to. If not, set the typewriter on it's feet again and move the carriage to the extreme right then looking down past the left thumb wheel you will notice a drum with the drawband attached. Rotate it until the drawband hook come into view. Get a piece of strong wire about 12 inches long,fashion one end into a hook,thread it through the machine under the carriage,from the right-hand side until it appears just over the drum. Ayyach the drawband hook to it and pull your piece of wire out to the right. You will notice the drum rotating and the increasing tension on the drawband , this good,nothing is going to snap, break etc. Hook the drawband on to it's latch and try the typing. If the typewriter's carriage moves slowly it means that there is not enough tension on the main-spring located inside that drum. Do not depair, because by removing both side plates you will see a large screw on each side of the back cover plate remove these and then you will see the mainspring drum in it's entirety. There will be a winding gear central to the drum,loosen the locking pawl and begin winding in aclock-wise direction to increase the main-spring tension. Test the carriage occasionally for tension.
When all is OK reverse all what you did before.  Cheers and goo luck from Australia....
Oct 11, 2007 | Office Equipment & Supplies
88 people viewed this question
k24674
