Question about Cell Phones
I've turned volume off in settings some how what can I retrieve
CHKDSK /r fails to complete to resolve Hard Drive Error 2000-0142 / 2000-0146
This is a regular problem on Win XP computers. They are old so the hard drive is also old. You may need to do a reinstall of your operating system. But you could try running RKill first it is a rootkit killer. This may find the problem in your software, but don't hold your breath, With chkdsk failing it is a reliable indicator of a physical failure on the hard disk. You need to consider that a hard disk is metal plates spinning very fast and while they are designed to take some knocks, over time a laptop takes more knocks than you would expect. The plain truth is, stuff breaks and need s replacing.
May 01, 2013 | Dell Latitude E6500 Laptop
The volume is half as loud as it use to be. How do I fix this?
right click on the volume speaker at the bottom right of your desk top ads press sound or playback device select the sound you are useding.go to properties select levels and turn it up this should help.
Aug 13, 2012 | Insignia Televison & Video
Muted my sharp le 810 and now i can't retrieve the sound
If you push the volume button on set does it show on screen?
My guess would be the sound may be turned down on the box or tv or maybe in the TV menu the speakers may be turned off.
Does not sound (pardon the pun) like a circuit repair but like an error.
Check all audio settings or options first in the set and then the box.
Mar 21, 2012 | Sharp Televison & Video
I have a 6th generation iPod Nano. This is the fifth one I've had and they all have had the same problem. At some point (usually after I've had it about a month) it starts to turn the volume down...
The only thing I can think of is that maximum limit has been set low and is somehow lowering itself. To set the maximum limit
On the home screen, tap settings
Tap Music, then tap Volume Limit
The volume limit control will then come up to raise the limit move the slider all the way to the right.
If you want to stop the volume limit moving you can put in a passcode by clicking on the Lock Volume Limit and entering a passcode (I'd just put in 1234, so you can remember it easily(
Hope this helps.
Sep 07, 2011 | Apple iPod nano 3rd Generation
My four year old was messing witht he bottons on the front of my Apex AT2702 television set, and not all it shows is a blue screen with a key symbol in the bottom left hand corner.
Hi
There are 7 buttons with its front panel including power ON/OFF switch button.They are; From left to right:- Video, Menu, Volume(-ve), Volume(+ve), Channel(-ve) and Channel(+ve). If these buttons are not there, it will be difficult to operate this set without a remote control. If you haven't the remote contro with you now, buy one universal remote control. The universal remote control suited for this set is COMCAST ON DEMAND CUSTOM-3 UNIVERSAL REMOTE control. The setup codes are:-
0748, 0765, 0767
OK.
Jul 11, 2011 | Apex Digital Televison & Video
New hyundai i30 has clock set to wrong time. the manual gives instructions to re set the clock for a different radio/cd player model to the one i have. mine does not have a SET UP button. in its place it...
Press the radio on button and hold down.
A menu appears, displaying Adjust Initial Volume, release the power button.
Turn volume button to the right to display the Clock menu item.
Press the power button to select the Clock Menu item.
Rotate the volume button to adjust the hour.
Press the power button to move to minutes adjustment.
Rotate the volume button to adjust the minutes.
Mar 17, 2011 | Hyundai Accent Cars & Trucks
Volume Issue with CD Player by Durabrand.
it just seems a setting problem.
go to AUDIO SETTINGS or MENU.it will have "ON VOLUME".
press volume control -ve to get desired volume.
press AUDIO or MENU to store volume level.Next time u turn it ON ,the volume will be what u SET. OK i hope this solves your problem.
Mar 24, 2008 | Audio Players & Recorders
TV PROBLEM
I don't know your set in particular:
Genericaly, there are some models of sets that have a pre-set level for the sound. Check in to the menus of the set if there is a setting for the audio level at turn on.
Some manufactures designed their sets so that the sound is at about 30% up when the set is first turned on. This is annoying. They did that because they had people turn on the set and call their tech support that their set had no sound. It turned out that the volume setting was at "0"!
Jerry G.
Nov 21, 2007 | Philips 28PW6506 28" TV
Password retrieval
There?s not much you can do. Try to put the router?s default password which is ?admin? (lower case) and then copy the settings so you can reconstruct them after the reset of the router. Hope it works good luck.
Feb 22, 2006 | Linksys Wireless-G Access Point WAP54G...
Password retrieval
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
