Question about Dryers
When I turn heat surge on high it runs for about 5 minutes and shuts off. what could be problem
5 Suggested Answers
SOURCE: Runs for 5 minutes then shuts off.
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
Posted on May 14, 2009
  • 530 Answers
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Posted on Jun 21, 2009
  • 73 Answers
SOURCE: lightning strike power surge partially disabled dryer.(Whirlpool)
If it took a lightning strike something in the heating coil is shorting to ground tripping the breaker. DO NOT Keep trying it, you could cause more damage or even burn your house down.
Posted on Oct 02, 2009
  • 82 Answers
SOURCE: Keeps shutting off after 5 minutes
You have a bad motor. Part number is 279827 retails for $112.78. UNPLUG THE DRYER. You change it from the front of the dryer, lift the top with a putty knife from the front, pull the front off held with 2 screws on the inside and take the belt and drum out and you will be looking at the motor.
Posted on Dec 13, 2009
Hotpoint Condenser Dryer Shuts Off After 5 Minutes
what is your model number is then we can get started then okay
Feb 01, 2013 | Dryers
The heater does not stay on long enough to heat my garage. it will come on for 3 to 5 minutes and shut off. it comes on again in 5 to 10 minutes for 3 to 5 minutes again. the heat is good when it runs....
You could tripping the high temp limit this will be located near the heat exchanger When it shuts how long does the blower motor stay running? Do you have a meter?
Dec 15, 2010 | Fahrenheat FUH5-4 Heater
I have a Lennox model CB19-51-1P air handling unit with HP19-511-1P compressor heat pump unit. I just turned the heat on for the first time this season. And I am getting low heat volume. The heat pump...
first thing you need to check is if the reversing valve is working you maybe running your A/C with the heat strips on depends on the t-stat your using some heat pumps will bring the strips on with a high degree difference in setting and room temp .
1- turn t-stat to heat set temp 10 degrees above room temp if you have a programable t-stat it will have a time delay on it allow to for the outdoor unit to come on 2 to 5 minute usually .
2- walk around to the outdoor unit when it comes on feel the big line the insulated one and see if it is hot or cold let it run for a 5 minutes peel back the insulation and gently grab the line with your hand it maybe real hot so be careful if this line is hot then your heat pumps is working mechanically and if it is just warm then you may need the charge topped off
there are so many different option's from this point i will need to know the findings of this test first thanks : Michael
Nov 16, 2010 | Heating & Cooling
'98 S10 4 cyl. 5 speed: Sudden high idle, now surges.
Go to your local shucks or auto zone and they can check any codes behind your check engine light and it's free. It sounds like one of two things a O2 sensor or your mass airflow sensor but they will tell you for sure
Oct 02, 2009 | 1998 Chevrolet S-10 Pickup
Honda GX160 runs fine for 5 minutes then dies like out of fuel.
I would look for the fuel filter. Blow it our. I know you have a new tank of gas, but you might want to empty it out and make sure the clean and put in new. Even with Stabil in the gas you might just have to much condensation in the tank
Sep 07, 2009 | Master Heaters MASTER HONDA POWERED...
Jun 21, 2009 | Dryers
I have a D52W20. The set turns on and then shuts
i have the same problem with my set.i placed a box fan behind the set and that seemed to solve the problem if u dont mind noise of the fan blowing
May 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My car surges after running for 10 minutes when I put it in parking or drive can you tell what is wrong .
Here is the most common cause of surges and stalls and low idle, it is the idle speed control air-bypass valve and throttle valve, they get full of gunk over the miles and cause idle issues (stalls) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Nov 05, 2008 | 1991 Ford Escort
Pioneer pro -200 60 in
Since the set needs to be diagnosed you have to take it into a repair shop.
Your specific problem indicates that a component is heating up then opening or closing to it's natural state. It is not a fuse or resistor. Obviously fuses can be reset or new one put in but when it comes to the smaller elements (resistors, transistors, capacitors) if they "pop" they are destroyed, so since you can turn the set on later this should not be the case.
For a power surge just use a surge protector to see if this remedies the situation, not to mention they help keep the set "healthier" due to brown-outs, etc.
You could also open the back up and watch what happens - see if there is a flash and get back with me. But a word of CAUTION, there is high voltage, so don't touch anything inside when the set is on or for at least 5 minutes afterward (let the capacitors discharge).
Jeff
Feb 28, 2008 | Pioneer PRO-200 60" Rear Projection...
Dryers Logo
Top Dryers Experts
