Question about Kitchen Ranges
How to fix an overheated oven stove with the model S2620-1?
Where are fuses in Kenmore stove C970
Stoves generally do not have internal fuses they rely on the house circuit breaker to protect the circuit. Some stoves have what is called a thermal fuse. These can trip when the oven or broiler has overheated. Some are located on the back panel and some are located on the top panel under the top of the stove. Since this is a smooth top model there may be one on the back panel. More than likely there is a problem with the oven control circuit possibly in the electronic control. The relays can go bad on the control and the oven will not work.
Oct 11, 2014 | Kenmore Electric Smooth Top Stove
Oven overheating
Your thermostat is STUCK. Replace. Your 'tripping mains' is your clue that your power is over loaded. Have an electrician check your boxes to make sure all is ok AFTER fixing stove.
Mar 03, 2014 | Electrolux EOC6690X Pyrolytic Electric...
Stove overheated and started smoking. heat element got extremely red. is stove worth fixing?
If the element hasn't deformed it should be ok to get fixed, but you may want to test the insulation first just to be safe.
Jul 08, 2011 | Ovens
Oven went last night after tripping fuse when flipped back on stovetop works but oven doesn't how do i fix this issue
there are often fuses on the oven somewhere.if u can type your stove model into google and get schematics for your stove it should show u where they are on your stove. hope this helps
Nov 11, 2010 | Ovens
My kenmore electric range model 790 is displaying a F10 code which i believe it means it's overheating. can you help with this problem
Frigidaire stove
(F10 only) Check RTD Sensor Probe & replace if necessary.
If oven is overheating, disconnect power. If oven continues to
overheat when the power is reapplied, replace EOC. Severe
overheating may require the entire oven to be replaced should
damage be extensive.
Feb 04, 2010 | Kitchen Ranges
Stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Aug 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
