Question about Garden
Fisher snow plow
Have a fisher xtreme v 5 years old was fine now not working no up down or side to side hand controller lights up and power light goes on
3 Suggested Answers
SOURCE: Lights on a fisher xtreme plow wont work
Check your harness plug ends for broken pins. Also the isolation module could be defective
Posted on Feb 07, 2012
lpfaff1
  • 11573 Answers
SOURCE: why does hand held lose power then come back on during plowing, and raising and lowering the plow ?
Sounds like wiring, check and clean all connections, check for pinched, bare or broken wires
Posted on Jan 25, 2016
I chang fues still no power fisher minit plow 2005 gmc plow work fine last year put on now no power to control box
May want to begin tracing the wiring harness from the plow all the way to the control box.
Dec 23, 2016 | GMC Cars & Trucks
Plows goes up not down
Fisher has a lot of info on there site. Maybe look through some of the guides and wiring diagrams to see if you can figure it out.
http://library.fisherplows.com/
Jan 20, 2016 | Fisher Minute Mount Plow Joystick...
Off/on light is flashing on HT handheld control and nothing is working on fisher plow but the headlights
joystick controller is saying its not connected to plow valves or pump , this happens a lot due to plug corrosion , using a squirt or two of "electric contact cleaner" in both sides of plugs helps with this
Jan 19, 2016 | Fisher Minute Mount Plow Joystick...
I have a minute mount plow, when I try to use it only goes to left and right side but doesn't go up, when I try to lift the plow goes to the right. What can I do
2002 Fisher Minute Mount Inst-Act Wont Angle [Archive] - PlowSite ...
www.plowsite.com > ... > Truck & Equipment Repair
Nov 17, 2011 - 90 posts - ‎9 authors
My plow went up it was jerking and did it in steps , but , it got there . Now , it onlyjerks when i try to angle it right or left or up . I filled the fluid ... Drop it and if it doesn'traise you can just use a jack and shorten the transport chain to hold it. .... I do havecontinuity on the plow side for all 3 wires going to the plug . Hooking Up A Fisher Minute Mount 2 In Under 1 ...
Feb 1, 2011
Plow Wont Angle
Oct 19, 2010
What's wrong with my plow?
Jan 9, 2003
Looking For Minute Mount Tips
Feb 13, 2002
More results from www.plowsite.com
Ultramount Intermittent Angle Problem - Snow Plow Forum - L
Dec 27, 2015 | Cars & Trucks
My fisher plow control unit will not turn on
I have the same problem, I do see the power light come on when I hit the key to start the truck but it goes out when I let off the key. If I park it in the garage with the furnace on it stars working and is fine until I don't won it for a day or two then its dead again. No idea why control is dead or sitting in garage with the heat on gest it working.
Dec 31, 2012 | Cars & Trucks
Fisher plow gets power to lights but wont lift or turn, Any ideas?
Fisher needs a good contact loose contact start from the battery and work your way around everywhere theirs a connection
Dec 28, 2012 | Fisher Minute Mount Plow Joystick...
I'm guessing that you have already checked to make sure there is power going to the plow lights. If not use a test light and make sure. The most likely problem is the grounds from the plow lights themselves to the frame. Take the lights apart and check and/or replace the grounds, wires inside the case take a lot of vibration and that can cause them to fail.Don't forget to check the bulbs to be sure they're good too. Hope this helps.
Dec 17, 2009 | 2007 GMC Sierra 2500HD
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
