Question about Watches
What are correct buttons to press for on/off - Watches
  • Les Dickinson
    Les Dickinson Dec 16, 2016
    Hi Lucille Nicol, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Set timax watch WR 50M 1440sports
Hi jay_jolene,
You can change the time your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
Jun 03, 2011 | Timex 1440 Nylon watch
How to adjust time
Hi rina15luigi,
You can adjust the time your Timex watch by following the steps below.
Hope it helps.
Apr 11, 2011 | Timex 1440 Nylon watch
I am having trouble setting time
Hi stowell522,
You can set the time of your Timex watch by following the steps below.
Hope it helps.
Mar 18, 2011 | Timex 1440 Nylon watch
How to set the time
Hi cglines,
Hope it helps.
Mar 15, 2011 | Timex 1440 Nylon watch
How do i set time
Hi rwhit41,
Hope it helps.
Set time
Hi wimberlf,
You can easily change the time of your Timex watch by following the steps below.
Hope it helps.
Feb 27, 2011 | Timex 1440 Nylon watch
Can't set the time
Hi fseagrav,
Hope it helps.
Nov 11, 2010 | Timex 1440 Nylon watch
How to set to 24hr mode for timex 1440 sports
Setting My Timex 1440 Sports Watch (4-button)
8. Press bottom left button, time format flashes ( now it can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
Feb 04, 2010 | Timex 1440 Nylon watch
Set time on timex 1440 sport
Hi wedgemason,
Hope it helps.
Nov 28, 2009 | Timex 1440 Nylon watch
SET THE TIME
: 1. With the time and date showing, press the top left button. 2.Press the right top button (this sets seconds) 3.Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm). 4.Press the bottom left button, minutes flash. Press the top right button until correct minutes. 5.Press the bottom left button, month flashes. Press the top right button til correct. 6. Press bottom left button, date flashes. Press the top right button til correct. 7. Press bottom left button, day flashes. Press right top button til correct. 8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished). To turn off the chime and alarm, press the top right button repeatedly until the CHIME or CH symbol is gone, then press the left top button. Repeat for alarm but watch for the bell icon or ALARM or ALM to disappear, then press the top left button.
Feb 16, 2008 | Columbia All Sport watch
Watches Logo
16 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
