My IDE CD-ROM drive does not show up in BIOS - Computers & Internet
    Top Expert:
  • Computers & ... Master
  • 12,962 Answers
Try another cd rom unit - if it also does not show up you have a mo bo issue. If it does show up your original unit is bogus.
Posted on Dec 17, 2016
Joed911
  • 4338 Answers
SOURCE: install sata drives on abit av8 motherboard (vista home)
Right click on my computer, click on manage. Then on Disk Management. See if the drive shows up . If it does you can format it by right clicking and select format.
Posted on Sep 28, 2008
  • 2427 Answers
SOURCE: IDE Drive not found on startup
I am assuming that the cd and DVD drives are on the Ide right ?? thats because one of the drives jumper is set wrong. If you take a look at the back you will find it saying master / slave / Cable select with eighter a 6 to 10 pins. basically one needs to be set to master and connected with the top piece of the cable and the other set to slave and connected with the middle of the cable. and the other jacks into the main board. If i misunderstood you please respond correcting me as soon as possible so i can be of further help.
Posted on Nov 13, 2008
support793
  • 81 Answers
SOURCE: Dell Dimension 8200 turns off in BIOS
If the dianostic lights A & D are yellow an IDE bus failure has occurred. Reseat the IDE cables at the motherboard and drive(s). If this does not resolve the issue you may need to contact Dell for a motherboard repair or replacement.
Posted on Mar 18, 2009
crapiemael
  • 241 Answers
SOURCE: Dell Dimension 8300 - Can't Boot from XP Disk
When in doubt do without, that is remove the new hard drive cable and power, remove the DVD drive and try loading booting the XP from just this CD device. Enter the BIOS and check if the system sees the device. If it's not found in the BIOS then you'll never boot anything. Address it as the Primary device on the cable (I don't use CS) and see if the BIOS sees it.
If you get CD device seen in the BIOS then try to boot the CD in it. If it boots then power off and connect up your 40gb drive (optioned as Primary) on the other cable. Now power on as check the BIOS for the drive and the DVD device. If both are seen then boot the cd and try to load XP. After it's up and running install the other CD device as a Slave on one of the cables.
Posted on May 28, 2009
  • 3940 Answers
SOURCE: Hard Drive Upgrade to Dell Dimension 3000
Try this Boot to the BIOS
press ALT+E (single Beep)
ALT+F another beep
ALT+B system will reboot and re-detect drives
once done, you should be able to install XP on HDD
Posted on Dec 30, 2009
Dell poweredge 830 cd-rom unknown bios
Enter the set up (BIOS) menu by tapping the F2 key. Hold down the <Alt> key and depress the <E> then the <F> keys in succession. This will force the motherboard to load default settings and also force the motherboard to redetect all IDE devices. Note: The selection for the floppy drive will be set to ON. If you do not have one then you must disable floppy in set up (BIOS) menu.
Apr 13, 2012 | Dell PowerEdge 830 Server
SUPER X5DPA-GG mainboard doesn't find connected ide hard drive. All bios and mainboard drivers are current. Board finds cd-rom in ide 1 and 2 but wont read any hard drives. IS THE MAINBOARD FRIED. IDE...
Never put the CD on IDE 1
The IDE hard drive should always be alone on the first IDE channel.
CD-ROM drives can slow down the transfer rates and cause other screwups, and so they should always be on IDE2 or as high as possible (Add in Cards)
Sep 05, 2010 | SuperMicro X5DPA-GG (672042882748)...
My samsung cd-rom sc-148c drive is not working. It is not listed in "My Computer". I have uninstalled and reinstalled it but that does not work.
Is the CD-ROM drive on a separate cable on the second IDE controller on the desktop motherboard? Then the jumper setting can be set to Master or Slave if no other drive is connector to this cable.
If the CD-ROM is also on the first IDE controller and IDE cable as the hard drive then the jumper setting on the CD-ROM must be set to SLAVE because the hard drive would be jumpered as MASTER.
Check the BIOS setting to see if the CD-ROM drive is detected.
If the CD-ROM still does not work after you checked and configured the CD-ROM drive, then is is faulty and needs to be replaced.
Dec 16, 2009 | Samsung SC-148 CD-ROM Drive
Vt82c693a motherboard cant show ide hdd in award gui bios check
There may be a need to check the Jumper settings on the IDE drive, I would make sure the jumper is in the master setting and also to try to keep the cd rom connected also when you boot it up again.
Blessings,
A/V Media Guy
Nov 21, 2009 | Computers & Internet
Vostro 1510. CD/DVD-R doesn't show up in the BIOS or 'My Computer' Is this a bad drive or can it be fixed?
If it is a normal IDE type of CD/rom drive it may not show in your BIOS. It may just need to reinstall the driver once up in W**dows.
Oct 31, 2009 | Dell DVD-rom DVD Drive
I've lost the connection to the E: (CD-Rom) drive to my computer. What needs to be to done to get it back?
go to start>>right click on my computer>>manage>>device manager>>dvd/cd rom drives>>disable and then enable ur driver and u'll get it back
plzzz rate
Oct 15, 2009 | Computers & Internet
No matter what i do cd rom not detecting
check whether the powe plug has been inserted properly and the power plug is working fine. Even though if the power plug inserted is working fine and CD ROM not detecting means CD ROM was damaged.
Sep 04, 2009 | Intel Motherboard
Setting up gigabyte ga-686lx3 verion motherboard
Here's a link to where you can get the manual free and it will show you the jumper options and all. Hope this helps.
http://www.motherboards.org/mobot/manuals/Gigabyte/GA-686LX3/
Mar 29, 2009 | Gigabyte 440LX (GA-686LX3) Motherboard
ASUS P5S800-VM Motherboard configuration
Serial ATA drives are pretty much plug and play. You just need to install them and set them up as a primary drive in your bios settings. The IDE devices can be connected on the same ribbon cable but need to have jumpers set on the back to determine which device is primary or slave. If the IDE devices are on different ribbon cables then most likely the hard drive jumper setting should be set to master or master (single drive). The CD-ROM drive jumper on master. BIOS should detect all drives You also need to assign the boot order in BIOS. CD-ROM should be the first boot device to load and install the new OS onto the primary hard drive.
Mar 20, 2009 | ASUS P5S800-VM Motherboard
Computers & Internet Logo
David Payne
David Payne
