Question about Cell Phones
Ig k8 phone I changed phone screen. Now when phone is turned on it just flashes until turned off. What can be the problem?
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: My screen isn't turning on there's a flash but
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_2_2012_2_20_11_pm.jpg
Posted on Apr 02, 2012
Google com
You used to have your homepage set to the Google IG page (that's what the /ig part is), which Google discontinued last September. It may have continued to work for a while after this because Google probably didn't get round to removing the page from their server immediately - either that or they possibly temporarily re-directed it to the normal google search page in the hope that people would eventually change their home page.
You need to go into the settings page - on Chrome enter into the web address bar chrome://settings
In the settings you'll see a "On start-up" section and there will be a radio button with the following option selected "Open a specific page or set of pages. Set pages".
The set pages will be blue - click that and in there you should see a line that says
http://www.google.com/ig?hl=en&gl=us
you just need to change that to http://www.google.com (remove the /ig?hl=en&gl=us bit at the end - the ig bit just tells google to go to ig and the hl bit tells it to use English language (en = English), and the gl but tells it to use Google US, but these aren't necessary as by default google.com is English, US, if you did want a different google for example googe uk just change http://www.google.com to http://www.google.co.uk
Also once you've done this in the Appearance section of the settings screen there should also be a tick box which has "Show home button" if that's ticked then you might also need to change the URL under that, just click on change next to the URL again and remove the same bit off the end of that url.
I've added an image below with the important bits that need changing, if your using another web browser other than Chrome then you need to follow that browsers procedure for changing the homepage (it should be somewhere in options)
Sep 03, 2014 | Google Computers & Internet
Flashing samsung sch-e189
My Samsung SCH-E189 tells me to insert UIM card but i want to flash the phone please, if i flashed the phone will i be able to use sim card?
Jan 27, 2014 | Samsung Cell Phones
My wyse laptop turns on but my screen stays black
try undo things..if problem solved then,try use different cards
May 17, 2012 | WYSE Winterm V90LE Thin Client - Thin...
I have an lg Rumor 2 phone. It is supposed to automatically lock the keypad and turn off the screen when it is idle. It does that but within 2 seconds it turns itself on again with the screen on and the...
Hi, when a phone randomly Switches off, it means that the phones memory is faulty or when an application you downloaded has virus.
What to do is this,
You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Jul 02, 2010 | LG RUMOR Cellular Phone
I have a EVGA 133-K8-NF41 mobo and want to update my BIOS but can't find what the latest would be and the flash utility for it. can you help?
forum topic: http://www.evga.com/forums/tm.aspx?high=&m=63702&mpage=1#65116
direct link to bios: ftp://ftp.evga.com/BIOS/NF41_E61.exe
Feb 25, 2010 | Evga 133-K8-NF41-AX Motherboard
USB Power Issue with ASRock K8 Combo m/b
Are you plugging in to the usb ports on the MB, or on the case?
Jan 14, 2008 | Asrock K8 Combo-Z Motherboard
I push the on button and the screen flashes for a second and turns off
Dear Friend,This problem may be caused due to insufficient power supply problem. so you need to charge your phone carefully . if possible try to change the phone battery and charger.
Aug 11, 2007 | Motorola Mobility RAZR V3
Flashing verizon wireless screen
YOU need to take the phone and ahve the firmware reflash on the phone.
Jul 14, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
