Trying to find schematics for a diplomat APM 8513/2. need to change the timer
    Top Expert:
  • Washing Mach... Master
  • 37,897 Answers
Request the diagrams directly from Diplomat.
Posted on Dec 16, 2016
Have a diplomat apm 6842 how do you defrost freezer
the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
Mar 23, 2015 | Refrigerators
Diplomat washing machine
Try Sliding the Soap Dispenser Drawer Lock to the RIGHT and then pull straight back... It is located under the handle
Mar 03, 2014 | Washing Machines
Defroster comes on every time fridge starts running. Make: Danby Diplomat
Defrost timer may be bad stays on all time try pulling one wire off the timer and see if it starts without defrost on
Jul 16, 2010 | Danby Refrigerators
Diplomat 8702 how to use drying cycle please
set the timer, press the half load wash button, and then turn the dial just before the sun, it will spin for a while and when it actually goes to the sun it will start drying - I just solved this problem after a month and its horribly annoying
Aug 31, 2009 | Washing Machines
How to change the starter on an 87 dodge diplomat
Disconnect the battery negative terminal. Remove the one large and one small wires from the starter. Starter is secured to transmission with one bolt and one nut/lockwasher. I think they are 9/16" fasteners.
Jul 01, 2009 | 1987 Dodge Diplomat
Amplifier schematic diagram
Hi Janet,
If you get back to me with your email address I will scan the schematics and email them to you.
Regards
Alan Hood
ami-man
UK
alan-hood@datex.co.uk
Mar 13, 2009 | Wurlitzer Jukebox 1015 One More Time...
I have a Lang Ecoh-ap-2080r (Dennys Restaurant) im trying to find part number for Timer
If your model # is ECOH-AP208DR, Electric Half Size Computerized Convection oven, the timer is as follows: 2J-30800-05 Timer Elec. 1hr 24V. Please check the time range of 1 hour and voltage on old timer be insure this is correct.
Dec 09, 2008 | Lang Manufacturing EHS-APM Electric Oven
Diplomat washer drier
all you have to do is:
select half load
set drier timer to required time. set main timer to dry program
i suspect you are not pressing half load button - this is essential
Jul 20, 2008 | Washing Machines
I have a Diplomat APM 8702 integrated washer / dryer, it has decided to stop working! its been great but does get used alot, the electrics come on, ive checked all the connections inside the machine made...
I have one of these machines. I don't know whether this will be of any help but I had issues of the machine not activating a final spin and the clothes being left sodden once the cycle had finished. The engineer replaced the PCB module at the rear of the unit which fixed the problem. If your APM 8702 is not even starting I'd guess its a motor problem and time for an expensive repair or new washing machine.
Apr 26, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
