Question about Humidifiers
I need part# M-G.3102 for my V3100 humidifier . Please help
5 Suggested Answers
SOURCE: Vicks V3100 1.2 Gallon Humidifier leaking
Check if the cap has a gasket or o-ring and is not worn. There are two designs for this model. The older model has the fill cap and valve together. The new design the fill cap and valve are at different locations. The new design has no hole in the bottom of the unit.
You can fixed the problem using a 1-1/2 inch washer for brass tubular found in the plumbing isles in HD or L. The rubber washer is 1 or 2 mm smaller then the grooves in the fill/valve cap. You can stretch the washer and it will fit perfectly in the grooves. When putting the fill/valve cap back with the washer, it will be tighter then before. Firmly turn and you should not have any leaks and make sure unit is level. You can plug the hole because the new design does not have a hole in the bottom of the unit.
Posted on Feb 05, 2009
SOURCE: Vicks V3100 Humidifier
http://www.kaz.com/kaz/support/manual/?ProductManualAction=renderProductManualById&ProductManualId=285ef863f85db2982e6f095560687917
  • 74 Answers
SOURCE: how do i take apart and clean my Vicks V3100 cold
couple of screws on the bottom, but why take it all apart when you can probably run vinegar through it and let that do the work, smells a little, so maybe on the porch...
Posted on Feb 28, 2010
  • 5370 Answers
SOURCE: v3100 kaz humidifier leaked, water
If water leakage occurs: • Check to be sure the tank cap is tightened properly. • Check the tank for leaks and replace if necessary.Check the water valve and water tank cap.If the valve or cap any of this is loose the water will leak. Fill the Water Tank with clean, cool, tap water and replace the Tank Cap by firmly turning clockwise. Turn the tank upright and check Tank Cap for leaks. If any water drips from Tank Cap, remove it and re-tighten. Make sure the circular rub cap Gasket (o-Ring) is in place when replacing Tank Cap - this prevents water leakage. ------------This should help.Thanks.Helpmech.
Posted on Dec 21, 2010
A seal for the cap for the 1.0 gallon humidifier
ck with ace hardware or hardware,they should be helpful.
Jan 06, 2011 | Vicks V3100 1.2 Gallon Humidifier
How do i take apart and clean my Vicks V3100 cold air humidifier?
Feb 27, 2010 | Vicks V3100 1.2 Gallon Humidifier
Just bought a Vick's V3100 Humidifier. When I turn it on the fan starts up but then sounds like it bogs down and stops.
the fan is not working properly it is defected,return item back to store or factory,if can you will have to repair but cost more then item.if my info was of help to you please leave a comment,vote,note.thankyou
Sep 09, 2009 | Vicks V3100 1.2 Gallon Humidifier
New filter,still no mist and water level does not drop
make sure that the filter is VERY snug into the bottom of the humidifier, and that the tank is on correctly. We had the same problem :)
Jul 01, 2009 | Vicks V3100 1.2 Gallon Humidifier
Vicks V-3100E Filters
Here is a site that stocks the filters you require, but needless to say it is main order.
http://www.healthcare4all.co.uk/vicks-filter-aca3e-v3100-p-330.html?osCsid=168dab22ab1bfeb75a4095d3d6e51127
Vicks Kaz Filter ACA-3E for V-3100
Availability: In Stock (for immediate despatch)
[ACA3E]
£9.79
(incl. VAT at 15%)
Regards
Alan Hood
ami-man
UK
Jun 16, 2009 | Vicks V3100 1.2 Gallon Humidifier
Sep 18, 2008 | Vicks V3100 1.2 Gallon Humidifier
Missing part
http://homeappliance.manualsonline.com/manuals/mfg/vicks/v3100.html
This is a link to the manual for the humidifier you bought.
It shows how everything comes apart and how it all goes together with the filter.
Hope this helps.
Good Luck.
Apr 18, 2008 | Vicks V3100 1.2 Gallon Humidifier
Crane penguin humidifier
This is the link to your manual:
http://www.crane-usa.com/manuals/HumidifierManual2008.pdf
Hopefully the manual helps you getting it to work. If not come back and give more info about the problem.
Good Luck.
Dec 26, 2007 | Vicks V3100 1.2 Gallon Humidifier
Humidifiers Logo
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
