PDF files issues on TurboTax 1-************ - Computers & Internet
How do I view my tax forms
Sorry, I don't see enough information to answer this question. But in general if you used any kind of online service to file your taxes they are also likely to have a copy of your taxes available if you signon to the same URL.
If that doesn't help you need to contact whoever it is you filed your taxes through to get a copy of the filing.
I know that both HR Block and TurboTax keep copies of the information. If you have used a "file for free" service I am less certain that they will keep a copy or let you have access to a copy. When I filed for free using Turbotax I specifically printed off a copy of my tax forms because they said I wouldn't have access to them otherwise. When I have paid Turbotax they have kept a copy of my taxes. And I know that HR Block makes every effort to keep old tax filings.
Feb 07, 2015 | Computers & Internet
Turbo tax for 2010,2011,and 2012will not let me open tax records
First it may possible that your security software such as antivirus bock that particular file so close any open programs running with security software and ten try again.
if still have same issue after this then , try
to uninstall TurboTax, and then reinstall the program. for more technical detail https://turbotax.intuit.com and need any guidance follow Intuit Support .
Feb 10, 2014 | Intuit TurboTax Basic Federal + e-File...
Quickbooks error -6000 -301
This is a network sharing issue
http://support.quickbooks.intuit.com/support/articles/SLN40085
Dec 21, 2013 | Turbotax Intuit QuickBooks Enterprise...
I completed my 2010 taxes last week, but did not submit to the IRS. Yesterday could not even open Turbotax - or run Turbotax. Have no idea where my completed tax work is! I'm resigned to spending 3h...
You can shutdown your computer and turn it back on,and log back in again. Click on start and all program, and turbo tax to see if it works. Your tax work file should still in in turbo tax folder in your C drive. Try shutdown and turn it back on first to see and let me know, and we can go from there.
Thanks
Apr 07, 2011 | Intuit TurboTax Deluxe: Windows
Getting error messages when trying to load the cd on my computer running windows xp. error message is 1334 and avg firewall comes out with a trojan virus. Is my cd bad, can it be replaced? I have been...
Hello sharon! My name is Kandi and I am an Expert with Fixya and also an Employee of Intuit. I troubleshoot TurboTax and supervise agents who handle customer service calls. I am very familiar with the error that you are talking about and it has nothing to do with your TurboTax disk. In order to install your disk, you need to remove your AVG virus software and reinstall it later when your finished filing your taxes. There is a problem with the older versions of AVG thinking that TurboTax is a virus and it will block the installation of the program. Go to your control panel, and remove AVG completely. Reboot your pc. Run disk cleanup (Start, programs, system tools & click on disk cleanup) and check all available boxes when asked. Then run disk defrag (located in the same place as disk cleanup as noted above). Then put your TurboTax disk back in your pc and try to install again. If you cannot get the disk to install, you can reach us for customer support by going to www.turbotax.intuit.com. Click on the support link and then move all the way down almost to the bottom of the page and look for the box on the right side that says "Contact us". Choose the option that best describes your problem and it will forward you to your choice of contact method (we have chat email and phone service all available at no charge to you). We are open from 5am until 9pm pst.
Apr 05, 2011 | Intuit TurboTax Deluxe: Windows
(prd.ini, startup) re-install -- is an error message that I received when I installed Turbotax Home & Business for 2010. Please let me know if you have any additional thought. Working with Turbotax...
For me, this seemed to be an issue with the PRD.INI.SIGNATURE file not being present in turbotax's 32bit folder. Typically this will be created during the install process... UNLESS it can't get access to the machine's crypto keys.
SOLUTION: Go here (http://support.microsoft.com/kb/817754/en-us) and follow the directions under "Assign the Everyone Group Appropriate Permissions to the Folder".
Jan 02, 2011 | Intuit TurboTax Deluxe: Windows
Unable to load program
did you get the right operating system for turbo tax...that might be for MAC...and you are using PC. check the system requirements...
second open the auto run file in cd using note pad..and you will see which directory the setup or install exe is.
or if you are upgrading to delux edition there might be upgrade command in your current version of turbo tax...good luck
Mar 13, 2009 | Computers & Internet
I downloaded my new turbotax product, but I cannot find it to use it.
It is normally in your temporary folder of the browser. If you are using Internet Explorer, try Tools, Internet Options, then check the temporary folders (button View Files).
Or try download something else, the destination folder for the last download may be the place of your turbotax program.
Dec 12, 2008 | Computers & Internet
Turbo tax
Go to this website http://turbotax.intuit.com/support/kb/update/update/2201.html?lid=stic double click the link maualy update your Turbo Tax hope i help you with your problem :p
PS:
or
Error 9111 indicates a connectivity issue:
An error occurred while we were checking for TurboTax updates and we could not connect to the program update system.
Your computer's firewall or other security software prevents TurboTax from accessing updates on our server. Error 9111 will continue to occur until you resolve the issues caused by your firewall.
Do one of the following:
  • To temporarily work around this issue, manually update TurboTax.
    icon_note.gif Note: Manually updating TurboTax does not resolve connectivity issues caused by your computer's firewall. We recommend you address these issues before attempting to update TurboTax again.
Still can't update? If you still have problems updating TurboTax, order the free update CD. To order, call us toll-free at 800-624-8384.
or
It's Blocked with your Firewall try UnBlock it to your firewall
for Firewall removal instruction click this link:
http://turbotax.intuit.com/support/kb/connectivity/firewalls-and-anti-virus/113.html
Feb 24, 2008 | Microsoft Office Outlook 2003 for PC
Computers & Internet Logo
David Payne
David Payne
