I have no remote for this tv it turns on light is on at the front but no screen
  • Grant Cox
    Grant Cox Dec 16, 2016
    it is a samsung la46m51b
Is there any way to turn on my RCA flat screen TV without a remote?
There might be a power switch on the front panel.
if the remote does not work, the replacement batteries could be defective or installed incorrectly.
The "light" on the front of the remote emits infra-red signals so you are unlikely to be able to see anything.
Dec 24, 2015 | RCA L37WD12 37 in. LCD HDTV
Rca model# d52w135d screen won't turn on
Are you saying that the screen goes black after the DVD player stops working?
Jan 10, 2008 | RCA D52W135D 52 in. TV/DVD Combo
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
I HAVE A HL72A650 DLP TV. AT FIRST THE TV STARTED TURNING OFF AND ON . I LOOKED ON THE WEB AND WE HAVE TRIED CHANGING THE LAMP AND THE BALLAST. THE TV IS SILL TURNING ON AND OFF. THE SCREEN DID COME ON...
Sir reset the lamp hour meter if you replace the lamp. Aim the samsung remote at the front panel where the infrared sensor is located, press the following keys on the remote in this order, Mute, 1,8,2,Power. Wait until the your tv screen lights up with the words "loading factory" on it. Press the "down" direction pad on the remote to select "option" from the list of choice that appears on the screen. Press the "enter" button on the remote, select "reset lamp timer " from the list of choices presented on the screen. Press the "enter" button on the remote. Turn off the TV with the remotes power button. Then wait at least five minutes before turning ON again your tv hope this helps good day and best regards.
Sep 23, 2011 | Samsung HL72A650 Television
I HAVE MODEL LCT3201TD. I AM USING THE REMOTE THAT CAME WITH THE UNIT. THE REMOTE WILL TURN THE UNIT ON AND OFF,CHANGE VOLUME AND SLEEP TIMER. TO CHANGE CHANNELS I USE A SEPARATE REMOTE. I WOULD LIKE TO...
The tv remote that came with the tv unit.The tv remote might have channels buttons up/down buttons functions and numbers pads might be shorted and dead and no longer functions anymore.U have a Digital Camera turn it on take the tv rmote put in the front of the Digital Camera pushes each buttons one by one all the buttons that work u will able to see a flashing white light on the camera vewing screen,because the Digital Camera can read INFERED input signal to see a output u see on the the camera viewing screen.After u test it on the front of a Digital Camera any buttons don't have a white light flashes INFERED read out than those buttons functions are shorted and dead.Try website like Remotes.com to buy the tv original remote to replace and used.
Aug 29, 2011 | Akai LCT3201TD 32 in. LCD Television
When i push the on button tv turns on or makes clicking sound timmer light flashes and turn off. another thing is when i push device on remote or tv the tv turns off or screen turns blue then shuts off
I would start by pressing the reset button on the front of the screen. After you are able to turn the tv on, press menu the 2470 then press enter on the remote to reset the tv. This might fix your problem. If not suspect the E2P, and if that doesn't work your DM is faulty and needs replaced.
Jul 06, 2010 | Mitsubishi WD73727 73" HDTV
Tv turns on. A blue screen appears. Then it shuts down in 20 seconds. The timer light blinks repetedly.
Try this:
1) turn on TV
2) from the remote control ..press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING.
4) press the RESET BUTTON on front of TV.
5) should be good to go!
Jan 15, 2010 | Mitsubishi WD62627 62" HDTV
TV or control doesn't work need help know
ok my tv is doing the same thing and i need help if you found a solution please email me at pieces41096@aol.com
Jul 06, 2009 | DISH Network 322 DTV Receiver
Tv2 light does not come on
hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
Sharp CRT that will not turn on
its CPU , please model TV write
Mar 17, 2009 | Sharp Televison & Video
Televison & Video Logo
Top Televison & Video Experts
