Como programo mi televisor trinitron son y sin control remoto
    Top Expert:
  • Televison & ... Master
  • 74,666 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts....
Posted on Dec 16, 2016
rulds2008
  • 3866 Answers
SOURCE: nesesito saber como le hago para poder aser que mi
Si los intructcions no sirven endonsis tiene que compara una remoto con mas compatibildad a que uste tiene hay una in www.amazon.com si llama remote plus, eso es mas major de que usted esta useando. Buena surte con su TV y gracias por usar nuestro servicios www.fixya.com
Posted on Apr 29, 2009
kimberlyesco
  • 184 Answers
    Verified Fixya Pro
    SOURCE: COMO PROGRAMO LA TV A MI CONTROL REMOTO DE DISH
    Hola! mi nombre es Kimberly Escobar trabajo con DISH Network. Para programar el control remoto con su television hay ciertos codigos que se pueden integrar al control para que pueda funcionar con la television estos codigo son diferentes dependiendo de la marca de televisor que tenga. Es importante saver cual es la marca para saber que codigo se va a integrar este link puede ser de mucha ayuda aqui puede encontrar los codigos necesarios y el procedimiento a como integrarlos http://www.dishnetwork.com/SupportSection/remote-setup si tiene preguntas adicionales o necesita mas ayuda por favor contactenos directamente al 1800-333-DISH.
    Posted on Feb 07, 2011
    kimberlyesco
    • 184 Answers
      Verified Fixya Pro
      SOURCE: como programo un control remoto
      Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televiso Aoc. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Aoc tenemos los codigos 627,566,505,659, y 664. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
      Posted on Feb 17, 2011
      SOURCE: COMO INSTALAR CONTROL REMOTO UNIVERSAL ATI A
      how to install a remote starter
      Posted on Oct 24, 2011
      kimberlyesco
      • 184 Answers
        Verified Fixya Pro
        SOURCE: Como puedo programar el control de dish para mi televisor panasonic si no tengo los codigos
        Hola mi nombre es Kimberly Escobar con DISH Network. Sera un placer ayudarle proveendole la informacion que necesita. Unos codigos para la television marca Panasonic que se pueden integrar al control serian los siguientes: 685, 512, 738, and 876. El procedimiento es el siguiente: oprima el boton de T.V localizado en la parte de arriba del control hasta que los demas botones se enciendan en rojo una vez esto suceda ingrese uno de sus codigos seguido por el signo de numero por ejemplo 685#, el boton de T.V debe de iluminarce 3 veces despues de esto puede tratar de usar su control con la T.V y deberia funcionar. Si necesita ayuda programandolo este link le puede ser de mucha ayuda http://www.dishnetwork.com/SupportSection/remote-setup tambien me puede contactar directamente a mi correo electronico a kimberly.escobar@dishnetwork.com Gracias espero que esto le sirva de ayuda.
        Posted on Dec 29, 2011
        COMO DESBLOQUEO SIN CONTROL REMOTO
        Sin un control remoto; usted no puede desbloquearlo. Si desea obtener algunos detalles; comprobar el sitio vinculado aqu?. Tire hacia arriba de las entradas m?s antiguas. Navegue por la web con paciencia. http://electronicshelponline.blogspot.com/
        Desbloquear procedimiento y para anular el bloqueo con contrase?a para se dan muchos televisores de marcas populares.
        Apr 26, 2015 | Televison & Video
        ZNA-110 CONTROL
        Remote controls are tricky. You might try reading the directions or checking online for your particular brand to learn to 'program' it.
        May 30, 2013 | Computers & Internet
        No me cambian los canales de mi control remoto
        chunghop universal tv remote control,what is the code for sanyo tv
        Nov 12, 2012 | DISH Network IR Remote Control
        Como programar un control nuevo a la caja de dish.
        hola, tengo un problema con mi control remoto de dish es un 3.4 IR le cambie las pilas y ahora no logro que responda, como apagar la caja o cambiar canales, no responden todas las funciones, si puedo apagar la tv y el volumen.
        May 12, 2011 | DISH Network IR Remote Control
        El lcd prende pero, queda como bloqueado, no me responde del panel de comandos ni del control remoto, solo puedo ver y escuchar en donde quedo sin ningun tipo de problemas.
        Me parece que hay un boton que se quedo atorado y que no deja aceptar otras funciones. Por favor de verificar en el televisor si todos los botones de audio, channel, etc.. son libres.
        Saludos
        Mar 13, 2011 | Samsung Televison & Video
        Tengo imagen negativa kp/51hw40
        Hola!
        Pruebe los siguientes pasos para resolver el problema: Asegúrese de que las conexiones de los dispositivos son firmes y seguros. Trate de encender y apagar la opción de Digital Reality Creation en el televisor. Trate de ajustar la nitidez de imagen y ajustes del modo de la TV. Presione el botón FLASH FOCUS en el panel frontal del televisor. Esto modifica la convergencia. Si el problema persiste, pruebe a quitar el televisor de la pared a dejar y conectarlo a una toma de corriente directa sin ningún tipo de protector después de 1 minuto. Pruebe a pulsar el botón RESET en el tiempo remoto en el menú de vídeo y compruebe si funciona. Si el problema persiste, el servicio puede ser requerido.
        Gracias por usar FixYa.
        Dec 02, 2010 | Sony Televison & Video
        No puedo programar para prender y apagar la tv
        Hola mi nombre es Kimberly Escobar con DISH Network servicio al cliente. Para programar el control con su televisor exiten ciertos codigos que se pueden integrar al control permitiendole funcionar ciertas funciones del televisor, para saber exactamente que codigos son compatibles necesitamos saber la marca del televisor. Tambien existe otro procedimiente donde no se necesita la marca de televisor. Estos procedimientos los puede encontrar en nuestra pagina de Internet oficial http://www.dishnetwork.com/SupportSection/remote-setup aqui encuentra codigos que puede integrar y el procedimiento al Power Scan que viene siendo el que no requiere la marca de T.V para poder programarse. Si necesita mas ayuda por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sea de ayuda.
        Jan 19, 2010 | DISH Network IR Remote Control
        Jan 16, 2010 | DISH Network IR Remote Control
        Televison & Video Logo
        Top Televison & Video Experts
        Electro Med Services...
